Determine the electric field on the y axis
The discussion focuses on calculating the electric field at a point on the y-axis due to two 2.04 µC point charges located symmetrically on the x-axis at x = 1.02 m and x = -1.02 m. The electric field is determined using the formula E = k*q/r², where k is Coulomb's constant (8.99e9 N·m²/C²). The solution involves calculating the distance from each charge to the point on the y-axis and resolving the electric field vectors into their x and y components. The key conclusion is that the y-components of the electric fields from the two charges cancel each other out while the x-components add, leading to a net electric field along the x-axis.
  • Understanding of Coulomb's Law and electric field calculations
  • Knowledge of vector resolution techniques (SOH CAH TOA)
  • Familiarity with trigonometric functions and their applications in physics
  • Basic algebra for combining vector components
  • Review vector resolution techniques in physics
  • Study the effects of charge sign on electric field direction
  • Learn about superposition principle in electric fields
  • Explore advanced topics in electrostatics, such as electric field lines and equipotential surfaces
This discussion is beneficial for physics students, educators, and anyone studying electrostatics, particularly those working on problems involving electric fields from multiple point charges.
LANS
Two 2.04 µC point charges are located on the x axis. One is at x = 1.02 m, and the other is at x = -1.02 m. Determine the electric field on the y-axis at y = 0.470 m.
E = k*q/r^2
First I find the distance from one of the charges to the point on the y-axis.
[tex]\sqrt(1.02^2 + 0.47^2) = 1.123m[/tex]
I also find the angle between this line and the y-axis.
[tex]tan^1 \frac{1.02}{0.47} = 65.26[/tex]
Then I found the component of the electric field at the point on the axis which lies along the y-axis.
[tex]E = k_e*\frac{q}{r^2}[/tex]
[tex]E = 8.99e9 * \frac{2.04\mu C}{1.123m}*cos(65.26)[/tex]
As this only accounts for one charge, and the other charge is equal in magnitude and position, I double this number to get the answer.
Howerver, this gives me the wrong answer. Any help would be appreciated.
The E field due to one of the charges (the one at x=1.02) on the y-axis is given by your equation E=k*q/r^2.
if you draw a line from your charge to the point on the y-axis, this E vector points in this direction. If your other charge (at x=-1.02) has opposite sign, then the y components of the E vectors cancel each other out and the x-components add. Else, the x-components cancel and the y-components add.
In either case break the E vector that you found into its x and y components using SOH CAH TOA. Then do the simple algebra depending on the signs of your charges.
