Tension at the Top of the String
  • Thread starter Thread starter Ahmad786
    String Tension
The problem involves a ball being swung in a vertical circle, where the tension in the cord at the top of the swing is to be calculated. The parameters include the speed of the ball, the radius of the circle, and the mass of the ball.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of centripetal force and its relationship to tension in the cord, questioning the application of formulas for different positions in the swing. There is confusion regarding the treatment of forces acting on the ball at the top versus the bottom of the swing.
Some participants have offered guidance on the correct interpretation of forces involved, noting the differences in force direction at various points in the swing. There is an ongoing exploration of how to apply the equations correctly for the scenario presented.
Participants express confusion over the application of gravitational force in the context of tension at different points in the swing, particularly regarding the sign convention for acceleration due to gravity.
Ahmad786
If a ball is being swung in a vertical circle at the end of a light cord at a constant speed of 3.35m/s when the the radius of the vertical circle is 0.70m and the mass of the ball is 0.160kg calculate the tension in the cord at the top of the swing.
fc=T+fg
m=0.160kg v=3.26m/s r=0.7m
T=fc-fg fc=T+fg T= ( mv2/r) - mg
now what confuses me is that this equation is used for tension in the cord at the bottom of the circle and it gives me the same answer what can i do to get a different answer for tension in the cord at the top of the cord
Welcome to PF!
Hi Ahmad786! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Ahmad786 said:
fc=T+fg
I think you're confused because you're using fc, by which I assume you mean centripetal (or centrifugal?) force.
This is a bad idea.
This is an F = ma equation, with all the forces on one side, and the acceleration on the other side.
What you are calling "fc" is not a force, it's the centripetal acceleration …
just remember that both T and centripetal acceleration are always inward, but fg can be either inward or outward. :smile:
This is a bad idea.
fc is centripetal force and is given by centripetal force= mv2/r this question is supposed to be answered using T= mv2/r + mg but i am confused on how to execute it
No no no
v2/r is centripetal acceleration
multiply it by m, put it in F = ma, and it should be equal to the total forces (in the vertical direction), in this case T and ±mg.
(if your book says that it is always +mg, then your book is wrong)
You are confused because you are tyring to treat this as a problem with three forces … when you accept that there are only two forces, everything will become clearer. :smile:
tiny-tim said:
No no no
there are example problems for this but they are on the downswing of the string they use the equation that I am using but its supposed to be used differantly for the upswinng I am still very confused:shy:
On the downswing, T and mg are in opposite directions, but on the upswing, T and mg are in the same direction.
So the first has ma = T - mg, the second has ma = T + mg. :smile:
so for my question it would be ma=T+mg and the ma is mv2/r so T=mv2/r -mg so (0.160kg)(3.26m/s)2/(0.7m) - (0.160kg)(-9.81m/s2) or do i use positive 9.81 for this example and do (0.160kg)(3.26m/s)2/(0.7m) - (0.160kg)(+9.81m/s2)
We always say g = 9.71 (positive), so the downswing has ma = T - mg, and the upswing has ma = T + mg.
Thx I got it :smile:
  • · Replies 16 ·
10K
