Thread Closed
Heat Current Problem
Share Thread Thread Tools
Jan22-10, 01:43 PM   #1
Rods of copper, brass, and steel are welded together to form a Y-shaped figure. The cross-sectional area of each rod is 2.00 cm^2. The free end of the copper rod is maintained at 100.0 degrees C, and the free ends of the brass and steel rods at 0.0 degrees C. Assume there is no heat loss from the surfaces of the rods. The lengths of the rods are: copper, 13.0 cm; brass, 18.0 cm; steel, 24.0 cm
What is the temperature at the junction?
2. Relevant equations
H = kA(T[hot]-T[cold]) / L
Where H is the heat current, k is the materials thermal conductivity, A is the cross-sectional area,
T[hot]-T[cold] / L is the temperature gradient. (change in temp divided by length).
3. The attempt at a solution
I can solve these types of questions with only 2 bars. What I would do is plug in the values for each material into the heat current formula , make them equal each other, then solve for T at the junction. This method won't work for 3 materials coming together. Please help! Thanks.
[Edit] I'm sorry for posting this in the advanced physics thread it was supposed to be in introductory. If any mod sees this they can move it, thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Jan24-10, 07:07 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Can you show where you're getting stuck? It looks like you're going to have four equations and four unknowns.
Thread Closed
Thread Tools
Similar Threads for: Heat Current Problem
Thread Forum Replies
pulsating LED to increase current but keep heat down. Electrical Engineering 9
Heat and electric current Introductory Physics Homework 1
Thermal Properties/Heat Current Introductory Physics Homework 0
Heat current through a spherical shell Introductory Physics Homework 2
Current to heat relation for a wire General Physics 2
