Work Done By Friction on a Piston, and Change in Enthelpy
The discussion revolves around a physics assignment involving work done by friction on a piston and changes in specific enthalpy in a steam turbine system. The original poster presents two distinct problems related to thermodynamics and fluid mechanics, seeking assistance with calculations and conceptual understanding.
  • Mixed
  • The original poster attempts to calculate the dissipative work done on a system involving an ideal gas and a piston, questioning how to determine the distance moved by the piston given the change in volume and the area. They also express uncertainty about the integration of force over distance due to varying contact area.
  • In the second problem, the original poster seeks clarification on applying Bernoulli's equation to find the change in specific enthalpy, particularly when considering different velocities and elevations, noting discrepancies in their calculations.
  • Another participant suggests a method for calculating displacement based on the change in volume and area.
The discussion is ongoing, with participants exploring various interpretations and approaches to the problems presented. Some guidance has been offered regarding the calculation of displacement, but there is no explicit consensus on the methods to solve the original poster's questions.
The original poster is under a time constraint due to an impending assignment deadline, which may influence the urgency and nature of the questions being raised. There is also a mention of classmates engaging in light-hearted banter, indicating a collaborative yet informal atmosphere.
mmmboh
Hi, I have an assignment due tomorrow and have been working for hours and hours on it, and have done all of the questions pretty much, except for these 2 parts of questions, since it is due tomorrow morning if someone can help me out that would be great! Here they are:
1.Consider a system consisting of a cylinder containing 0.2 kilomoles of an ideal gas and fitted with a massless piston of area 0.5m2. The force of friction between the piston and the cylinder is 10 N. The gas is initially at a pressure of 1atm and the system is to be maintained at 300 K. The volume of the system is slowly decreases by 10 percent by an external force.
The question asks to find the configuration work done on the system, which I found, and it also asks to find the work done on the system by the external force and the dissipative work done on the system. I believe the work done on the system is the configuration work plus the dissipative work, but I can't figure out how to find the dissipative work. I know the force of friction, and I know W=FD, but we don't know the distance, but we know the new volume is 10% less, and I know the area...but this doesn't help with finding the distance since I don't know the height of the piston. Also I am not sure if I am suppose to integrate the FD, because I think the force changes with respect to the distance since as you push more more of the piston comes in contact with the cylinder...can someone please help! :)
2. A steam turbine receives a steam flow of 5000 kg/h and its power output is 500 KW. Neglect any heat loss from the turbine. Find the change in specific enthalpy of the steam flowing through the turbine if a) if the entrance and exit are at the same elevation and entry and exit velocities are negligible (I found this answer already) and b) if the entrance velocity is 60m/s and the exit velocity is 360m/s, and the inlet pipe is 3m above the exhaust.
Part b I can't figure out, I know Bernoulli's equation, but when I plug in the given velocities and heights it doesn't give me the right answer for the enthalpy. Can someone help me out please?!
Thank you so much :D
Any help please? Assignment is due tommorow :(
Anyone?
you guys are in my class, could you wear bright colors tomorrow to solve the mystery of who you are?
good luck figuring it out. We guessed that it was the change in volume divided by the area, to calculate the change in displacement.
  • · Replies 28 ·
  • · Replies 58 ·
