Measuring 3 Phase Current: Tips for Determining Motor Draw
The discussion revolves around methods for measuring the total current drawn by a three-phase motor. Participants explore the use of clamp meters, the implications of current imbalance, and considerations for component sizing in electrical systems.
  • One participant inquires about using a clamp meter to measure the current in each phase and summing them to find total current draw.
  • Another participant notes that if the system is balanced, the currents should be equal, but in practice, the highest current reading is often considered for practical applications.
  • It is mentioned that slight voltage unbalance in three-phase systems can lead to current imbalance, which is typically acceptable within a few percent.
  • A formula for calculating power in a three-phase motor is provided, incorporating line-to-line voltage, average per-phase current, and power factor (PF).
  • One participant emphasizes the importance of considering the highest current reading for sizing components, especially in older systems where wear may increase current draw.
  • Concerns are raised about significant current imbalances (greater than 5%), which may indicate underlying issues with the motor or system.
Participants express varying opinions on the best approach to measuring and interpreting current draw, with some advocating for averaging and others for using the highest reading. There is no consensus on a single method, reflecting differing practices and experiences.
Participants acknowledge that the discussion is influenced by practical experiences and that assumptions about balance and measurement techniques may vary based on specific applications and conditions.
This discussion may be useful for electrical engineers, technicians working with three-phase systems, and individuals interested in motor performance and electrical measurements.
chronic_mka
Hi, I have a question.
Suppose I have a motor that runs on 3 phase power. If I only wanted to find out the total amount of current that the motor draws, how would I go about doing that?
Would I just use a clamp meter to get the amount of current going through each phase and then add them up to get the total current that the motor draws?
Welcome to PhysicsForums!
Unfortunately, I'm not a power engineer and the last time I encountered these sorts of problems were in second year, nearly a decade ago. That said, you'll notice that the voltage (and hence current) waveforms are all 120 degrees out of phase:
http://en.wikipedia.org/wiki/3_phase
Your clamp meter (usually) gives you an RMS value for current (though you can also get ones that give you the max and min), or, the equivalent DC current that would be have to flow to give the same power. With this in mind, you can add up the RMS currents per phase to determine total current consumption (what the power company would charge you).
EDIT: Hopefully, your currents per phase are fairly close, otherwise your motor (or the load) may be unbalanced!
If everything is balanced, all three legs should show the same amount of current (albeit, at different angles). In practice, this is not the case, so I usually just consider the highest current reading.
It is not uncommon for typical 3-phase supply voltages to be slightly unbalanced. this voltage unbalance will be reflected in per-phase current imbalance in the motor. It is acceptable & normal to see a few percent of per-phase current imbalance. Just take the average of the 3.
Power for a 3-ph motor = V(line-line) x I(per-phase avg) x 1.732(root of 3) x PF
PF is power-factor, which is the cosine of the phase angle between the applied voltage and the phase currents. For a small AC 3-ph motor, this will be between 0.75 and 0.90, depending on the load. The motor's full-load PF should be printed on the name-plate.
M
Taking the average is okay, but I generally like to consider the highest reading when sizing components (wire, contactor, fuses, etc.). As things get older and worn (contact resistance, connection torque, insulation breakdown, etc.), they are likely to cause higher current in the motor, so I'd rather oversize a bit anyway. In most cases the average reading and the highest reading will yield the same results as far as component sizing, but when those results are "on the line" between one size and the next, I'd use "the next."
Note that more than a few percent (>5% roughly) of imbalance generally is unacceptable, and indicates a possible problem (especially in a new motor). Sometimes this can be due to an unbalanced voltage and rotating the motor wires may "even things out."
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 20 ·
