Equilibrium heat equation in 2D cylindrical coordinates
The discussion focuses on solving the equilibrium heat equation in 2D cylindrical coordinates for a circular halo plate with inner radius a and outer radius b, where the inner edge is maintained at a constant temperature T_0 and the outer edge follows the function f(φ) = T_0 cos(2φ). The solution involves separating variables and solving the Laplace equation, resulting in a general solution expressed as a superposition of two parts: u(r, φ) = C ln(r) + D + Σ (r^m[A_m cos(mφ) + B_m sin(mφ)]) + Σ (r^(-m)[C_m cos(mφ) + D_m sin(mφ)]). The challenge lies in determining the coefficients A_m, B_m, C_m, and D_m using Fourier summation techniques.
  • Understanding of Laplace's equation in cylindrical coordinates
  • Familiarity with separation of variables technique
  • Knowledge of Fourier series and their application in boundary value problems
  • Basic concepts of harmonic functions and boundary conditions
  • Study the application of Fourier series in solving boundary value problems
  • Learn about the method of separation of variables in cylindrical coordinates
  • Explore the properties of harmonic functions and their solutions
  • Investigate specific examples of Laplace's equation in cylindrical geometries
Students and professionals in applied mathematics, physics, and engineering, particularly those dealing with heat transfer and boundary value problems in cylindrical coordinates.
dingo_d
Plate in the shape of the circular halo (inner radius a, outer radius b>a), the inner edge is being kept at a constant temperature [tex]T_0[/tex], and the outer at the temperature given by the function [tex]f(\phi)=T_0\cos(2\phi)[/tex]. Find the equilibrium distribution of the heat everywhere inside the plate.
Laplace equation:
[tex]\nabla^2 u(r,\phi)=0[/tex]
Boundary conditions:
[tex]u(a,\phi)=T_0[/tex]
[tex]u(b,\phi)=T_0\cos(2\phi)[/tex]
By separation of variables I get:
[tex]r^2\frac{R''}{R}+r\frac{R'}{R}=-\frac{\Phi''}{\Phi}=\lambda^2[/tex]
For [tex]\lambda\neq 0[/tex] I have 2 DE, one is Euler's DE, and the other the equation of harmonic oscillator. Their solution is:
[tex]R(r)=Ar^\lambda+Br^{-\lambda}[/tex]
[tex]\Phi(\phi)=C\cos(\lambda\phi)+D\sin(\lambda\phi)[/tex]
With the condition of consistency of the azimuthal part:
[tex]\Phi(\phi)=\Phi(\phi+2\pi)[/tex]
I get that [tex]\lambda=m\in\mathbb{Z}[/tex], the [tex]\lambda=0[/tex] gives different solutions.
So my first solution is:
[tex]u_1(r,\phi)=\sum_{m=1}^\infty r^m[A_m\cos(m\phi)+B_m\sin(m\phi)]+\sum_{m=1}^\infty r^{-m}[C_m\cos(m\phi)+D_m\sin(m\phi)][/tex]
For [tex]\lambda=0[/tex] I have these solutions:
[tex]R(r)=C_0\ln(r)+D_0[/tex]
[tex]\Phi(\phi)=A_0\phi+B_0[/tex]
With the condition of consistency I get:
[tex]A_0\phi+B_0=A_0\phi+A_02\pi+B_0\Rightarrow A_0=0[/tex]
So the second solution is: (I have put the constants together)
[tex]u_2(r\phi)=C\ln(r)+D[/tex]
The general solution is the superposition of the two solutions:
[tex]u(r,\phi)=C\ln(r)+D+\sum_{m=1}^\infty r^m[A_m\cos(m\phi)+B_m\sin(m\phi)]+\sum_{m=1}^\infty r^{-m}[C_m\cos(m\phi)+D_m\sin(m\phi)][/tex]
So here is where my problem starts. I know that I'm supposed to use formulas for Fourier summation but in the case of a string that was the more straightforward, for example:
[tex]f(x,0)=\sum_{m=0}^\infty A_m\sin\left(\frac{m\pi}{L}x\right)\Big/ \cdot \sin\left(\frac{n\pi}{L}x\right),\ \int_0^L dx[/tex]
And the integral on the right would give me Kronecker delta which would 'kill' the sum so I would get the [tex]A_n[/tex] from that. But here I don't have this simple way. How should I get the [tex]A_m,\ B_m,\ C_m,\ D_m[/tex]?
Use the same procedure for [tex]r=a[/tex] and [tex]r=b[/tex], multiplying your solution by [tex]sin(n\phi)[/tex] and [tex]cos(n\phi)[/tex]. You will get equations for the unknown coefficients.
  • · Replies 19 ·
  • · Replies 46 ·
