STRACT: Inertial Frames in Special and General Relativity
The discussion centers on the definition and characteristics of inertial frames in Special and General Relativity, contrasting them with Newtonian physics. Participants explore the implications of these definitions, including the distinctions between globally and locally inertial frames, and the effects of gravitational fields on these frames.
  • Some participants define inertial frames in Special Relativity (SR) as those moving along geodesics in spacetime, which corresponds to non-accelerating frames.
  • Others argue that in General Relativity (GR), an inertial frame can be locally inertial even if it appears to be accelerating, highlighting the distinction between local and global inertial frames.
  • One participant notes that while the Earth is moving along a geodesic, a person standing on its surface is not in an inertial frame due to the normal forces acting on them.
  • Another participant emphasizes that geodesics depend on initial conditions and the curvature of spacetime, suggesting that they are not coordinate dependent.
  • Some participants discuss the implications of tidal forces on inertial frames, indicating that deviations from Newton's second law can occur in non-uniform gravitational fields.
  • There is a discussion about the nature of geodesics, with some asserting that they are the same across different frames, while others contend that the perception of a geodesic can vary based on the observer's frame of reference.
  • One participant introduces a mathematical perspective on geodesics, discussing their dependence on the parameterization of curves in spacetime.
Participants express differing views on the nature of inertial frames and geodesics, with no consensus reached on several points, particularly regarding the implications of gravitational effects and the relationship between geodesics and frames of reference.
Some claims rely on specific interpretations of gravitational effects and the definitions of inertial frames, which may not be universally accepted. The discussion includes unresolved mathematical concepts related to geodesics and their parameterization.
madness
How are inertial frames defined in Special and General Relativity? In Newtonian physics, an inertial frame is usually defined as one in which N2 holds. Clearly this cannot be the same definition as for SR. In GR an inertial frame is one in which SR holds (I think). However, there is now a distinction between globally and locally inertial, and frames which are apparently accelerating towards each other can still be locally inertial.
In both SR og GR, an inertial frame is one which is moving along a geodesic in space-time. In SR this reduces to nonaccelerating frames as inertial.
First of all, I concur with the reply above.
Yes, in SR an intertial frame can be said to fill the entire space. N2 would be valid for all movements of particles as seen from this frame, no matter how far away.
In GR this needn't be the case There could be tidal forces present, if the frame is located in a non-uniform gravitational field. So in GR it could be the case that the inertial frame is only exact in an infinitesimal volume, since deviations from N2 appear as soon as a particle is not in the origin of the inertial frame.
The fact that each planet experiences tidal forces is a manifestation of this. They do not follow N2 because their size is finite.
In GR, two intertial frames can accelerate towards each other. Just consider two frames, each freely falling towards a massive object, from opposite sides.
Torquil
Isn't the Earth moving on a geodesic? Would someone standing on a non-rotating Earth be in an inertial frame? And the geodesics depend on the frame we're working in, but it still holds that someone traveling along one will be in an inertial frame?
madness said:
Isn't the Earth moving on a geodesic? ...
Yes.
... Would someone standing on a non-rotating Earth be in an inertial frame?
No. They are kept on the surface by normal forces. A geodesic at the surface is the line traced by a falling object which otherwise does not interact with matter. The geodesics proceed downwards, through the surface. You can tell it is not inertial because you can feel weight.
The Earth itself, however, is falling unimpeded around the Sun... a geodesic.
In GR, a geodesic is a frame which is freely falling. As I understand it, in GR, a frame is really only local to the observer falling along the geodesic.
Cheers -- sylas
Earth's center is moving approximately on a geodesic.
Geodesics at the surface are accelerated inwards by Earth's gravitation, so someone standing at the surface actually accelerates away from a geodesic.
Further, and maybe more pertaining to your question: a point on the surface is moving alway parallel to Earth's center, but, due to tidal effects, experiences different gravitational "forces" from moon and sun. So even in the absence of Earth's gravitational field, it doesn't move on a geodesic. That's how inertial frames are valid only for small regions in curved spacetime.
No, geodesics depend on initial conditions (velocity) and the curvature of spacetime. They are not coordinate dependent.
"No. They are kept on the surface by normal forces. A geodesic at the surface is the line traced by a falling object which otherwise does not interact with matter. The geodesics proceed downwards, through the surface. You can tell it is not inertial because you can feel weight."
It seems a little strange that the Earth is moving along a geodesic and I'm moving along with the Earth yet I'm not moving along a geodesic. I suppose Ich is right that if I was in the centre of the Earth I would be moving along a geodesic.
"No, geodesics depend on initial conditions (velocity) and the curvature of spacetime. They are not coordinate dependent."
From the point of view of a man in freefall, he sits at the origin the whole time, whereas from the point of view of the Earth he traces out a geodesic. Or from the point of view of someone on a roundabout, a geodesic might be a spiral. They do depend on the frame of reference - that's where the affine connection come's into the geodesic equation.
No; the geodesics are the same in all cases. All that is different is the co-ordinates of the geodesic. The geodesic itself is a set of points in spacetime... a path or a locus. The same set of points is a geodesic independent of what co-ordinate system you use to identify the points.
Cheers -- sylas
Approximately. An extended object is always subject to tides, so no point of it moves exactly on a gedesic. But the center is as close as possible.
And sylas beat me to your second statement. There is only one geodesic, but infinitely many ways to assign coordinates to it.
Yes.
This confuses a function with the image of a function, but I'm probably being overly pedantic here.
Not at all! I'd much prefer to be as correct as I can manage, and I don't always get the terminology right. But I'm not sure of the issue here. A pedantic explanation of the best way to express it would be much appreciated!
Cheers -- sylas
A geodesic depends not only on a set of points in spacetime, but also on how ("fast") the points are traversed. A curve in a spacetime [itex]M[/itex] is a mapping
[tex]\gamma : I \rightarrow M,[/tex]
where [itex]I[/itex] is an interval (often closed) of the real line. A curve [itex]\gamma[/itex] is a geodesic if the tangent vector [itex]\dot{\gamma}[/itex] is parallel transport along the curve, that is, if
[tex]\nabla_{\dot{\gamma}} \dot{\gamma} = 0.[/itex]<br /> <br /> An observer is a future-direct timelike curve [itex]\gamma[/itex] parametrized by proper time. This means that<br /> <br /> [tex]g \left( \dot{\gamma} , \dot{\gamma} \right) = 1[/tex]<br /> <br /> all along the curve. In this case, the tangent vector "field" is the observer's 4-velocity, often denoted by [itex]\mathbf{u}[/itex], the observer's 4-acceleration is<br /> <br /> [tex]\mathbf{a} = \nabla_{\mathbf{u}} \mathbf{u},[/tex]<br /> <br /> and a freely falling observer is a geodesic observer curve.<br /> <br /> Sometimes pinning down things so precisely confuses, and sometimes it helps with understanding.[/tex]
Ah! Thank you. I think I have been thinking of a geodesic as what should more properly be called the image of a timelike geodesic. Given the image of a timelike geodesic, I guess there is only one unique way to give a geodesic that is parameterized by proper time, and so I didn't worry about the map.
Quite so! But if I understand the definitions better, I may be able to improve my own descriptions, even if not given in full detail, so that they remain correct when made more precise; which would be nice. Not to mention that I simply wanted to know it better myself.
Thanks -- sylas
[tex] <br /> Mathematicians mostly use M as a n-dimensional embedded manifold in a (n+1)-space and they of course clarify what topology the manifold is equipped with. In this case (basically in GR), since M is a smooth manifold and of course equipped with the metric topology in a Riemannian space(time), i.e. the local coordinates are curvilinear, one has to notice that<br /> <br /> [tex]\gamma : I \rightarrow M,[/tex]<br /> <br /> depends, above all else, on the metric itself and then when it comes to the dynamical properties of the moving particles, mass points, on geodesics, considering the fact that [tex]\nabla_{\dot{\gamma}} \dot{\gamma} = 0[/itex], it is said to be <i>a geodesic depends on how fast the points are traversed</i>. This means that the geodesics are split into various categories just by studying the dynamics of particles moving on them. This is the reason why Mathematicians are not that much acquainted with, for instance, light-like geodesics. <br /> <br /> So I would see that both sylas and George look at one thing from two different angles which each calls for its own viewpoints.<br /> <br /> AB[/tex][/tex]
As usual, Altabeh, I think I disagree with what you have written, but I am sufficiently confused by what you have written to be sure that I disagree.:wink::biggrin:
Also, as usual, work intervenes, and I don't know when I'll get back to this thread. IF I do get back to this thread, I want to address some technical issues, but first a simple example. Take R^4 to be Minkowski spacetime, with g suitably defined using the standard global chart as an inertial coordinate system.
Let \gamma : [0, 1] -> R^4 be given by \gamma(t) = (t, 0, 0, 0), and let \alpha : [0, 1] -> R^4 be given by \alpha(t) = (t^2, 0, 0, 0).
What is the relevance to this example of what you have written.
I'm so happy that you disagree again with me this time on this issue and I hope you are not going to not be back to this thread as you once left my post https://www.physicsforums.com/showthread.php?t=371614" without an answer.
Let's say you wanted to declare that geodesics are realized by two qualities:
1- A geodesic is a set of points in spacetime that is defined to be locally the shortest path between points in the spacetime. (From a mathematical point of view)
2- The instantaneous derivative of a curve wrt the proper time s at each point and the change in the direction of this derivative along the curve must be taken into account so a little analysis on these two things is required when studying geodesics. For example, [tex]\dot{\gamma}=a[/tex] with a being a constant, represents a straight line or the shortest path between two points in a Minkowski spacetime and thus [tex]\dot{\dot{\gamma}}=0[/tex] for every line; this is the shortest because the curvature vector of [tex]\gamma[/tex] is null.
In mathematics, the second part of the "quality" 2 is indeed a manifestation of the first formula of Frenet formulae,
[tex]R=|\dot{\dot{\gamma}}|[/tex], (1)
where R is the magnitude of curvature vector.
Which in physics and specially GR plays a significant role as the equation of geodesic. So that one can see that it just falls upon the equation of geodesic to determine how fast geodesics are traversed. All these things happen to exist on metric spaces so the first thing that a geodesic depends on is the metric of that space(time) not anything else. You say it is the first part of "quality" 2 which can along with "quality" 1 distinguish a geodesic from other curves. But I'm saying that it
not how fast geodesics are traversed. The difference between my idea and yours is that I don't talk about a special M but you take M for granted to be a given metric (I think). So you can see that it is so simple-minded to even think that we are in a disagreement with each other.
See that you specify R^4 or the Minkowski spacetime. Now you must get my idea: through the use of equation (1), [tex]|\frac{d^2}{dt^2}\alpha(t)|=R_\alpha=2,[/tex] which means [tex]\alpha[/tex] is not a geodesic in R^4. But this could be if we considered another spacetime with another metric.
AB
Okay, now I have some idea what you mean, but in this thread, I think that is best to take spacetime to be an arbitary but fixed pair [itex]\left( M , \mathbf{g} \right)[/itex], where [itex]M[/itex] is a 4-dimensional differentiable manifold and [itex]\mathbf{g}[/itex] is a Lorentzian "metric", so that a metric-compatible torsion-free connection is fixed.
I think that box 10.2 form Misner, Thorne, and Wheeler hints at a physicist's version of what you mean. I don't seem to have any math references that talk about this. Could you give some?
Like always, I am hard-pressed to find time for this, as I'm preparing to go out of town today, and much of my weekend will be spent doing stuff with my wife and three-year-old daughter. Maybe Monday. I want to discuss some of the technical details.
For example, while it is true in a Riemannian mainfold that shortest distance (if it exists) between two points is a geodesic, it not true that
Easy counterexamples to this statement exist! For example, consider [itex]S^2[/itex] with its metric inherited by considering it to be a surface in [itex]\mathbb{R}^3[/itex]. Think about geosdesics on the surface of the Earth!
Could the difference between George's and Altabeh's definitions (the acceleration def, not the length def) is that for George, a geodesic is an affinely parameterized geodesic, while for Altabeh, a geodesic can be a non-affinely parameterized curve traversing the same path?
The concept of inertial frames doesn't really apply to GR. An inertial frame is a coordinate system in which the laws of physics take the standard form, and in GR the laws of physics are expressed in terms of tensor quantities in order to ensure that they take the same form in all coordinate systems.
The comments about geodesics describe inertial objects, which is not the same as describing inertial reference frames.
You can define an inertial frame in GR too. Consider a point p on the world line of an object. We take p to be the origin. The tangent of the world line at p is by definition a geodesic through p. We take that to be the time axis. The time coordinate at a point q on the time axis is defined to be the proper time along the time axis from p to q. The x,y,z axes are chosen from a hypersurface through p that's orthogonal to the world line. They're either chosen arbitrarily or chosen to match how the object is oriented in space. And, uh, I realize that I don't fully understand the whole construction myself (in curved spacetimes). I'm going to have to think about it, or look it up.
If spacetime is flat, the result is the co-moving inertial frame at p. If spacetime is curved, the procedure may not define a coordinate system that covers the entire manifold. Hence the term "local inertial frame".
Exactly.
"The concept of inertial frames doesn't really apply to GR. An inertial frame is a coordinate system in which the laws of physics take the standard form, and in GR the laws of physics are expressed in terms of tensor quantities in order to ensure that they take the same form in all coordinate systems"
Can't you say that an inertial frame is one in which SR applies locally?
Yes. BTW, in Newtonian physics, I usually think of an inertial frame as one in which N2 and N3 apply.
I think that is best here to take spacetime to be a "Pseudo-Riemannian" manifold M equipped with a non-degenerate, smooth, symmetric metric tensor g. So you can see that I rule out the part demanding the Minkowskian signature for metric just because we can talk about beautiful and new-brand things like geodesically equivalent metrics on a such a manifold which could bring more motivation into the discussion.
I'm really uncomfortable with the notations M, T and W use in their book to describe things. I'll study whatever I see in that box and come to you and say if I am able to find any math ref. on that!
Say my special hello to your beloved family! Hope to have a nice weekend and of course a challenging monday here in this thread! :)
I don't see anything here that can be in contrast to my statement. Geodesics can generally be defined for any (Pseudo-) Riemannian manifold. Every shortest path from a point on the manifold to another one gives rise to a geodesic, but the converse is not always true if the discussion does not focus on the local paths or the paths berween sufficiently neighbouring points in which case your counterexample fails to work! This is because the shortest paths between two sufficiently adjacent points must concide with one of the geodesics. Otherwise you are completely right!
Besides, it is possible that there are no shortest paths from a point in M to another point in M, but there are geodesics connecting these two. An example of this is the sphere with a point between two points removed. But remember that this case is not globally smooth, so the idea of counterexamples fails to be valid in any way.
AB
This is partly just a matter of taste, but I'm in sympathy with DaleSpam. To me, the whole philosophy of GR is to explicitly stop trying to make these distinctions between valid and invalid frames of reference. That's the whole point of general covariance. Einstein has a very readable discussion of this in "The Foundation of the General Theory of Relativity" http://hem.bredband.net/b153434/Works/Einstein.htm . (Note that although the guy has his own copyright claim on the page, it's actually just a verbatim copy of the public-domain translation by Perrett and Jeffery.)
The way I read Einstein's explanation, it's basically a statement that the whole concept of a frame of reference is kind of meaningless in GR. By the time he gets done introducing general covariance, he's weakened the word "frame" so much that it no longer means what it originally meant. In SR "frame" carries the connotation of a lattice of clocks and rulers that fills space in a Euclidean way. In GR it just means a system of arbitrary labels for events.
This is not exactly my own discussion here, but you got it sort of right! If you had said a geodesic must be a non-affinely parameterized, I would have answered in the negative. You know, in GR the geodesic equation does not call necessarily for an affinely parameterized geodesic. If we set the tangent vector to a curve as [tex]u^{\mu}=dx^{\mu}/ds[/tex] for some arbitrary parameter of curve, [tex]s[/tex], then the geodesic equation has the form
[tex]u^{\mu}u^{\nu}_{;\mu} = f(s)u^{\nu}[/tex],
for some scalar function f(s). In general, the right hand side of this equation does not vanish unless we take s to be an affine parameter. But you can see that here the four-velocity [tex]u^{\nu}[/tex] plays a role in determining the geodesics, but geodesics can be independent of them while they strongly depend on, first, metric (so Christoffel symbols) and then accelerations [tex]du^{\nu}/ds[/tex]. This can be readily understood from Goerge's example ([tex]\alpha(t)=(t^2,0,0,0)[/tex]) why here I don't rely on the four-velocity along a geodesic: As t is not an affine parameter and in a Minkowski spacetime the Christoffel symbols vanish, so the terms containing four-velocities disappear in the geodesic equation which reduces now to:
[tex]u^{\mu}u^{\nu}_{,\mu} = f(s)u^{\nu}[/tex],
from which we have only the following non-vanishing equation
[tex]u^{0}u^{0}_{,0} = f(s)u^{0}[/tex].
So [tex]u^{0}_{,0}=f(s)[/tex]. Finally
[tex]f(s)=2[/tex].
As you can see, after considering the metric itself, it's the components of four-acceleration (which I'm fine with "acceleration" alone) along the curve determine whether [tex]\alpha[/tex] is geodesic or not!
AB
I haven't read this mathematical discussion in detail.
For me, it seems reasonable that all physics should be completely independent of the choice of parametrization of a worldline path. So any observable property should only depend on the image of the path. Thus I hope that the mathematical formalism was independent of this.
Torquil
I like that point of view too but unfortunately you can still tell whether or not you are in an inertial frame, which seems to detract from the absolute relativity of motion. Every treatment of GR I have read so far makes extensive use of inertial frames and the fact that you can always make a change of coordinates into an inertial frame.
How?
By checking that SR applies locally. It's not much different to checking that N2 applies in Newtonian physics.
  • · Replies 22 ·
  • · Replies 36 ·
  • · Replies 78 ·
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 144 ·
10K
