Thread Closed
Law of conservation of mass question
Share Thread Thread Tools
Jan19-10, 03:36 AM   #1
" In a chemical reaction matter can be neither created nor destroyed "
So does this law only apply to chemical reactions or can matter ever be destroyed or created in any way shape or form?
and do people beleive that something that has been burned can be unburned?
It says that when metal is heated it leaves behind calx and that if you want to remove the calx and combine it with charcoal you can then heat the calx will become metal again, this seems untrue, this is in a science book, not sure whether or not they are talking about a theory that existed at one time or if this is believed to be true now a days that something can be un burned ?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> Detecting mirror molecules: New technique reliably tells left-handed from right-handed variant of a compound
>> Chemists devise inexpensive, accurate way to detect prostate cancer
>> Overcoming resistance to anti-cancer drugs by targeting cell 'powerhouses'
Jan19-10, 07:36 AM   #2
Admin
Quote by land_of_ice View Post
Mass conservation has been replaced by mass&energy conservation - that is, mass can be converted directly into energy and vice versa. But for most practical purposes mass conservation still holds, it becomes important when you are close to c or when you are talking about nuclear eactions.
Calx is usually a metal oxide - and it can be decomposed back into metal and oxygen. It doesn't have to be easy, but it is always doable.
ChemBuddy chemical calculators - buffer calculator, stoichiometry calculator
www.ph-meter.info - ph meter, ph electrode
Jan19-10, 08:04 AM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
This is called reduction (the opposite of oxidation). The heated charcoal produces carbon monoxide, which steals the oxygen from the metal oxide, turning it back into metal again.
It's how people have produced metal from ore for ten thousand years.
Thread Closed
Thread Tools
Similar Threads for: Law of conservation of mass question
Thread Forum Replies
Conservation of Mass Special & General Relativity 10
question about conservation of energy/mass Classical Physics 2
Conservation of Mass? General Physics 8
Conservation of mass Introductory Physics Homework 2
One question on conservation of mass and energy Introductory Physics Homework 0
