What is the significance of work done by an ideal gas?
The discussion focuses on calculating the work done by an ideal gas during the dissolution of 50.0 g of tin (Sn) in excess acid at 1.00 atm and 298.15 K. The reaction produces 2 moles of hydrogen gas (H2) as indicated by the equation Sn(s) + 2H+(aq) → Sn2+(aq) + H2(g). The work done is derived using the formula w = -PΔV, where ΔV is calculated as ΔV = (ΔnRT)/P, leading to the conclusion that the work done is w = -(2 mol H2)RT.
  • Understanding of ideal gas laws
  • Knowledge of stoichiometry in chemical reactions
  • Familiarity with thermodynamic concepts
  • Basic skills in algebra for calculations
  • Study the Ideal Gas Law and its applications in thermodynamics
  • Learn about the relationship between pressure, volume, and temperature in gases
  • Research the concept of enthalpy changes in chemical reactions
  • Explore advanced stoichiometry involving gas production and consumption
Chemistry students, chemical engineers, and professionals involved in thermodynamics and reaction kinetics will benefit from this discussion.
AdkinsJr
See my reply
I'm trying to calculate the work done when 50.0 g of tin dissolves in excess acid at 1.00 atm and 298.15 K
[tex]Sn(s)+2H^+(aq)-->Sn^{2+}(aq)+H_2(g)[/tex]
Here is what I've done:
[tex]\Delta V=\frac{\Delta n RT}{P}[/tex]
[tex]\Delta n=n_{H_2(g)(after)}-n_{H_2(g)(before)}=2 mol H_2[/tex]
It seems that the moles of hydrogen gas will apply pressure to the air, so the work will be
[tex]w=-P\Delta V[/tex]
[tex]\frac{-P(2 mol H_2)RT}{P}[/tex]
[tex]=-(2 mol H_2)RT[/tex]
This makes sense in terms of dimensions, but I don't have the answer in my book, so I can't tell if I did this right.
  • · Replies 16 ·
