Magnitudes, Resultant Force (missing angle)
The discussion revolves around determining the angle \(\phi\) for a force \(F_3\) in a physics problem involving resultant forces and vector components. The context includes analyzing a diagram with given dimensions and angles related to forces acting in a plane.
  • Participants explore the need to find the angle \(\phi\) and discuss the possibility of using sine and cosine values instead. There are questions about the relevance of certain dimensions in the diagram and whether assumptions about the triangle formed by the forces are valid.
The discussion is ongoing, with participants providing insights and clarifications about the geometry involved. Some guidance has been offered regarding the interpretation of the diagram, but no consensus has been reached on all aspects of the problem.
Participants note potential confusion regarding the dimensions in the diagram, particularly concerning a corner that may affect the interpretation of the triangle's sides. There is an acknowledgment that some measurements may not be relevant to the specific problem at hand.
jegues
See attachement.
I would be able to solve it if I could somehow find [tex]\phi[/tex] to describe the angle of F3 relative to the positive x axis. Can anyone see how to solve that specific angle?
Then and can simply sum as follows
[tex] F_{x} = F1cos(\theta) + F2cos(\alpha) + F3cos(\phi)[/tex]
and
[tex] F_{y} = F1sin(\theta) + F2sin(\alpha) + F3sin(\phi)[/tex]
and
[tex] F = \sqrt{F_{x}^{2} + F_{y}^{2}}[/tex]
Then let [tex]\beta[/tex] be the resultant angle,
[tex]\beta = tan^{-1}(\frac{F_{y}}{F_{x}} )[/tex]
You don't need to know the angle [itex]\phi[/itex] itself, just its sine and cosine. And the picture gives x and y sides of a similar triangle to the one with F3 as the hypotenuse.
I think you are thinking of the similar triangle for F2 not F3. Am I correct in my assumption?
No, the diagram gives you similar information for F3. It's just not explicitly drawn in like it is for F2. F3 lies on the hypotenuse of a triangle in the picture. You should be able to identify the lengths of the legs of that triangle.
Well it can't be the triangle with the sides 0.2 and 0.3 because there is a corner that intersects it at the bottom right. I don't see how the 0.1 near the joint helps us either.
Is it safe to assume that the corner in the bottom right doesn't effect our triangle so it will have sides of 0.2 and 0.3?
Otherwise, I'm just not seeing it! Any more help?
Truth is, I didn't see that little corner so you are correct. But I would bet money that it is safe, and you are expected, to ignore it, and use the .2 and .3.
Is there any other way I could solve that angle without using similar triangles (using sides 0.2 and 0.3)? If so how?
If there's no other way, then I guess I'm stuck assuming it's the safe(and correct) way to do it.
I don't see why the corner is a problem.
Because if that corner is there then the sides aren't going to be 0.2 and 0.3 respectively.
I just looked at the picture again. The corner is not a problem at all. It is only the dimension arrows that give it that appearance. The dimensions are OK as given.
The thin lines are all dimension lines, so that is not a "corner." Look at the 0.3m measurement: there are arrows pointing up and down. The arrow pointing up points to a dimension line, as does the arrow pointing down. What you're seeing as a "corner" is this lower dimension line intersecting with the right-hand dimension line for the 0.2m measurement. The thin line extending out of the bold 1200N force line is just an extension of the force line which is being used to give us the slope of the force.
jegues said:
WI don't see how the 0.1 near the joint helps us either.
There are a couple of measurements that don't relate to this problem. My guess is that this diagram comes from a book with several questions relating to it.
Draw a vertical line from the corner to the upper horizontal line. The vertical line, the upper horizontal line, the horizontal edge of the corner, and the measurement arrows form a rectangle. The opposite sides of the rectangle are the same length, so the vertical line is 0.3 m. Similarly, the horizontal distance from where F3 acts to the corner is 0.2 m.
Thank you for the clarification, I seem to have forgot that we were only using the similar triangle to solve the angle for F3 in relation to the positive x-axis.
I've solved the problem now!
  • · Replies 16 ·
  • · Replies 21 ·
