Are Endothermic Nuclear Reactions Possible in Nature?
The discussion revolves around the possibility of endothermic nuclear reactions in nature, specifically focusing on the conditions under which such reactions might occur, the implications of negative Q values, and the mechanisms of beta decay. Participants explore theoretical aspects, examples, and the energy requirements for these processes.
  • Some participants propose that endothermic nuclear reactions imply that the initial rest mass energy is less than that of the products, leading to confusion regarding the decay of an isolated proton.
  • Others clarify that an isolated proton cannot disintegrate into a neutron, positron, and neutrino due to the requirement of energy input for endothermic reactions.
  • Questions arise about the source of energy that triggers beta plus decay, with some suggesting that differences in nuclear binding energy play a role.
  • One participant notes that a stable parent nucleus will not spontaneously decay unless external energy is provided.
  • Another participant explains that proton to neutron decay occurs for neutron-poor nuclei, while neutron to proton decay occurs for neutron-rich nuclei, emphasizing the symmetry in weak force processes.
  • Internal conversion is mentioned as an interesting form of beta decay, where a proton absorbs an electron to become a neutron, which is an exothermic process.
  • Concerns are raised about the search for endothermic proton decay, with some participants noting that such decay has not been observed and discussing the implications of proton decay lifetimes.
  • Questions about the nature of the weak force and its role in nuclear processes are posed, with some participants expressing confusion about its characterization as "weak" despite being a fundamental nuclear force.
  • There is a discussion about the energetic permissibility of proton decay to a neutron, with some participants asserting that external energy is necessary for such a reaction to occur.
Participants express a range of views on the mechanisms and conditions for endothermic nuclear reactions, with no consensus reached on the specifics of energy sources or the characterization of the weak force. Multiple competing explanations and models are presented throughout the discussion.
Limitations include the dependence on specific definitions of energy states and binding energies, as well as unresolved questions regarding the exact nature of energy inputs required for certain nuclear reactions.
kihr
Nuclear reactions in which the Q value is negative (endothermic reactions) imply that energy is absorbed in the process of the reaction. Is this to be interpreted as a case where the initial rest mass energy is less than the rest mass energy of the products of the reaction? If affirmative, it should be possible for an isolated proton to disintegrate as under:
p -- n + e+ (positron) + Y(neutrino)
However, the above is not possible because the mass of a proton is less than that of a neutron, and thus the reaction would imply a negative value of Q (mass energy on the left of the equation being less than that on the right). The reaction, otherwise, appears to be endothermic in nature because of the negative Q value. There, thus, appears to be a conflict in my understanding on this score.
I would appreciate if the forum members could clarify the position to me, and to also provide me with one or two examples of endothermic reactions.
Everything you said is correct except for this sentence:
As you say, this is an endothermic reaction, so it requires in input of energy. Therefore it won't occur for an isolated proton.
OK. Could you also indicate as to how in a beta + decay, what is the source of the input energy that triggers the above reaction, i.e., transformtion of a proton into a neutron? Thanks
There's a difference in nuclear binding energy between the initial nucleus and the final nucleus.
I now understand the issue somewhat better. Should the parent mass be less than the sum of the masses of the daughter and remaining products of the hypothetical reaction, the parent is a stable nucleus and will not spontaneously decay. The reaction could, however, take place if some external energy is given to the parent nucleus. This explains why an isolated proton will not decay into a neutron plus a positron and neutrino.
However, I am still not quite in the grip of how the proton in a nucleus decays spontaneously into a neutron plus positron and neutrino. I believe that this situation happens relatively less often, but I am trying to understand as to why this happens at all. Maybe you could explain to me using some examples. Thanks.
P->n doesn't happen less often. P->n happens for nuclei on the neutron-poor side of the line of stability, whereas n->p happens on the neutron-rich side. As to why it happens, p->n happens for the same reasons that n->p happens. The weak force treats the two processes symmetrically. As a general rule in quantum mechanics, if a process can occur without violating conservation laws, then it will actually occur.
There is an interesting form of beta decay called internal conversion, where a bound [STRIKE]neutron[/STRIKE] proton in the nucleus (example: beryllium-7) absorbs an atomic electron, and becomes a bound neutron plus an anti-neutrino.
e- + p → n + ν-bar
This reaction is exothermic. Endothermic proton decay to a neutron has been searched for, and not found. The minimum proton decay lifetime (if it decays at all) is over 1025 years.
Bob S
I think searches for proton decay are searching for spontaneous (and therefore exothermic) decay, and it's not decay into a neutron, it's decay into something like a pion and a positron: http://en.wikipedia.org/wiki/Proton_decay
Quote
Unquote
Could you please elaborate further on the above? Does the weak force refer to force between two nucleons? If it is indeed a nuclear force such a force cannot be weak because it is supposed to be about the strongest force on earth. Hence you must be referring to some other force.
Also in the case of B- decay, the nucleous has a surplus of neutrons and therefore one neutron decays to a proton thereby emitting an electron and an antineutrino in the process. As the mass of a neutron is a little higher than that of a proton, this reaction is energetically permitted. However, in the scenario of a nucleous being neutron deficient, one proton decays to a neutron. However, since the proton has less mass than a neutron this reaction should not be energetically permitted. This is precisely where my doubt arises. Actually in this case the nucleus has to receive some external energy so that the reaction could take place. What is the source of this external energy? Perhaps you could look into my concern from this angle. Thanks.
  • · Replies 18 ·
