Improving MPG with hydrogen/oxygen
  • Context: Undergrad
  • Thread starter Thread starter Razzor7
The discussion centers on the feasibility of using hydrogen and oxygen generated through hydrolysis to improve gas mileage in vehicles. Participants conclude that while devices exist to inject these gases into engines, the energy required for hydrolysis exceeds the energy gained from combustion, resulting in no net benefit. The primary advantage noted is improved driving habits rather than the hydrolysis process itself, which does not contribute to enhanced fuel efficiency.
  • Understanding of hydrolysis and its energy requirements
  • Knowledge of internal combustion engine mechanics
  • Familiarity with fuel combustion processes
  • Basic principles of energy conservation
  • Research the impact of hydrogen injection on gasoline combustion efficiency
  • Explore alternative fuel technologies for improving gas mileage
  • Study driving behavior modifications that enhance fuel efficiency
  • Investigate the thermodynamics of hydrolysis and energy loss in fuel systems
Automotive engineers, fuel efficiency researchers, and anyone interested in alternative fuel technologies and their impact on gas mileage.
Razzor7
If you use the alternator to hydrolysis water and then run the oxygen/hydrogen into the engine, is there any way for this to improve your gas mileage? I know that many such devices exist, but on the surface it appears that energy must be lost. Energy from the gasoline is hydrolyzing the water, and then energy is regained from these byproducts of hydrolysis. But this amount of energy must be less than the original input. The only alternate I can imagine is that a combination of hydrogen and gasoline in the engine causes the gasoline to burn more effectively, creating a net MPG benefit.
Precisely.
The injection of hydrogen is very small, and the primary effect is to improve your driving habits, with the result that you may get better mpg.
Bob S
No
Correct
Also correct
The only alternative is that they are a con
  • · Replies 77 ·
44K
47K
32K
