Is it possible to find out how many bytes of data one chromosome holds?
  • Thread starter Thread starter Char. Limit
    bytes Data
The discussion revolves around the question of how much data a single human chromosome, specifically Chromosome 1, can hold in terms of bytes. Participants explore the implications of defining genetic information, the relevance of different types of information encoded in DNA, and the comparison of genomic data to computational data storage.
  • Some participants suggest that the amount of data a chromosome holds depends on how 'byte' is defined in the context of genomic information.
  • Chromosome 1 is noted to have about 224 million base pairs, which some participants quantify in terms of bytes, estimating it to be around 62 Mbytes based on information theory.
  • There is a distinction made between the DNA sequence itself and other forms of information, such as chromatin packaging and DNA methylation, which some argue also carry information.
  • One participant expresses a desire to quantify genetic information in bytes for reference, comparing it to expressing distances in kilometers.
  • Another participant challenges the comparison of genomic data to computer data, emphasizing that DNA can store vast amounts of information in a small physical space.
  • Some participants mention that the total data in a typical human cell is much larger than just the DNA sequence, citing figures in the gigabytes and terabytes when considering non-coding DNA and cellular structures.
  • There is a discussion about the potential of DNA computing, highlighting its parallel processing capabilities compared to traditional computing methods.
Participants do not reach a consensus on the meaning of quantifying chromosome data in bytes, with multiple competing views on what constitutes information in the context of DNA. The discussion remains unresolved regarding the comparison of genomic data to computer data storage.
Participants note that the definitions of 'information' and 'data' can vary significantly, and there are unresolved assumptions regarding the types of information encoded in DNA versus the information theory perspective.
Char. Limit
Is it possible to find out how many bytes of data one chromosome (say, Chromosome 1 for humans) carries?
Does the question have any meaning?
Biology news on Phys.org
That would depend on how you would define a 'byte' of data as it pertains to genomic information, but chromosome 1 has about 224 million base pairs.
What kind of information are you counting? The DNA sequence is one part of the information carried on the chromosome and it's failry easy to quantify the amount of information present there. However, you could also argue that the way in which the DNA is packaged into chromatin or the patterns of DNA methylation also constitutes information.
I'm not sure, I thought information was only in the actual DNA.
Information is also on top of the DNA, like Ygggdrasil mentioned.
I'm not sure why you want to express it as bytes (I have a worm database, which contains all the genomic sequence and specifies locations of genetic elements, which is 1520 MB in size). It is better to formulate it as functional units, such as genes or CNVs or SNPs etc: the database contains 24114 curated coding sequences.
I want to express it in bytes for the same reason I like to express distance of light-years in kilometers: to give me a reference.
You don't express length or weight in bytes, do you?
you might want to express it in bytes if you are looking at it from an http://en.wikipedia.org/wiki/Information_theory" perspective
The raw number of base pairs is still not necessarily the best information theory perspective; but that's a quibble.
The simplest answer for the human chromosome 1 is a bit under 62 Mbytes. There are about 247 million base pairs, and each base pair has four possibilities. So if you just take it as a sequence of units, each unit being two bits, you end up with nearly 62 million bytes.
Cheers -- sylas
I see. Thank you, Sylas.
Also, to Monique, I would, of course, not express a length or weight with a unit of information.
You are being smart, but you've still not explained why you would want to know the number of bytes over simply the number of units (kilometers/basepairs/genes). You yourself stated that you questioned whether your question has any meaning.
I did indeed, because I wasn't sure if DNA could be said to carry data in the sense of bytes.
The bytes are to give me a reference point. Can a chromosome carry more data than, say, an advanced computer?
At near 62Mb, no way.
Alright, fair enough. Just note that it is not a valid comparison. You are comparing an arbitrary unit (one chromosome) to an advanced computer (carrying how many chips?). People are not turning to DNA as the future for computing for nothing: you can contain a lot of information on a very small scale.
A typical diploid human cell has "1.5 Gb of data" stored in a nucleus with a diameter of approximately 6 micrometers (only taking into account the basepairing of the DNA).
According to Leonard Adleman, a pioneer in DNA computing:
What about the future? It is clear that molecular computers have many attractive properties. They provide extremely dense information storage. For example, one gram of DNA, which when dry would occupy a volume of approximately one cubic centimeter, can store as much information as approximately one trillion CDs. They provide enormous parallelism. Even in the tiny experiment carried out in one fiftieth of a teaspoon of solution, approximately 1014 DNA flight numbers were simultaneously concatenated in about one second. It is not clear whether the fastest supercomputer available today could accomplish such a task so quickly.
http://www.cs.virginia.edu/~robins/Computing_with_DNA.pdf
Also note that the biological information in DNA is contained on many layers (for instance epigenetic information): it is not simply a linear sequence of letters.
i believe the benefit to DNA computing would be the massive amount of parallelization. this can be good for certain types of problems, like cracking encryption by brute strength. but for general purpose computing, where serial calculations are required, it's probably not very useful.
Monique said:
A typical human cell has "750 Mb of data" stored in a nucleus with a diameter of approximately 6 micrometers.
Dear Monique, a nucleus has far, far more data stored than 750 MB. The DNA backbone alone (not considering DNA methylation) has about 3.3 GB in its haploid form for human DNA (one byte being 2 bits of information A=T, G=C and T=A, C=G). Most of the information is stored in non-coding stretches (98%) which constitute the so-called regulatory network of information (the higher an organism, the more non-coding DNA stretches it carries in the genome). If you consider RNA and proteins in the 3D space of a cell, which is usually highly structured, the stored information of a single cell (or nucleus) is easily in the lower TB. All life forms are self-encoded, self-assembling, self-propagating nano-structures and what is written in the DNA is only to get from one existing nano-structure (fertilized egg) to a complete mature organism and back to the initial nano-structure. If you mess up a fertilized egg's 3D RNA and protein structure (virtually destroy its information content), the micro-injected DNA cannot perform. The DNA is kind of like the software in a robot (fertilized cell) to give the instruction on how to change itself for duplication. The fertilized egg with all its components is the hardware. So not everything is encoded in the DNA. That's why organisms (species) and its DNA (RNA) co-evolved over millions of generations.
Hi bioinfinity, the human genome carries about 3 billion base pairs, you need two bits to describe each basepair, divide by 8 = 750 Mb. Indeed that is haploid (one copy), a diploid genome (two copies) would be 1.5 Gb.
I've already mentioned that there is additional information besides the bare genetic code.
