Does the Universe's Expansion Affect Time Travel?
The discussion explores the relationship between the universe's expansion and the concept of time travel, referencing Gödel's solutions to Einstein's equations and the implications of a rotating universe. Participants examine theoretical frameworks, including general relativity and the Godel metric, and consider how these might relate to time travel possibilities.
  • Some participants propose that Gödel's solutions indicate time travel is possible, but express concern about the implications of the universe's expansion and rotation.
  • Others argue that the cosmic microwave background radiation (CMBR) suggests the universe is not rotating, which could affect the feasibility of time travel models based on rotation.
  • A later reply questions whether the CMBR could appear stationary if it rotates with the universe, suggesting that such rotation might be undetectable from within the universe.
  • One participant notes that the Godel metric represents a different spacetime than the expanding Friedmann-Robertson-Walker (FRW) solution, highlighting the differences in their properties.
  • Another participant corrects a previous claim about the Godel metric, stating it is homogeneous and lacks special points, but has a special direction at every point.
  • Some participants mention that general relativity allows for reverse time travel under certain conditions involving imaginary matter, but acknowledge that this matter is theoretical and not physically realized.
Participants express a range of views on the implications of the universe's expansion and rotation for time travel, with no consensus reached on the relationship between these concepts. Disagreements persist regarding the nature of the Godel metric and the interpretation of the CMBR.
The discussion includes various assumptions about the nature of spacetime and the conditions under which time travel might occur. Limitations arise from the dependence on theoretical models and the unresolved status of certain mathematical interpretations.
anvesh111
If time travel is possible,is there any problem of universe revolving which would affect time travel,because as,Gödel was the first person who found solution to Einstein equations involving time travel,but he disappointed when astronomers told that universe is expanding,but the net spin of the universe is zero.
i mean ,does revolving and expanding of universe affect the time travel how?
Space news on Phys.org
The field equations for general relativity show that rotation of the universe around a symmetrical axis would lead to closed time like curves.
I was interested in this question of a rotating universe. It seems that the CMBR shows the universe is not rotating.
Really, but if the CMBR is rotating along with the universe and also us, it would all seem stationary, I think something like that can only be detected from an external point of view, and is thus impossible to either confirm or deny that concept.
The Godel metric represents a different spacetime to the expanding FRW solution, so the two can't really be compared. Aib's post above is instructive, "but if the CMBR is rotating along with the universe and also us, it would all seem stationary"; that is exactly right, in order to define that something is rotating, you need to say what it is rotating with respect to. This is the same as any motion, if everything moves together then nothing is really moving in a relative sense, and relative motion is all there is.
On the other hand, the 'rotation' in the Godel metric is of a different nature. It is more like the rotation in a the Kerr solution for a rotating black hole (although the Godel solution is not asymptotically flat or vacuum like the Kerr metric, so there are important differences). Unlike the homogenous and isotropic FRW metric, the Godel metric contains special points, in this case a special line about which the space rotates. The Godel metric is not isotropic, you could actually observe the rotation by noting that along the axis of the spin, everything looks 'normal' but across the plane of rotation you would observe objects to be smeared out.
There are various ways (the key word is 'Killing Vector' if anyone wants to look deeper at the maths) to determine the true co-ordinate independent nature of a given spacetime, and in the Godel metric this analysis tells you that there is true rotation; physical experiments and observations could therefore detect that the space is rotating. On the other hand this same analysis tells you that the FRW metric (that of our expanding universe) is not rotating, and that no experiment of observation would say that it is.
There are no special points, as the Gödel metric is homogeneous. There's a special direction at every point, however.
http://adsabs.harvard.edu/cgi-bin/n...T&data_type=HTML&format=&high=4381f4775710298
http://www.absoluteastronomy.com/topics/George_Smoot
According to this entry on George Smoot,
"He then took up an interest in cosmic microwave background radiation (CMB), previously discovered by Arno Allan Penzias and Robert Woodrow Wilson in 1964. There were, at that time, several open questions about this topic, relating directly to fundamental questions about the structure of the universe. Certain models predicted the universe as a whole was rotating, which would have an effect on the CMB: its temperature would depend on the direction of observation. With the help of Alvarez and Richard A. Muller, Smoot developed a differential radiometer which measured the difference in temperature of the CMB between two directions 60 degrees apart. The instrument, which was mounted on a Lockheed U-2 plane, made it possible to determine that the overall rotation of the universe was zero, which was within the limits of accuracy of the instrument. It did, however, detect a variation in the temperature of the CMB of a different sort. That the CMB appears to be at a higher temperature on one side of the sky than on the opposite side, referred to as a dipole pattern, has been explained as a Doppler effect of the Earth's motion relative to the area of CMB emission, which is called the last scattering surface. Such a Doppler effect arises because the Sun, and in fact the Milky Way as a whole, is not stationary, but rather is moving at nearly 600 km/s with respect to the last scattering surface. This is probably due to the gravitational attraction between our galaxy and a concentration of mass like the Great Attractor."
To answer the topic question, yes, time travel does possible, but only in one direction.
Ah yes, you're right. Thanks, looks like I've been mistaken about that metric for a while. Quite an interesting thing to try and get your head around really...
Yeah, I gave up trying long ago.
GR permits reverse time travel for imaginary matter. But, imaginary matter is still ... imaginary.
  • · Replies 23 ·
  • · Replies 22 ·
