What to do if your car accelerates out of control
  • Thread starter Thread starter edward
    Car Control
The discussion revolves around the issue of cars accelerating out of control, particularly in the context of newer vehicles with electronic throttle control systems. Participants explore various factors that may contribute to this phenomenon, including mechanical failures, sensor issues, and driver responses in emergency situations. The conversation includes both theoretical considerations and practical advice for handling such scenarios.
  • Some participants suggest that newer cars can overpower brakes due to engine power, while others contest this by stating that brakes are generally stronger than the engine under normal conditions.
  • There are concerns about the reliability of throttle position sensors (TPS) and their potential failure leading to erratic vehicle behavior, such as over-rich or over-lean operation.
  • One participant shares a personal anecdote about a tragic incident involving sudden acceleration, highlighting the real-world implications of the issue.
  • Several participants discuss the logic behind not turning off the engine during an acceleration event, with some advocating for maintaining control over steering and brakes.
  • There is mention of a specific incident captured in a video where a driver struggles to stop a vehicle at full throttle, raising questions about the effectiveness of braking systems in such situations.
  • Participants express uncertainty about the mechanics of ignition systems and their impact on steering lock during emergencies, with some sharing personal experiences with different vehicle models.
Participants express a mix of agreement and disagreement regarding the mechanics of vehicle acceleration and braking. While some points are clarified, there remains no consensus on the effectiveness of various emergency responses or the underlying causes of the acceleration issue.
Limitations include varying experiences with different vehicle models, the complexity of electronic systems, and the potential for miscommunication regarding emergency procedures. Some assumptions about driver behavior in emergencies are not universally applicable.
This discussion may be of interest to automotive enthusiasts, drivers concerned about vehicle safety, and individuals looking to understand the implications of electronic throttle control systems.
edward
Many newer cars have engines that can over power the brakes. Don't pump the brakes. Don't turn off the ignition. Hit the brakes and shift to neutral.
Sounds easy but is it? Practice it first in a safe area according to Consumer Reports
I understand that the Toyota's involved in the big recall use drive by wire accelerator control. There is no longer a direct mechanical linkage to the engine.
I have had a gut feeling for some time that there may be more than just a carpet problem.
Even when there is a direct throttle linkage, many things can happen when sensors fail. Lots of vehicles with direct linkages rely on throttle position sensors to to tell the fuel and ignition systems what to do. If the TPS fails, you could have over-rich or over-lean operation, stumbling on acceleration (it feels like water in the fuel system), high or low shift points, or surging at highway speeds, among other things.
Putting the car in neutral helps in icy conditions too--well, it for me (rear wheel drive) when starting to slide. Its seems to help the car straighten out.
Weird, my car seems to accelerate out of control all the time. . .
No, few, if any, do. Any car can hit the brakes hard enough to skid at virtually any speed, but unless you have a sports car, the only time you can overcome the static friction of the tires with the engine is when revving the engine and popping the clutch in first gear. Otherwise, the brakes are much stronger than the engine.
Anyway, what is the logic for not turning off the engine? I'd rather slow to a stop without power steering or brakes than risk damaging the engine with a runaway throttle and no load.
Reminds me of the woman that lived across the street from me when I was little. She had a new Ford, and had just backed out into the street, then when she applied the gas pedal, it went all the way down and she ended up running into a huge tree in her front yard and died. Right in front of her family. My mother wouldn't let me go outside.
Look at the video. The guy can not stop it at full throttle because the transmission shifts down to lower gears as the brakes try to slow down the vehicle. Anti lock brakes do not skid.
I would probably do it the same way you would. Not shutting off the engine was recommended by Consumer Reports. Turning the key to far in the off direction would lock up the steering entirely.
The car the guy was driving in the video couldn't be shut off at road speed. Then he realized that the button had to be pushed in for three seconds.
Sirens go all night here at first freeze every fall.
My advice: Try to minimize acceleration; that is, try to minimize breaking, gassing, and turning so you can regain the friction bond between tire and road. Of course, you want to turn your wheels into the slide so they're rotation is aligned with the direction of motion (again increasing the chance of regaining the static friction bond). You don't want to slam on the breaks because then you lose all chances of friction regaining a static case.
I have had all kinds of weird sensor problems over the years. Most of them will cause a check engine light to come on or leave a code in the CPU.
The worst thing I had happen was to have a throttle body shaft break and leave the butterfly valve stuck half way open.
I haven't had a vehicle that allows the ignition to be turned off to the point where the steering wheel locks up unless the vehcile is in park or if it is a stick-shift, there is a small lever on the side of the steering column that has to be pushed to get the ignition switch to go to the point that the steering wheel locks.
That's morre or less (not exactly, though...) what he says, but the video shows the spedomeder needle going down when he does it.
Perhaps the problem they are really after is that the car doesn't decelerate fast enough when you just slam on the brakes?
Actually, they do, but that doesn't have anything to do with the point. You don't need to apply the brakes hard enough to skid in order to overcome the engine's torque.
True, but unless you have to make a new turn between the time you apply the brakes and the time you get to a complete stop, that doesn't hurt you any. We're only talking about up to 3 seconds, here.
Frankly, that was another part of the video I didn't like. I'd expect an engineer to be enough of a nerd to know that holding a power button for 3 seconds is the standard way to turn off any device with a multi-function power button (try it with your computer and your cell phone). It's the next thing that would come to mind for me while standing on the brakes and decelerating...
That's a good point and one I didn't think of. I had to go test it on my Mazda to be sure: you have to push the key in while turning to get to the last position. Trouble is, that fact is so burned into my subconscious that I do it all in one motion without thinking about it. In an emergency situation, I'm not sure if I'd do it or not.
You are right I wonder how Consumer Reports missed that, especially a test driver. I checked my Honda van, I can turn the key off in neutral but not to the point that it locks.
The recall goes back to the 2002 models. Did they have this safety feature??
So it would appear that only power steering would be lost. That might be difficult for some people to handle. I have actually experienced a sudden loss of power steering at road speed. I handled it OK but it was one heck of a surprise.
True but he could not get the vehicle to stop. The slower the vehicle goes the lower the gear that the tranny will shift into.
Perhaps the problem they are really after is that the car doesn't decelerate fast enough when you just slam on the brakes? Actually, they do, but that doesn't have anything to do with the point. You don't need to apply the brakes hard enough to skid in order to overcome the engine's torque.
Again at road speed anything that affects braking is too slow for safety
3 seconds From 80 mph ?? Not all of these incidents are in parking lots. At speed there is a lot of brake fade even with disk brakes when dragging against an open throttle.
I have a link somewhere showing a little 4 cylinder Chevy HHR that had brake fade before they could get it stopped under full throttle.
This three second thing is fairly new in vehicles and the directions are in the owners manual. The test driver did mention that and was aware of it.
I read my owners manual and I know you read yours but not everyone does. My wife can't even program the radio stations.
This weekend, my girlfriend's car was having trouble that caused it to stall out when trying to idle. It stalled when I was making a left turn in traffic, shifting from first to second. I didn't try to steer, kept going in the turn and popped the clutch when I dropped it into second and it started right back up.
Point being, it is important to be able to keep your head in trouble situations in a car. They aren't usually that bad if you just relax and take it slow.
Next up, we tried our Toyota Venza and Chevrolet HHR. Since these lacked smart-throttles, we proceeded more cautiously. So we decided to start this test by flooring the cars to 20 mph (instead of 60) and then slamming on the brakes. While we stopped both cars, the transmissions downshifted hard, trying to fight us on the way down, and we needed to exert quite a bit of brake pedal effort to stop completely. We then drove a lap around our test course to cool the brakes and repeated the procedure. This time we accelerated to 60 mph before we slammed on the brakes. Again, the engines downshifted and fought us all the way down. But by the time we slowed down to about 10 mph, the brakes had faded so much that we weren’t able to come to a complete stop. If the driver had less strength or was traveling at higher speeds, they would not be able to slow down nearly as much.
Verdict: Most people will likely have a tough time stopping a car using the brakes with a stuck throttle without a smart throttle.
http://blogs.consumerreports.org/cars/2009/10/toyota-recall-putting-stuck-floor-mat-survival-strategies-to-the-test.html
Yea but all people aren't as perfect as you and I and the PF'ers are Russ. o:)
We don't know any of that from watching the video - he didn't show it. I expect that the car will continue to downshift until it stalls out in first gear.
[edit: you found a link confirming what I said - a car will stop if the gas and brake are both pushed]
Ehh, I'm not really buying that. Why do you need to do a slam-on-the-brakes stop anyway? Heck, if this happens on a highway and you use his method, it just seems to me to be a good way to get rear-ended!
Obviously it depends on the speed you're going. From 80, it is probably around 6 seconds.
Yes, it is new - pusbutton starting is new. And yes, I read my manual, but heck, if a car had a new feature I'd never seen before, I'd hope everyone would read their manual!
In any case, my point is that there are an awful lot of people out there who would know intuitively that a 3 second hold is how to turn off a car with a power button(and certainly any young engineer should) . His characterization that this is some arcane knowledge is just plain inaccurate.
Heck, in normal everyday situations, how do you turn off the car? Is it different when it is moving than when it is in park?
Either way, 3 seconds is probably too long to wait for the car to shut off in some cases, so I might not be inclined to use that method for such a car.
Yes, that link confirms what I said in my first post: most cars will stop if you push both the gas and the brake to the floor. The brake is a lot stronger than the engine.
In the situation in the link below the driver actually made it to the Toyota dealership with engine still reving. Odd that they didn't find a fault code:confused:
Earlier this week, The Safety Record reported another Toyota SUA incident involving a 2007 Avalon and a New Jersey driver who managed to get his over-accelerating vehicle to the dealership with smoking brakes and an engine at full throttle. For those of you who missed it:
This owner had experienced several unintended acceleration incidents – incidents in which the vehicle accelerated without driver input. The most recent occurred on Dec. 29 as he drove on the highway. The man was unable to stop the vehicle with the brakes alone, but he was able to shift the vehicle into Neutral. As the engine continued to race to full-throttle, he immediately called the local Toyota dealer, about two miles away, to alert them he was bringing the vehicle to their lot. He drove the car to the dealer by shifting from Neutral to Drive, foot on the brake, with the engine at full throttle.
http://www.safetyresearch.net/2010/01/15/toyota-sudden-acceleration-in-reverse/
It depends on how much weight you can put on that brake pedal.
Regardless of the causes, these incidents of runaway vehicles underscore serious control issues plaguing Toyota’s brake and acceleration systems. In its most recent investigative report NHTSA’s Vehicle Research & Test Center found that drivers would have a difficult time reacting appropriately to an SUA event for three reasons: Many drivers did not know that depressing and holding the ignition button will eventually turn off the engine after three seconds; many complained that the neutral gear position in the gated shift pattern was not immediately obvious; with the throttle plate open, the vacuum power assist of the braking system cannot be replenished and the effectiveness of the brakes is reduced significantly and that brake pedal force in excess of 150 pounds was required to stop the vehicle, compared to 30 pounds required when the vehicle is operating normally.
http://www.safetyresearch.net/toyota-sudden-unintended-acceleration/
Edit: I haven't seen this website before so I can't vouch for its credibility. I'll check it out.
There was a relatively recent incident here in California where a family had their vehicle accelerate out of control apparently on a downhill grade that eventually took the car right into a brick wall at full speed. They all were believed to have died instantly upon impact. There was speculation that a known issue of the floor mat catching and holding down the accelerator was the cause of the accident.
They called 911 when they realized that they could not figure out how to stop the car and that it was headed for a T-intersection. They played the recording on the news. It was rather sad to listen to.
drive by wire has got to be the dumbest thing toyota has ever done. painfully stupid, really. at least with my mechanical linkages, I've got several tools at my disposal, and am unlikely to have everything fail at once. i can shift the transmission into neutral, depress the clutch pedal, apply the brakes, take my foot off the accelerator, AND i can still cut the power to the ignition and not lose steering.
it almost sounds as if they've either got one box controlling it all, or linked them in such a way as to override independence. if they had any sense at all, and were still determined to do this, then at least use a distributed control system and maybe even redundancies on those. geeze, i bet they run it on a microsoft OS, too.
Turning off the ignition while the car is moving is just a really bad idea, considering there's so many other less drastic options. You'll lose your power steering and you'll lose your power brakes.
Once in a while, you hear of some tourist that overheated his brakes coming down Pikes Peak that thought turning off the ignition on the way down a mountain was a good idea. The accounts of people driving up the mountain of a silent car rolling down the hill with little terrified faces pressed desperately against the window are just too poignant. You never get the account of the people that were actually in the car, since they inevitably miss a turn and roll 2 or 3 miles down the steep mountain side, scattering body parts all along the way. Well, almost like that.
Better options:
1) Surely your emergency brake is in proper operating condition. I know everyone, even those with automatic transmissions, religiously use these when they're parked and that everyone religiously washes the underside of their car, even in the winter.
2) Downshift. Even an automatic transmission has low gears.
3) Once the speed has decreased enough, you can put the car in neutral. Just wait until you're already going slow - the braking action of a lower gear would be preferable to neutral at higher speeds, since neutral won't actively slow you down.
4) If all else fails, shift into reverse. Your transmission and drive shaft will be totally and completely trashed, but it's still a better option than turning off the ignition.
Just another reason automatic transmissions should be banned. They automate things to the point that not only do drivers not bother to drive anymore, they don't even remember how.
Yep BOB G I Agree about the automatic transmissions, but a lot of people can't even dive a stick any more.
The new automatics have as many as six gears which makes the the braking even more difficult when trying to stop against the power of a wide open throttle from highway speed.
The transmissions keep shifting down to meet any load requirement.
The worst thing to do is to pump the bakes at wide open throttle because there is not enough engine vacuum to provide power brake boost.
The automotive grapevine indicates that Toyota will be installing a brake /accelerator
override on new vehicles.
The element of surprise at road speed can really magnify the results of any type of failure.
The In the San Diego situation where a family was killed the driver was a policeman.
[PLAIN]http://www.sandiego6.com/mostpopular/story/Santee-CHP-officer-Saylor-killed-Lexus-accelerator/AzYjOhtvFE2mIuxTtxrK4Q.cspx
Along with the tragedy this has turned out to be a financial disaster for Toyota employees.
My Honda van has an interlock that requires pulling the shifter back then forward and down to make a manual down shift. Ironically Honda's way of dealing with a weak transmission was to make downshifting difficult. My wife can't even figure it out.
  • · Replies 49 ·
9K
  • · Replies 39 ·
  • · Replies 136 ·
21K
126K
