Understanding Particle Energies in Ohanian's Book: A Potential Problem Explored
  • Context: Graduate
  • Thread starter Thread starter vin300
    Potential
The discussion centers on the concept of particle energies as presented in Ohanian's book, specifically the separation of energies into kinetic and rest mass components. It is established that the total mass of a bound system is less than the sum of the particle rest masses due to the presence of a "mass deficit," which is directly related to the binding energy. The binding energy is defined as the energy required to separate particles in a bound system, and its removal results in a decrease in total mass. The inclusion of the four-momentum of the binding energy resolves any discrepancies in the energy-momentum four-vector.
  • Understanding of kinetic and rest mass energies
  • Familiarity with the concept of binding energy
  • Knowledge of energy-momentum four-vectors
  • Basic principles of relativistic physics
  • Study the concept of mass deficit in nuclear physics
  • Learn about binding energy calculations in particle systems
  • Explore the implications of energy-momentum four-vectors in relativistic mechanics
  • Investigate the relationship between energy and mass in the context of Einstein's theory
Physicists, students of theoretical physics, and anyone interested in the principles of energy and mass in relativistic systems will benefit from this discussion.
vin300
I saw today in Ohanian's book:
"It is convenient to separate particle energies into kinetic and rest mass energies:
M=∑m +(∑T/c^2 +U/c^2)
The term in the paranthesis is negative for a bound system,hence the total mass is less than the sum of the particle rest masses"
I thought the rest masses were indeed less.If it is otherwise, there's a problem with the Energy momentum four vector
M=?m +(?T/c^2 +U/c^2)
This is correct. The "missing" mass is called the "mass deficit" and that mass/c^2 is called the "binding energy". Note, the mass deficit only appears when the binding energy has been removed from the system, usually either through radiation or through doing work on another system.
The problem goes away if you include the four-momentum of the binding energy which left the system.
  • · Replies 55 ·
  • · Replies 62 ·
