Large Static E Field, Dielectric Break Down, Quantum View
The discussion revolves around the mechanisms of ionization in large static electric fields, particularly in the context of dielectric breakdown and quantum effects. Participants explore the differences between static fields and low-frequency radiation, including the role of tunneling and non-resonant excitation.
  • One participant questions the difference between static electric fields and extremely low-frequency radiation, suggesting that both should behave similarly regarding ionization.
  • Another participant asserts that ionization can occur through non-resonant excitation at sufficient intensities, referencing Keldysh theory as a framework for understanding tunneling and multi-photon ionization.
  • A different participant discusses the role of an "initiator" in electrical breakdown, emphasizing the importance of field-enhancement regions and the Fowler-Nordheim model, which involves tunneling effects leading to field emission currents.
  • There is uncertainty expressed regarding whether ionization from high electric fields is analogous to spontaneous boiling, and whether tunneling is necessary for ionization by high-intensity radio waves.
Participants do not reach a consensus, as there are competing views on the mechanisms of ionization and the roles of static fields versus low-frequency radiation.
The discussion highlights limitations in understanding the conditions under which ionization occurs, particularly regarding the dependence on field strength, frequency, and the presence of initiators or sources of ionization.
azaharak
Hi
Got a question, hoping someone can give a good explanation for.
We all know that large static uniform electric fields have the potential to ionize. (Dielectric breakdown of Air - Static Electricity Shock).
In the Quantum picture, why does this occur. Take for instance the photo electric effect, increasing the intensity of radiation does not allow for electron ejection/excitation unless the frequency is above a certain threshold.
The frequency for a static field, I'm assuming to be zero. I'm thinking that, (virtual photons) could play a role in the underlying static field, and these photons might be the right frequency to ionize?
For a large static field, I understand why the ionization occurs classically but ...
I understand that a large enough static field, can liberate the electron classically.
I understand that even without this large static field that tunneling is a possibility.
What I don't understand is how a static field is really that much different from extremely low frequency radiation.
What I have learned is that only certain frequencies of radiation (light) can produce excitation or ionization. Increasing the intensity of a non resonant frequency will not liberate the electron (here the frequency is less that than threshold Like photo electric effect).
For instance, take really large intensity radiowaves Such that they will produce a huge electric field that is time varying. But they should not be able to ionize an atom?
Is the difference here that large intensities are many single photon combination.
What is so different between a high intensity static electric field and high intensity extremely low frequency radiation, other than the magnetic field tagging along with the radiation and the sinusoidal dependence?
Still a little uncertain.
Thank you all for your responses.
Best
Az
Your supposition is wrong. You can get ionisation through non-resonant excitation. Radio sources will induce ionisation at sufficient intesities.
Are you familiar with Keldysh theory? This is the theoretical framework that governs the transition between tunneling ionisation and multi-photon ionisation in the non-resonant case.
Claude.
azaharak said:
Hi
Best
Az
This is a bit confusing.
Let's start first of all by saying that in an electrical breakdown, there's a "source" of ionization. This is true be it in a static or alternating E-field.
Secondly, the external E-field is significantly lower than the ionizing potential of the molecules involved.
In many instances, there is an "initiator" or source. Often, it is a region with high field-enhancement (sharp, pointy objects). The most accepted explanation involves the formation of field-emission current (see Fowler-Nordheim model) from these field-enhancement region. These currents gain significant energy from the external field so much so that they can collide and ionize with the surrounding gas. This in turn can often lead to a cascading effect resulting in the formation of a plasma for a very brief period (see this: http://focus.aps.org/story/v19/st4).
The "quantum" aspect in all of this is not really in the field itself, but in how the source or initiator react to the field. The Fowler-Nordheim model invokes tunneling effects that resulted in the field emission current.
Zz.
Thank you
Soo, I'm assuming that the ionization due to high electric field occurs because of some (initiation), like how water begins to boil (spontaneous boiling)
I still maybe wrong.
Another thing, according to this Keldysh theory (previous reply)
you can ionize atoms (strip off electrons) with extremely high intensity radio waves.
Am I correct in saying that this ionization would not occur (if it was not for tunneling)?
Thanks again everyone
  • · Replies 0 ·
  • · Replies 24 ·
