Can You Calculate Torque with Angular Velocity and Moment of Inertia Data?
The discussion focuses on calculating torque from given angular velocity, mass, and moment of inertia data for a turntable disk. The mass is specified as 0.04452199 kilograms, with an angular velocity of 106.81 radians/second. The moments of inertia are provided in detail, including values taken at both the center of mass and the output coordinate system. The key equation for torque, τ = dL/dt, is highlighted, emphasizing the need to consider the spin angular momentum vector, especially due to the offset of the axis from the center of mass.
  • Understanding of torque and angular momentum concepts
  • Familiarity with SolidWorks for modeling and data extraction
  • Knowledge of moment of inertia calculations
  • Basic physics principles related to rotational dynamics
  • Study the relationship between angular velocity and angular acceleration
  • Learn how to calculate torque using the equation τ = dL/dt
  • Explore the effects of offset axes on torque and angular momentum
  • Investigate SolidWorks tools for analyzing rotational dynamics
Students in physics or engineering courses, mechanical engineers, and anyone involved in rotational dynamics analysis or SolidWorks modeling.
physisis
I have an assignment that asks to find a torque from given angular velocity, mass and moment of inertia.
For a turntable disk, mass is known as 0.04452199 kilograms
The Angular velocity should be 106.81 (rads/sec)
These values are from solidwork file (anyone familiar with Solidworks?)
Center of mass: ( meters )
X = -0.01474448
Y = -0.00659061
Z = 0.04376940
Principal axes of inertia and principal moments of inertia: ( kilograms *
square meters )
Taken at the center of mass.
Ix = (-0.70029829, 0.71385033, 0.00002079) Px = 0.00001872
Iy = (-0.71385033, -0.70029829, -0.00002111) Py = 0.00001875
Iz = (0.00000000, -0.00002962, 1.00000000) Pz = 0.00003073
Moments of inertia: ( kilograms * square meters )
Taken at the center of mass and aligned with the output coordinate system.
Lxx = 0.00001874 Lxy = -0.00000001 Lxz = 0.00000000
Lyx = -0.00000001 Lyy = 0.00001874 Lyz = 0.00000000
Lzx = 0.00000000 Lzy = 0.00000000 Lzz = 0.00003073
Taken at the output coordinate system.
Ixx = 0.00010596 Ixy = 0.00000431 Ixz = -0.00002873
Iyx = 0.00000431 Iyy = 0.00011371 Iyz = -0.00001284
Izx = -0.00002873 Izy = -0.00001284 Izz = 0.00004234As far as I know, equation for torque is angular acceleration X moment of inertia,
but in this case, I don't have Angular acceleration but velocity. and Radius is unknown.
Is it possible to get a value of Torque from these information? I am keep looking for way to approach this question but I am having a hard time with it.
Any help will be appreciated.
Note that the turntable is spinning through an axis that is offset from its center of mass. That means that relative to its center of mass, the contact forces at the pivot produce a torque.
I think that the spin angular momentum vector goes through a precession because of this offset, but I'm not sure.
If I'm right in my approach, then the key to solving this question is: [tex]\vec \tau=\frac{d\vec L}{dt}[/tex] where in this case, [tex]\vec L[/tex] would be the spin angular momentum vector.
  • · Replies 42 ·
  • · Replies 18 ·
