Quick question on explaining the law of conservation of momentum.
The discussion centers on calculating the impulse acting on a booster unit after an explosion separates it from a space vehicle. The space vehicle, weighing 7.3 x 10^3 kg, and the booster unit, weighing 6.8 x 10^2 kg, initially move at 370 m/s. After the explosion, the space vehicle's speed increases to 430 m/s. The impulse exerted on the booster unit can be derived using the principle of conservation of momentum, which states that the total momentum in a closed system remains constant. The impulse on the booster unit is equal in magnitude and opposite in direction to the impulse on the space vehicle, as dictated by Newton's third law.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of impulse and momentum
  • Knowledge of closed systems in physics
  • Ability to perform calculations involving mass and velocity
  • Study the derivation of the impulse-momentum theorem
  • Explore examples of closed systems in physics
  • Learn about the implications of Newton's third law in various scenarios
  • Investigate the effects of explosions on momentum in real-world applications
Students of physics, educators teaching mechanics, and anyone interested in understanding the principles of momentum and impulse in closed systems.
Senjai
I have done the question already and attained the correct answer. However if it was a written question i do not know how i could prove the following.
A 7.3 x 10^3 kg space vehicle and its empty 6.8 x 10^2 booster unit are moving together through space at 370 m/s. An explosion lasting 2.2s is used to separate the two parts. If the speed of the space vehicle is increased to 430 m/s, what impulse acted on the booster unit?
I used the Impulse formula [tex]I_{space vehicle} = \Delta{p}[/tex]
And used the change of momentum of the space vehicle to determine the Impulse exerted on it. How would i prove that this impulse is the same in magnitude and opposite in direction as the impulse exerted on the booster unit?
Is their a way to do this question a different way? Did they give the time for no reason?
Regards, Senjai.
The space vehicle, the booster unit together with the explosive constitute a closed system in the far space. Only forces of interaction act among them. According to Newton's third law, if a body "1" acts with force F12 on an other body "2" this other one acts with force F21=-F12 force on the first one.
The momentum is [itex]I=F\Delta t[/itex]. The sum of the forces of interaction is F12+F21=0, therefore [itex]I=F_{12}\Delta t+F_{21}\Delta t=0 \rightarrow I_1+I_2=0[/itex]
The change of momentum is equal to the impulse. When only two bodies are interacting [itex]\Delta p_1+\Delta p_2=0[/itex]
The sum of forces in a closed system is 0. So is the overall change of momentum.
The vehicle and booster are separated by an explosion, but we can assume that no momentum is wasted, or this waste (the momentum of escaping particles of the explosive) is negligible -we have only two interacting bodies.
ehild
Thank you so much :P Appreciate it :)
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 20 ·
