Finding the Intercepts and Asymptote of a Graph with Exponential Functions
  • Thread starter Thread starter TyErd
    Graphic
The discussion revolves around finding the intercepts and horizontal asymptote of the function defined by the equation y=e^(2x) - 3ke^(x) + 5. Participants are exploring the values of a, b, and k, where the graph intersects the axes and has a horizontal asymptote.
  • Participants discuss substituting values into the equation to find k and a. There are attempts to understand the behavior of the function as x approaches infinity and negative infinity to determine the horizontal asymptote. Some participants question the implications of their findings and the definitions involved.
There is ongoing exploration of the values of a, b, and k, with some participants providing insights into the behavior of the function. Multiple interpretations of the asymptotic behavior are being discussed, and while some guidance has been offered, there is no explicit consensus on the findings yet.
Participants are working under the constraints of the problem as posed, with some expressing confusion about the asymptotic behavior and the role of their calculators in evaluating the function at extreme values of x.
TyErd
The graph of a function with equation y=e^(2x) - 3ke^(x) +5 intersects the axes at (0.0) and (a,0) and has a horizontal asymptote at y=b. Find the exact values of a,b and k.
I tried assigning a variable to e^x but struck a dead end.
If (0, 0) is a point on the graph, then you can replace y and x with 0 to solve for k, and a won't be hard to solve for after that.
Have you found b?
oooohk so i found k and it equals 2 and also a which equals loge(5). and no i haven't found b
not sure how to find b
If [itex]z=e^x[/itex], you have [itex]y=z^2-6z+5[/itex]. Does that help?
Think of what happens with y = e2x - 3kex as x→∞ or -∞. Does it approach a certain value? What happens when you shift the graph up 5 units with the +5?
vela is leading you toward finding the x-intercepts, and Bohrok is leading you toward finding the horizontal asymptote.
Yeah, I misread the problem. Ignore what I said.
No, not a problem. I was just pointing out to the OP that the two of you were looking at different parts of the problem.
hey I am still having trouble understanding what the horizontal asymptote is.
b is 5 but i don't get why
What does the function do as x goes to infinity or -infinity?
do i have to use the calculator to do that?
Of course not!
Just try to puzzle out where y goes for x-> -oo. I've excluded +oo to get you to understand something important. Use the fact that for any x, x^a =0 if a-->-oo.
Altabeh said:
Of course not!
This not true for 0 < x < 1. Even if you limit it to x > 1, x^a merely approaches zero as a gets large. x^a is not equal to zero for any real value of a.
ook,as x approaches -infinity it gets closer to 5 but at a certain -x value, y actually equals 5. Which isn't right because its suppose to be an asymptote. And also why exclude positive infinity??
as x approaches -infinity y approaches 5. The use of "it" is confusing because a casual reader would think you were talking about x. There is no negative value of x for which y = e2x - 6ex + 5 equals 5. In fact, for x < 0, y is always < 5, but it gets infinitesimally close to 5 the more negative x gets.
There is a positive value of x for which y = 5, but we're talking about asymptotic behavior for x < 0, i.e., behavior for very negative x values.
Im not sure if I am doing something wrong but I just substituted -15 into x and y equaled 5 but as i get more negative like x=-1000, y still equals 5.
You're probably running into the limitations of your calculator. For x=-15, to ten decimal places, y=4.9999981645, which is within two-millionths of 5. At x=-1000, y differs from 5 by about [itex]3\times10^{-434}[/itex].
oh yea vela you're right, i just tried it on a different calculator.
  • · Replies 21 ·
  • · Replies 17 ·
