Orion1
- 961
- 3
I attempted to use the Maple 13 'tensor' package to solve the [itex]G_{rr}[/tex] component of the Einstein_tensor for a General Relativity generic metric for which the solution is already known.<br /> <br /> General Relativity generic metric: (reference 2 - eq. 1)<br /> [tex]c^{2} d\tau^{2} = e^{\nu(r)} dt^{2} - e^{\lambda(r)} dr^{2} - r^2 d\theta^{2} - r^2 \sin^2 \theta d\phi^2[/tex]<br /> <br /> I used the exact same source code listed in the Maple 13 software help index and reference 1, except the definitions of the [tex]g_{11}[/tex] and [tex]g_{22}[/tex] matrix elements.<br /> <div class="bbCodeBlock bbCodeBlock--screenLimited bbCodeBlock--code"> <div class="bbCodeBlock-title"> <i class="fa--xf fal fa-code "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1780853889#code"></use></svg></i> Code: </div> <div class="bbCodeBlock-content" dir="ltr"> <pre class="bbCodeCode" dir="ltr" data-xf-init="code-block" data-lang=""><code>> with(tensor); coord := [t, r, th, ph]; g_compts := array(symmetric, sparse, 1 .. 4, 1 .. 4); g_compts[1, 1] := exp(nu(r)); g_compts[2, 2] := -exp(lambda(r)); g_compts[3, 3] := -r^2; g_compts[4, 4] := -r^2*sin(th)^2; g := create([-1, -1], eval(g_compts)); ginv := invert(g, 'detg'); D1g := d1metric(g, coord); D2g := d2metric(D1g, coord); Cf1 := Christoffel1(D1g); RMN := Riemann(ginv, D2g, Cf1); RICCI := Ricci(ginv, RMN); RS := Ricciscalar(ginv, RICCI); Estn := Einstein(g, RICCI, RS)</code></pre> </div> </div><br /> The Maple 13 'tensor' package generated this solution for the [itex]G_{rr}[/itex] component:<br /> [tex]G_{rr} = \frac{- r \nu'(r) + e^{\lambda(r)} - 1}{r^2}[/tex]<br /> <br /> However, the correct solution is: (reference 2 - eq. 4) <br /> [tex]G_{rr} = \frac{e^{-\lambda(r)} (-r \nu'(r) + e^{\lambda(r)} - 1)}{r^2}[/tex]<br /> <br /> Can anyone here identify any algorithmic error in my source code?<br /> [/Color]<br /> Reference:<br /> <a href="http://www.maplesoft.com/support/help/AddOns/view.aspx?path=tensor/Einstein"" target="_blank" class="link link--external" rel="nofollow ugc noopener">http://www.maplesoft.com/support/help/AddOns/view.aspx?path=tensor/Einstein"</a><br /> "www.new.dli.ernet.in/rawdataupload/upload/insa/INSA_2/20005a87_195.pdf"[/URL][/itex]
