Does the Relativity of Simultaneity Depend on the Axis Along Which Events Occur?
The discussion centers on the relativity of simultaneity in special relativity, specifically addressing how simultaneous events in one inertial frame (S) may not be simultaneous in another (S'). The key assertion is that if events occur along an axis perpendicular to the direction of motion of the second frame, they may still appear simultaneous in that frame. The formula \Delta t' = \gamma (\Delta t - (\textbf{V} \cdot \Delta \textbf{r})/c^2) is highlighted to illustrate the time delay induced by relative motion. Additionally, it is emphasized that clocks in the moving frame K' are not synchronized according to the stationary frame K, leading to differing perceptions of simultaneity.
  • Understanding of Special Relativity (SRT)
  • Familiarity with inertial reference frames
  • Knowledge of Lorentz transformations
  • Basic grasp of time dilation and simultaneity concepts
  • Study Lorentz transformations in detail
  • Explore the implications of time dilation in moving frames
  • Examine the synchronization of clocks in different inertial frames
  • Learn about the concept of simultaneity in various reference frames
Physicists, students of relativity, and anyone interested in the fundamental principles of time and space in the context of special relativity.
darkchild
I was reviewing this concept last night, and it occurred to me that the statement
Two spatially separated events simultaneous in one reference frame are not simultaneous in any other inertial frame moving relative to the first
is not specific enough. If the simultaneous (as seen in S) events occur along an axis that is perpendicular to the direction of motion of the second reference frame S', won't they also appear simultaneous in S'?
It seems like the paragraphs and paragraphs used to explain this phenomenon are a complicated way of saying that events that are simultaneous in one frame S are not simultaneous in another frame moving with respect to the first S' because the moving frame S' is moving toward one of the events and away from the other, thus inducing an observed time delay between the closer event and the further event, in which case the axis along which the events occur is a crucial factor.
Yes, you're quite right
[tex]\Delta t' = \gamma (\Delta t - (\textbf{V} \cdot \Delta \textbf{r})/c^2)[/tex]
A crucial point is that the clocks at rest in inertial frame K' are not all synchronized, according to the clocks at rest in K. In SRT only the clocks in a plane normal to the velocity vector of K' relative to K are synchronized in the opinion of both frames. If K' moves in the positive x-direction of K, and if t1 and t2 are equal, K contends that the events at the respective clocks occurred simultaneously. But K' contends that the clocks are not synchronized (although he agrees that they read the same thing when the space-time coordinates of the two events were measured using the grid/clocks of K). Consequently, K' contends that the two events did not happen simultaneously.
  • · Replies 38 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 221 ·
18K
  • · Replies 16 ·
  • · Replies 51 ·
