Thread Closed
Two Speakers - Sound Maximum and Sound Minimum Problem
Share Thread Thread Tools
Jan30-10, 05:40 PM   #1
Hi, I am having difficulty solving the following problem:
Two loudspeakers 5.0 m apart are playing the same frequency. If you stand 13.0 m in front of the plane of the speakers, centered between them, you hear a sound of maximum intensity. As you walk parallel to the plane of the speakers, staying 13.0 m in front of them, you first hear a minimum of sound intensity when you are directly in front of one of the speakers.
What is the frequency of the sound? Assume a sound speed of 340 m/s.
2. Relevant equations
Sound Maximum:
L1 - L2 = n[tex]\lambda[/tex]
Sound Minimum:
L1' - L2 = (n+[tex]\frac{1}{2}[/tex])[tex]\lambda[/tex]
Frequency:
f = [tex]\frac{v}{\lambda}[/tex]
3. The attempt at a solution
Sound Maximum:
L2 = 13.0 m
L1 = [tex]\sqrt{13.0^{2}+2.50^{2}}[/tex] = 13.23820229
L[tex]_{1}[/tex] - L[tex]_{2}[/tex] = n[tex]\lambda[/tex]
13.23820229 - 13 = n[tex]\lambda[/tex]
n[tex]\lambda[/tex] = 0.23820229
Sound Minimum
L1' - L2 =(n + [tex]\frac{1}{2}[/tex])[tex]\lambda[/tex]
L2 = 13.0 m
L1' = [tex]\sqrt{13.0^{2}+5.0^{2}}[/tex] = 13.92838828
Sub in n[tex]\lambda[/tex]= 0.23820229:
L1' - L2 = (n + [tex]\frac{1}{2}[/tex])[tex]\lambda[/tex]
13.92838828 - 13 = n[tex]\lambda[/tex] + [tex]\lambda[/tex]/2
[tex]\lambda[/tex]/2 = 0.92838828 - 0.23820229
[tex]\lambda[/tex] = 1.380371974
Sub in [tex]\lambda[/tex] = 1.380371974:
f = [tex]\frac{340}{1.380371974}[/tex]
f = 246.3104195 Hz
I'm not sure if my approach is wrong or if I'm interpreting the question incorrectly. Any help would be greatly appreciated!
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jan31-10, 07:51 AM   #2
Recognitions:
Homework Helper Homework Help
In the central position the two speakers are at equal distance. So the path difference is zero. In between the first and the second position, there is neither a maximum nor a minimum. So at the second position ( l1' - l2) = λ/2.
Jan31-10, 08:57 AM   #3
Ooh.. no wonder. Thank you very much!
Thread Closed
Thread Tools
Similar Threads for: Two Speakers - Sound Maximum and Sound Minimum Problem
Thread Forum Replies
Directional (ultra)sound speakers General Physics 5
Hooking up surround sound, how to disable tv's speakers? Computing & Technology 6
Sound: Speakers Woofers vs. Tweeters Advanced Physics Homework 2
Speakers & sound waves Introductory Physics Homework 6
Speakers sound level at a certain point. Introductory Physics Homework 1
