Can the de broglie formula still hold in a medium with reduced speed of light?
  • Context: Graduate
  • Thread starter Thread starter Andeplane
    Medium Photons
The discussion revolves around the applicability of the de Broglie formula in a medium where the speed of light is reduced compared to vacuum. Participants explore the implications of light's behavior in different media, particularly focusing on momentum and wavelength changes as light transitions between vacuum and a medium.
  • One participant questions whether the de Broglie formula holds in non-vacuum materials, noting that as the speed of light decreases, the wavelength decreases, which would imply an increase in momentum that could reach infinity if the speed of light approaches zero.
  • Another participant suggests that the reduced speed of light is an apparent effect due to collisions (absorption and re-emission), asserting that light travels at speed c at all times when it is actually moving.
  • A different viewpoint compares the momentum changes of light entering and exiting a medium to a comet's momentum changes as it approaches and leaves the sun, indicating that the momentum's inverse relationship to velocity is due to conventions in energy definitions.
  • One participant introduces an analogy from solid state physics, discussing how electrons exhibit different effective masses in various semiconductors, suggesting a parallel to how light behaves in different media.
Participants express differing views on whether the de Broglie formula is applicable in media with reduced speed of light, with no consensus reached on the matter. Some agree on the behavior of momentum in different contexts, while others challenge the implications of reduced speed on the formula.
Participants reference different conventions and interpretations regarding energy and momentum, indicating that assumptions about the nature of light and its interactions in media may vary. The discussion does not resolve these assumptions or clarify the mathematical implications fully.
Andeplane
Hi, I was discussing a question with a Ph.D-student at my uni that neither him or the professor were able to answer.
The situation is the following;
Light enters a medium going from i.e. vacuum. We know that the energy of the photons in the vacuum is
[tex]E = h\nu[/tex]
and we have the de broglie formula
[tex]p = \frac{h}{\lambda}[/tex]
The relation [tex]c=\lambda\nu[\tex] tells us that the wavelength [tex]\lambda[\tex] decreases if the speed of light decreases (since frequency is constant). Does the de broglie formula still hold now? In that case, the momentum increases as the wavelength decreases, eventually reaches infinity when the speed of light goes to zero.<br /> <br /> In my eyes, this cannot be true, so the de broglie formula cannot hold for reduced speed of light (also remember that when the light goes out of the medium again, the speed and hence the momentum is back to 'normal' again.<br /> <br /> If we look at the particle interpretation of light, the photon will probably hit electrons and excite them and quickly send a new photon again. The reduced speed of light might be a consequence of many collisions. <br /> <br /> The problem isn't quite clear, but the de broglie formula, does it hold in non-vacuum material?[/tex][/tex]
The reduced speed of light is only an apparent effect of the collisions (absorptions and re-emissions). At any time the light is actually traveling, it's traveling at c, I believe.
No, that's all ok. That the momentum changes when entering the medium is not astonishing and that it goes back to the value before entering the medium when leaving isn't either. Thats analogous to a comet approaching the sun where its momentum increases and decreases again when leaving the sun. The only astonishing point is that the momentum is inversely proportional to velocity, but that is more due to different conventions on the zero point of energy in relativistic and non-relativistic problems.
The FAQ at the top of the General Physics forum has an entry that addresses photons and light in a medium.
An even better analogy from solid state physics: Electrons have different "effective" masses in different semiconductors. This effective masses are due to the electrons carrying with them a polarization cloud of different size in the different media.
We now can think of an electron changing from one semiconductor to another without change of energy: p^2/2m will remain constant but m will change. That means that p1/p2=sqrt(m1/m2) but v1/v2=sqrt(m2/m1), so in one medium the electrons have a higher momentum but are slower.
The analogy is probably very close as both the optical polarization and the mass of the electrons are in both cases given as the omega dependent terms of the self energy.
  • · Replies 0 ·
  • · Replies 28 ·
  • · Replies 46 ·
  • · Replies 17 ·
  • · Replies 18 ·
