Change in electric field of charged particle
The discussion revolves around the effects of a charged particle's motion on its electric field, particularly as its velocity approaches the speed of light. Participants explore the relationship between electric and magnetic fields in the context of relativistic physics, addressing both theoretical and conceptual aspects.
  • Some participants assert that at velocities much less than the speed of light, the electric field remains largely unchanged, while at relativistic speeds, the electric field transforms into a magnetic field.
  • Others argue that while the magnetic field strength increases, the relationship between electric and magnetic fields is governed by constants, with the electric field always being greater than the magnetic field in magnitude.
  • A participant mentions that the transverse electric field is multiplied by a factor of γ as velocity approaches c, while the longitudinal component remains unchanged.
  • There is a discussion about whether the formation of the magnetic field affects the magnitude of the electric field, with some participants suggesting that they are independent, while others clarify that they are related through specific equations.
  • One participant highlights that the electric field's configuration changes, becoming a flat disc normal to the velocity of the charged particle at relativistic speeds.
  • Another participant notes that the forces generated by the electric and magnetic fields depend on different factors, emphasizing that the electric field's force is always greater than that of the magnetic field for a charged particle moving at subluminal speeds.
Participants express differing views on the relationship between electric and magnetic fields, with some asserting independence while others highlight their interdependence. The discussion remains unresolved regarding the exact nature of these relationships at relativistic speeds.
Limitations include assumptions about the constancy of velocity and the specific conditions under which the electric and magnetic fields are analyzed. The discussion references Lorentz transformations and specific equations from electromagnetic theory without resolving the complexities involved.
arul_k
It is known that the motion of a charged particle creats a magnetic field and also at speeds approaching c there will be an increase in its relativistic mass, but what effect does motion of a charged particle have on the magnitude of its electric field (Couloumb force). From what I know at velocities much less than c there appears to be no effect on the magnitude of the electric field but as its velocity approaches c the entire electric field converts to a magnetic field. Is this correct?
Hi arul_k! :smile:
Not quite …
the magnetic field becomes stronger, but E2 - B2 is a constant, and since it starts positive, it stays there, and |E| is always greater than |B|.
(also, E.B is constant, and it starts zero, so E and B are always perpendicular)
You might find it helpful to index "the fields of a point charge moving with constant velocity" (or something to that effect) in an EM text or two. Yes, assuming the charge's velocity is constant, E differs little from the electrostatic field when v<<c. At speeds approaching c, E increases "to the sides" of the moving charge. And of course there is a magnetic field when the charge moves. As v approaches c, E and B "to the sides" approach infinity! If you own or can borrow a copy of "Introduction to Electrodynamics", 2nd Edition, David J. Griffiths, then the exact formula for E is provided in Eq. 10.103.
Thanks for the replies. Would it be right to say that the magnitude of E has no relation to the formation of the magnetic field of a moving charged particle i.e the magnitude of E and B are independent of each other.
No, that would not be right. For a charge moving with constant velocity, B is related to E by B = v X E / c^2, where v is the charge's velocity.
Right, I didn't quiet word my question correctly, what I wished to ask was does the creation of the magnetic field result in a change in the magnitude of the electric field of the charged particle.
tiny-tim said:
Hi arul_k! :smile:
Not quite …
When you say that E is greater than B do you mean that the force generated by the E field i s greater than that of the B field
If you look at the Lorentz transformation of fields in the LBL PDG website (see last fourl ines):
http://pdg.lbl.gov/2009/reviews/rpp2009-rev-electromag-relations.pdf
you will see (from the second of the four equations) that the transverse electric field is increased by a factor γ, while the longitudinal field is unchanged. What is not shown is that the relativistic contraction of longitudinal length causes angles to increase, and this in turn compresses the transverse electric field from isotropic (for a stationary charge) to a purely transverse electric field with an opening angle of 1/γ.
For a particle traveling in the direction x, an angle θ transforms as
tan θ' = tan y'/x'= tan γθ = tan γy/x
Thus at very relativistic velocities, the electric field is a flat disc normal to the velocity.
Bob S.
[added] Although it may be counter-intuitive, a relativistic charged particle does not "drag" the electric field like a shock wave. The peak electric field is at right angles to the velocity, as seen above. If the electric field were dragged, then the Poynting vector would imply that the charged particle were losing (or radiating) energy, which is not the case with a constant velocity particle in free space. In the case of a relativistic charged particle inside a vacuum tube, there are image currents in the vacuum conducting tube wall. If the vacuum tube wall is resistive, there is power loss in the vacuum tube wall, and the electric field is dragged, meaning that the Poynting vector is pointing outward (as it must)
If there is no magnetic field B in the unprimed system, then the electric field is exactly as I described above. The electric field in the unprimed system does produce a transverse magnetic field in the primed system, but that was not part of your question.
Yes …
the strength of the E field is greater than that of the B field,
but the forces are qE and qvxB/c, where v is the velocity of the particle, and c is the speed of light …
so the force generated by the E field depends only on the charge of the particle, but the force generated by the B field depends also on the speed and direction of the particle, but since v/c must be < 1, |qE| is always greater than |qvxB/c|. :smile:
  • · Replies 22 ·
