| Thread Closed |
pH Buffer solution |
Share Thread |
| Jan26-10, 02:45 PM | #1 |
pH Buffer solution
I have no idea how to find the pH of a buffer solution:
Please step by step! Calculate the pH after 0.020 mol NaOH is added to 1.00 L of: a mixture containing 0.100 M HONH2 and 0.100 M HONH3Cl please step by step instruction so I can follow and do other problems on my own! Thanks |
| Jan26-10, 02:50 PM | #2 |
its been a while but dont you just find the moles of each. then find out how many OH or H you have and find the ph like that? or was that not buffer?
| Jan26-10, 03:29 PM | #3 |
i don't believe that's how you do it
| Jan26-10, 04:06 PM | #4 |
Admin
pH Buffer solution
One of the substances listed reacts with NaOH. Assume reaction is quantitative, then it is just Henderson-Hasselbalch equation.
-- buffer calculator, concentration calculator pH calculator, stoichiometry calculator |
| Jan26-10, 04:33 PM | #5 |
would the answer be 6.18?
| Jan26-10, 05:00 PM | #6 |
ahhh the henderson hasslebach i remember that one. Yeah you just have to use that equation with the mols of acid and base taht you have.
| Jan26-10, 05:06 PM | #7 |
Admin
Depends on what value you have used for pKa. Correct ball park for sure.
| Thread Closed |
| Tags |
| buffer, ph value |
Similar discussions for: pH Buffer solution
| How to determine if the mixing of two solution would result in buffer solution? | Biology, Chemistry & Other Homework | 3 | ||
| ph of buffer solution | Biology, Chemistry & Other Homework | 2 | ||
| pH of buffer solution | Biology, Chemistry & Other Homework | 5 | ||
| pH of buffer solution | Biology, Chemistry & Other Homework | 2 | ||
| pH of a buffer solution | Biology, Chemistry & Other Homework | 2 | ||
