How Does Water Pressure Relate to Tank Height and Pipe Elevation?
The discussion focuses on the relationship between water pressure, tank height, and pipe elevation. The water level in a tank is 37 meters, which generates a street-level pressure of 36x104 Pa. To achieve a pressure of 400 kPa (40x104 Pa) at the bottom of a vertical pipe, the required height of the water column must be calculated using the equation P = pgh. The correct height for the vertical pipe is determined to be 40 meters.
  • Understanding of fluid mechanics principles
  • Familiarity with pressure calculations using P = pgh
  • Basic knowledge of units of pressure (Pascal, kPa)
  • Ability to manipulate equations for height and pressure
  • Study the derivation and applications of the hydrostatic pressure equation P = pgh
  • Learn about the implications of water tank height on municipal water supply systems
  • Explore the effects of pipe elevation on water pressure in fluid systems
  • Investigate real-world applications of pressure gauges in hydraulic systems
Students in engineering or physics, educators teaching fluid mechanics, and professionals involved in water supply system design and analysis.
SAT2400
The water level in a large tank supplying a small town is 37m high. Water is pumped up for storage in the evenings and allowed to free-fall down as needed during the day. The street-level water pressure is...
2) How high should a vertical pipe filled with water be if a gauge at its bottom is to read a pressure of 400kPa due only to the liquid?
P= pgh = F/A
answer: 36x 10^4 Pa
2)
answer: 3x 10^4 Pa
I have been trying to get these right answers using the equations above..
But, I have no idea..T_T
Please help!
P= pgh = F/A
answer: 36x 10^4 Pa
yes
2)
answer: 3x 10^4 Pa
I don't know what you did here, but the problem is asking for the height, when the pressure is 400 kPa (40x 10^4 Pa). Use the same equation you used for the first part. (you don't need to know F or A).
  • · Replies 17 ·
