Does the ground have to be on X2?
  • Thread starter Thread starter foo
    Ground
The discussion centers on the wiring configuration of potential and current transformers in a schematic. Specifically, it addresses whether the wire connecting the transformers to the test switch must be connected to X2 or if it can be connected to X1. Additionally, it examines the implications of grounding in relation to the resistance of potential and current coils, questioning if an Earth ground can be safely connected without causing a short circuit. The transformers are typically designed for a nominal operating voltage of 115Vac, with the test switch shorting the current transformers' secondary when open.
  • Understanding of transformer wiring configurations
  • Knowledge of potential and current transformers
  • Familiarity with grounding principles in electrical systems
  • Basic electrical measurement techniques
  • Research the wiring standards for potential and current transformers
  • Learn about grounding techniques in electrical circuits
  • Study the operation and safety of test switches in transformer applications
  • Explore the implications of transformer resistance on grounding and measurement accuracy
Electrical engineers, technicians working with transformer systems, and professionals involved in electrical measurement and grounding practices will benefit from this discussion.
foo
In this schematic there is two potential transformers on the left and two current transformers on the right.
The potential transformers on the left are connected together by a wire between X2 of the left transformer and X1 of the right transformer. Then there is a wire that must come from one of these two transformers to the test switch location that also has a ground connected to it.
My first question on this is, does the wire that connects these two ends of the transformer to the switch have to be connected to X2 in that part or can it be connected to the X2 or X1 of those two directly connected terminals?
I ask because I notice that the schematic rearranged the way that the current transformers on the right are oriented so that the X2 wires that are going to the switch will also be grounded. Althought they are not connected in series with each other like the left ones are.
My second question is, are the potential and current coils connected at the tops past the switch so much less resistant than the Earth ground that an Earth ground can be connected in this way without causing a short? Will only excessive current go to ground? And under what kind of conditions will current decide to go to ground?
I see nothing wrong with the wiring here. Ground is just your reference when taking measurements (I assume the components above your test switch are meters). The voltage transformers are wired so that the connection of X2 and X1 is like a center tap. You are measuring the voltage of each leg to ground; (they are usually wound to provide a nominal operating voltage of 115Vac which represents the lines higher voltage). And the current transformers are wired to measure the current through each leg; (they are usually wound to provide a nominal operating voltage of 115Vac which represents the lines normal current).
Note that the test switch shorts out the CTs secondary when the switch is open (not taking a reading).
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 42 ·
  • · Replies 32 ·
