Could Ammonia be the Basis of Life?
This discussion explores the potential of ammonia as a solvent for life, drawing comparisons to water. Ammonia is polar, amphoteric, and can form acid and base conjugates (NH4+ and NH2-), which may allow for life forms in extreme environments like Titan, Saturn's moon. However, the consensus indicates that carbon-based life in warm environments is more likely due to the abundance of water and the temperature requirements for biological processes. The challenges of ammonia as a life solvent include its low temperatures and the rarity of ammonia compared to water in the universe.
  • Understanding of polar solvents and their properties
  • Basic knowledge of astrobiology and the conditions for life
  • Familiarity with chemical compounds such as NH4+ and NH2-
  • Awareness of planetary environments, particularly Titan and its conditions
  • Research the properties of ammonia as a solvent for life
  • Explore the conditions on Titan and its potential for hosting life
  • Investigate alternative biochemistries, including silicon-based life
  • Study the abundance of chemical elements in the universe and their implications for life
Astrobiologists, chemists, and anyone interested in the potential for alternative life forms in extreme environments.
espen180
I'm guessing this is the right forum to post in.
Ammonia shares many properties with water. It is polar, it is amphoteric, it reacts with itself to form its acid and base conjugates NH4+ and NH2-.
Just as water is our basis of life, could another species use ammonia like we use water?
On another note, ammonia combusts to water and nitrogen(oxide).
Biology news on Phys.org
Definitely and it's an astrobiologists job to verify what exactly would have to be going on etc. in order for these various life forms to exist, what they would look like, if intelligence could arise, etc.
Here's an article specifically on ammonia life forms(the beginning is atleast):
http://www.xenology.info/Xeno/8.2.2.htm
This article also lists a bunch more 'life-solvents' and discusses a couple of them.
Ammonia is antifreeze, that means it is useful in cold invironments like saturns moon Titan.
-180 makes Methane or water freeze, but Ammonia is able to make it fluent and suitable for life.
On the other hand, water is common in our universe, its from Hydrogen+Oxygen, that means you will find it everywhere. The chance life takes water instead of Ammonia as solvent is already bigger.
The next problem, Ammonia makes solvents fluent, but the temperatures stay the same (-180 on Titan), which is not suitable to life forms.
The rule is (at least for carbonlife), the hotter (unless it is too hot) the faster the reproducion and thus the faster the development of life.
And carbon, which is the construction of our DNA, doesn't harmonize with cold environments (from what i remember), silicon is better in cold.
But silicon is on the other hand not very good "constructor".
All in one, carbon is common (search: abundance of chemical elements), water is common, and thus life in warm environments (planet at 0.8 - 1.3 AU, in the case of yellow stars like our Sun) common.
While life on cold planets/moons, means far away from star and less photosynthesis
(but enough oxygen in the atmosphere of the Earth was the reason higher life (animals/plants) was possible, photosynthesis and enough oxygen is important),
ammonia not so common, siliconlife problematic (once, i heard a scientist saying, sex of siliconlife takes up billions of years:eek:).
All in one, carbonlife in warm water is probably the most you will find.
http://en.wikipedia.org/wiki/Hypothetical_types_of_biochemistry"
  • · Replies 21 ·
  • · Replies 21 ·
14K
