Thread Closed
Designing Motor Driver Circuit
Share Thread Thread Tools
Feb1-10, 07:07 AM   #1
Hey, i'm looking for some ideas how to design a motor driver for a pair of DC motors. They have a input variable voltage of 0v-3.3v. When the input voltage is half (about 1.6v) the motor should stop, but if it is any greater than 1.6v it will go forward, below 1.6 it will go backward. 0v should go backward at full speed, and 3.3v should go forward at full speed. I dont know why, but im having a real brain fart this morning and am looking for any general ideas, or what blocks i would need to do this (all i have so far is a voltage follower buffer from the power inputs)
The micro would be varying the voltage to control the direction and speed, but would I need to use comparators to do this? I found an H bridge motor driver circuit, but it looks like that is controlled by PWM http://www.societyofrobots.com/schem...ridgedes.shtml
Any input is appreciated
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Feb1-10, 04:44 PM   #2
Mentor
Quote by tkulchaw View Post
Yes, you need to use PWM to vary the speed of the motor. Voltage variation is generally ineffective, and is not used. So just have your uC digitize the variable input voltage, and use that to control the PWM polarity and duty cycle.
Feb1-10, 06:34 PM   #3
i spoke to one of my professors today concerning it, he said that we were meant to try to use a window comparator, and then two op amps to vary the voltage potential on the two sides of the motor (a completely analog solution).
It is a group project that we are making a line following robot, and the different group members have to output and take specified inputs. The specified input I get is a 0-3.3Vdc input. The important part is that my section of the project works stand alone, so that I can simulate inputs and show that my outputs are correct.
I was told that most people get a 2nd micro, and use an ADC to make their own PWM output, and direction bit to control an H bridge, which is most likely what I will fall back on... if i have trouble with the window comparator. Google here I come.
Feb1-10, 06:49 PM   #4
Mentor
Sounds like your prof isn't familiar with how to drive DC motors.... or else he is thinking of something that I'm not understanding.
If you would prefer to generate the PWM signals in a more analog fashion, you can use a technique that is used in switching power supply designs often. You can compare a triangle wave against the DC voltage level to give you a varying PWM signal that varies with the DC voltage.
Draw a triangle wave, and then draw some horizontal lines through the tri wave. You can see that the higher the horizontal (DC) voltage is on the tri, the less time the tri is above it. If you square up the comparison of the tri wave and the DC voltage, you can see what kind of PWM waveforms you will get out of the copmarison.
So now you can think of what kind of other circuitry you can add to the output of the tri vs DC comparator circuit, in order to generate the correct polarity PWM signal to your H-bridge motor drive circuit. At least your prof is right that you will need some window comparators... One for high input DC, one for low input DC, and one for the middle window area where you want the motor off...
Can you post a block diagram of such a circuit?
Thread Closed
Thread Tools
Similar Threads for: Designing Motor Driver Circuit
Thread Forum Replies
Motor Driver General Engineering 2
Line Driver and Oscillating Circuit Electrical Engineering 5
Low Power Dissipation Driver Circuit Electrical Engineering 8
Motor Driver circuit Electrical Engineering 1
motor driver booster Electrical Engineering 8
