Proving the Uniqueness of Base Representation for Integers
  • Context: Graduate
  • Thread starter Thread starter sty2004
    Base Representation
The discussion focuses on proving the uniqueness of base representation for integers in base k, specifically addressing the scenario where two different representations, n and m, exist. It establishes that if n is represented as asks + as-1ks-1 + ... + a0 and m as btkt + bt-1kt-1 + ... + b0, then m cannot equal n when as and bt are non-zero. The participants suggest dividing both numbers by ks+1 to demonstrate that one quotient will be less than 1 while the other will be greater than or equal to 1, confirming the uniqueness of representation.
  • Understanding of base k number systems
  • Familiarity with polynomial representations of integers
  • Knowledge of mathematical proofs and inequalities
  • Basic concepts of uniqueness in mathematical representations
  • Study the properties of base k representations in detail
  • Explore the implications of Theorem 1-3 on integer representations
  • Investigate the uniqueness of representations in other bases
  • Learn about polynomial division and its applications in number theory
Mathematicians, computer scientists, and students studying number theory or discrete mathematics who are interested in the properties of integer representations in various bases.
sty2004
base representation please help~
It is known that if asks+as-1ks-1+...+a0 is a representation of n to the base k, then 0<n<=ks+1-1.
Now suppose n=asks+as-1ks-1+...+a0 and m=btkt+bt-1kt-1+...+b0 with as,bt not equal to 0, are two different representations of n and m to base k, respectively. Without loss of generality we may assume t>=s. Without using Theorem 1-3(existence and uniqueness of such representation of an integer), prove directly that m not equal to n.
Many many thanks~~~
You can try dividing both numbers by ks+1... one quotient will be <1 and the other >=1.
Edit: Oh, I'm sorry. I thought t>s, while you said instead t>=s. In this case I think you need something else, because if t=s, as=bs and all ai,bi are 0 for i<s, then n=m.
Oh, but then again... you said they are different representations. I assume this means that, even if t=s, as and bs cannot be the same. Then, in this case, divide both numbers by max(as,bs) . ks, and that should give you one quotient <1 and another >=1.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 26 ·
10K
