Can a Photon be deflected by Magnetic and Electric Field?
The discussion revolves around whether a photon can be deflected by magnetic and electric fields, exploring the fundamental properties of photons in relation to electromagnetic interactions.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the notion that photons, lacking charge and mass, cannot be deflected by electric or magnetic fields. Some reference historical figures and modern interpretations regarding photon interactions, including photon-photon scattering.
The conversation includes various perspectives on the nature of photons and their interactions with fields. Some participants provide references to academic articles and diagrams, while others express skepticism or curiosity about the implications of photon behavior in different contexts.
There are references to specific articles and experimental observations that suggest complex interactions involving photons, indicating that the discussion may involve advanced concepts in quantum electrodynamics and light-matter interactions.
utsav55
Can a Photon be deflected by Magnetic Field and Electric Field?
Photon cannot be deflected by either, as it has no electric charge.
Correct, the photon has no charge or mass (although it has a spin!), so it can't be deflected. The photon itself is the propagation of a sinusoidal magnetic and electric field.
thank you
Almost correct. Heisenberg and Euler were the first to give the correct answer to this question http://arxiv.org/abs/physics/0605038" in 1936.
A modern treatment can be found http://arxiv.org/abs/hep-ph/9806417"
This question amounts to whether photon-photon scattering can occur, I think. I'm no expert, but I see no reason why the answer should not include this graph: http://colinfahey.com/eclectic_images_2002/gg-scat.jpg
Obviously, there's no tree level diagram cause there's no A^4 in the QED lagrangian, but I can't see why the above diagram wouldn't be allowed.
That's right and this gives rise other effects as well. If you connect one of the photon lines to a real electron, you get the diagram that describes the splitting of a photon due to interaction with a charge (rather than mere Compton scattering). Computing the amplitude is an exercise in the book by Itzykson Zuber.
I would like to catch your attention to the following recent article.
http://prl.aps.org/abstract/PRL/v106/i19/e193003
The abstract is the following.
"We report the direct observation of the nonreciprocity of the velocity of light, induced by electric and magnetic fields. This bilinear magneto-electro-optical effect appears in crossed electric and magnetic fields perpendicular to the light wave vector, as a refractive index difference between two counterpropagating directions. Using a high finesse ring cavity, we have measured this magnetoelectric nonreciprocity in molecular nitrogen at ambient temperature and atmospheric pressure; for light polarized parallel to the magnetic field it is 2η∥exp⁡(N2)=(4.7±1)×10-23  m V-1 T-1 for λ=1064  nm, in agreement with the expected order of magnitude. Our measurement opens the way to a deeper insight into light-matter interaction beyond the electric dipole approximation. We were able to measure a nonreciprocity as small as Δn=(5±2)×10-18, which makes its observation in quantum vacuum a conceivable challenge."
It has been reported as being a first experimental evidence of a possibility for photon-photon collision, here.
http://www.physorg.com/news/2011-05-when-the-speed-of-light.html
Cheers,
Thibault
A lot of this nonsense about photons doing one thing when you're looking at them and another if you're not is explained by the interaction of light and photons. In other words, you need light to see so yeah, they act differently if they are somehow sensitive to light.
(Another bit of nonsense is the Schroedinger's Cat thing. Schroedinger intended this as an illustration of some of the absurdities promulgated back then in quantum mechanics. But most peole seemingly took him literally and believe that the poor cat really IS neither dead nor alive until the box is opened.)
Am I boring anyone yet? :-)
  • · Replies 33 ·
