How Does the Fermi Level Influence Solar Cell Voltage?
The discussion revolves around the concept of the Fermi level in the context of solar cells, particularly its influence on the voltage produced by the device. Participants explore definitions, relationships to chemical potential, and the implications for semiconductor physics.
  • One participant seeks clarification on the term "Fermi level" as it relates to the working voltage of solar cells, specifically in relation to titanium dioxide and redox potential.
  • Another participant questions whether the term "normal" Fermi level is being used, implying a potential misunderstanding of the context.
  • A participant references a previous discussion that mentions two definitions of the Fermi level, expressing confusion and seeking further explanation.
  • One participant asserts that chemical potential and Fermi level are synonyms, prompting further inquiry into the definition of chemical potential.
  • A participant claims that the chemical potential of a semiconductor is typically located in the middle of the band gap, raising questions about the accuracy of this statement.
  • Another participant counters that the chemical potential is not generally in the middle of the band gap and provides a technical definition related to thermodynamics and solid-state physics.
  • One participant notes that while the Fermi level and electrochemical potential are not the same in general, they are often treated as synonymous in the context of semiconductors.
Participants express differing views on the definitions and implications of the Fermi level and chemical potential, indicating that multiple competing perspectives remain without consensus.
There are unresolved questions regarding the definitions of Fermi level and chemical potential, as well as the specific conditions under which these terms apply in semiconductor physics.
Max.Planck
Hello,
Im working on a paper on solar cells and i came across the term "Fermi level". What exactly is the Fermi level in this context:
"The working voltage produced by the device is the difference
between the chemical potential of the titanium dioxide (Fermi
level) and the redox potential of the mediator (I-/I3-)."
Thank you!
Max Planck
"in this context"?
Is there are any particular reason why you think they are referring to anything but the "normal" Fermi level?
Chemical potential and Fermi level are synonyms.
What exactly is the chemical potential?
I read that the chemical potential of a semiconductor is in the middle of the band gap, is this true?
No, generally not.
Its the derivative of e.g. energy U with respect to particle number (here of electrons) at fixed S and V or of G at fixed T and p. In a semiconductor it is usually somewhere inside the gap, but seldomly in the middle. In a metal at absolute zero it is the borderline between the occupied levels and the empty energy levels.
Have a look at a book on thermodynamics or solid state physics.
In general the Fermi level and the (electro)chemical potential are not the same, but in a semiconductor we regard them as being synonymous.
Thanks
  • · Replies 21 ·
13K
