Thread Closed
Difference between fractal dimension determined by surface profilometry and Hg poros.
Share Thread Thread Tools
Jan26-10, 03:58 PM   #1
What is the difference between fractal dimension determined by surface profilometry and Hg porosimetry?
For example, for a given dataset, say samples 1-5, the backbone fractal dimension determined by Hg porosimetry increases from 2.5 to 3 (the percolation fractality is 3 for all samples).
For Surface profilometry determined on a 2D surface (not a line!) with z as the third dimension, the data is exactly inversed, it decreases from 3 to 2.5
(see example data below)
Why?
What is the difference between the two methods?
thanks.
Data# Hg Profilom.
1 2.5 3
2 2.6 2.9
3 2.7 2.8
4 2.8 2.7
5 2.9 2.5
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Jan29-10, 02:05 PM   #2
Perhaps I am missing something...but those experiments don't measure the same thing. Profilometry will give you a wet blanket approximation of the surface. It has no information about the internal structure or surface area under the measured hyperplane. Porosimetry basically gives the opposite result in high surface area materials...it gives most of the internal surfaces but no relational geometry....the total geometry is realized by putting Both of the datasets together.
Jan29-10, 02:15 PM   #3
Thanks for your reply.
Thant might be it.
I also thought that one output is the outer blanket, and the other the internal structure, but outer or inner surface would have the same characteristics, no?
Anyways, your explanation might explain why they don't correlate linearly, but with inversely.
Thx.
Thread Closed
Tags
fractal dimension, mercury porosimetry, surface profilometry
Thread Tools
Similar Threads for: Difference between fractal dimension determined by surface profilometry and Hg poros.
Thread Forum Replies
Dimension and basis for subspace determined by given vectors Calculus & Beyond Homework 2
Difference between dimension and rank Linear & Abstract Algebra 4
Fractal dimension of CMBR? Cluster distribution? Special & General Relativity 2
Dimension of fractal object General Math 2
How is reflectivity of a surface determined? Atomic, Solid State, Comp. Physics 9
