UFO Sighting: Is It Real or Imaginary?
  • Thread starter Thread starter Grizzlycomet
    Imaginary
The discussion centers on a reported UFO sighting observed through 10x40 binoculars, where the object exhibited unusual movement patterns, including sharp turns and fading visibility. The observer speculated whether the sighting could be attributed to satellites, specifically mentioning an old Russian rocket body and an American Lacrosse satellite, which were both in the vicinity of Oslo around the time of the sighting. However, the observer noted discrepancies in timing and duration, leading to uncertainty about the object's identity. The discussion emphasizes the importance of precise location and timing when identifying celestial objects.
  • Understanding of satellite visibility and orbital mechanics
  • Familiarity with binocular usage for stargazing
  • Knowledge of celestial navigation and star mapping
  • Experience with tools like Heavens-Above for satellite tracking
  • Research satellite tracking using Heavens-Above and similar tools
  • Learn about the orbital paths of specific satellites, including the Russian rocket body and American Lacrosse satellite
  • Study the principles of light reflection and visibility of satellites post-sunset
  • Explore techniques for documenting and reporting UFO sightings effectively
Astronomy enthusiasts, amateur astronomers, and individuals interested in UFO phenomena will benefit from this discussion, particularly those looking to enhance their observational skills and understanding of satellite behavior.
Grizzlycomet
I was outside just now, stargazing with my 10x40 binoculars, as it is an exceptionally clear and beautiful night here today. I was looking east, at Andromeda, when I spotted a moving object. It's apparent size and magnitude was about that of the stars behind. I follow it in my binoculars while it traveled towards the horizon, and in a northernly direction for maybe 30 seconds. At this point, it made a 180 degree turn, now heading up from the horizon and in a southernly direction. After another 20 seconds or so, it again made a sharp turn, now heading straight north parallell to the horizon. Now it started fading rapidly, and after a short while, maybe like 10 seconds, it was too faint for me to keep tracking it.
Am I seeing a UFO :confused:
Or does anyone have a more down-to-earth solution?
Astronomy news on Phys.org
Hard to account for such a strange path.
Usually, the 'stars' you see moving too rapidly to be stars are satellites. Just after sunset, the sun can reflect off of them, making them visible to you.
You don't give your location very precisely or the exact time you saw them. However, if the location were Oslo (biggest city I know of in Norway, therefore the best chance of being right), two reasonably bright satellites could have been seen tonight.
An old Russian rocket body should have risen in the southwest at 10:52, hit its maximum elevation of 70 degrees in ESE direction at 10:58, and set in the NE at at 11:03 (man you guys have late sunsets up there).
An American Lacrosse satellite should have risen in the SW at 10:58, hit its max elevation of 75 degrees in the SE at 11:03 and set to the NE at 11:08.
Typically, satellites are not visible for the entire time they are above the horizon - it depends on the angle between the Sun-satellite-and you, plus the satellite's orientation sometimes. The satellite would almost certainly be visible at its max elevation, though.
If you're out of the city, and have binoculars there's quite a few others you could have seen, some of which would cross each other while still visible.
Check http://www.heavens-above.com/
They post schedules for most visible satellites.
I'm in a town called Tønsberg. It's a bit south of Oslo, but not too far so the times shuld not be too far off. The time of the sighting was not too long before I made my post, a little before 2 am local time. The satellites you mention had the right kind of directions, but they had the wrong timing (assuming you gave times in local time, CET), also they were there for spans of ten minutes. The object I saw was visible for only one, certainly no more than one and a half minute. I am familiar with heavens-above, I use it regularly. I searched it for possible matches immideately after the sighting, but couldn't find any satisfactory results. Not that any of the other satellites I have seen carried out these kind of maneuvers in any case. As to satellites crossing each other's paths, I am certain I was following a single object all along, as I had it in view at all times.
10K
  • · Replies 60 ·
  • · Replies 84 ·
