What is the solution to the differential equation dy/dx=(y-y2)/x for x≠0?
The discussion revolves around solving the differential equation dy/dx=(y-y²)/x for x≠0. Participants are exploring various methods for integration and discussing the implications of their approaches.
  • Mixed
  • Some participants attempt to solve the equation using integration by parts, while others suggest using partial fractions for the integral. There are also questions about the validity of certain derivatives and integrals related to logarithmic functions.
The conversation includes attempts to clarify misunderstandings regarding derivatives and integrals, with some participants providing corrections and confirmations. Multiple methods for approaching the problem are being discussed, but no consensus has been reached on a specific solution.
Participants are grappling with the integration techniques and the relationships between derivatives and integrals, indicating a potential confusion in foundational concepts that may affect their approach to the differential equation.
mmekosh
Solve the differential equation: dy/dx=(y-y2)/x , for all x[tex]\neq[/tex] 0
Integration by Parts: [tex]\int[/tex] u dv = u v - [tex]\int[/tex] v du
[tex]\int[/tex]lnx= 1/x + C
[tex]\int[/tex] (1/x) = lnx + C
dy/dx lnx = 1/x
dy/dx 1/x = lnx
dy/(y-y2)=dx/x
[tex]\int[/tex] 1/(y-y2) dy = [tex]\int[/tex] 1/x dx
[tex]\int[/tex] (1/y)(1/(1-y))dy = lnx + C
(Integration by parts)
u=1/x dv=(1/(1-y))dy
du=lnydy v= -ln(1-y)dy
-lny / y + [tex]\int[/tex] lny ln(1-y) dy
And then if I continue and do integration by parts again, it just goes back to the original integral.
Instead of trying to do this by integration by parts, use the technique of partial fractions. In a nutshell you want to rewrite your integral on the left side:
[tex]\int \frac{dy}{y(1 - y)}[/tex]
with the fraction broken up into two separate fractions, like so:
[tex]\int \left[\frac{A}{y} + \frac{B}{1 - y}\right]dy[/tex]
What you need to do is to find constants A and B so that 1/(y(1 - y)) is identically equal to A/y + B/(1 - y).
dy/dx lnx = 1/x
dy/dx 1/x = lnx
Hello!
I don't mean to butt in, but can someone verify that:
[tex]\frac{d}{dx}(\frac{1}{x}) = \ln{x}?[/tex]
Also, the integral:
[tex]\int{\ln{x}} \left \left dx = \frac{1}{x}?[/tex]
I'm confused...
Many thanks.
nobahar said:
Hello!
Also, the integral:
I'm confused...
Many thanks.
I think you've confused the concept of integral with that of derivative as
[tex]\frac{d}{dx}(\ln(x)) = \frac{1}{x}[/tex]
[tex]\int{\frac{1}{x}} \left \left dx = \ln(x)+C[/tex].
And yeah both are correct.
AB
nobahar said:
Hello!
No, no one can verify that- it's not true. What is true is that
[tex]\frac{d}{dx}(\frac{1}{x})= -\frac{1}{x^2}[/tex]
because [itex]\frac{1}{x}= x^{-1}[/itex] and the derivative of [itex]x^n[/itex] is [itex]nx^{n-1}[/itex].
Also, the integral:
I'm confused...
Many thanks.
No, that's also not true. [itex]\int ln(x) dx= ln(x)(x- 1)+ C[/itex]
You have these both backwards: [itex]d(ln(x))/dx= 1/x[/itex] and [itex]\int 1/x dx= ln(x)+ C[/itex].
Thanks both Altabeh and Halls.
I didn't consider them to be true, hence why I said I was confused. It was from the OP's relevant equations section.
