Gauss Divergence theorem to find flux through sphere with cavity.
The problem involves applying the Gauss Divergence Theorem to determine the outward flux of a vector field across the boundary of a specified region defined by the inequalities 1 ≤ x² + y² + z² ≤ 4. The vector field in question is given in terms of its components and magnitude based on the coordinates.
  • Mixed
  • The original poster attempts to visualize the boundary as a sphere with a cavity and considers different methods for calculating the flux, including treating the outer and inner surfaces separately or integrating over the entire volume.
  • Some participants question the treatment of the inward normal for the cavity and clarify the implications of the outward normal requirement in the context of the divergence theorem.
  • There is discussion about the correct notation for the dot product in the context of the theorem.
The discussion is ongoing, with participants exploring the implications of normal directions on the flux calculation. Clarifications have been provided regarding the outward normal and the validity of the original poster's approach, but no consensus has been reached on the final method to be used.
The original poster expresses uncertainty about how to handle the inward normal area element and the implications for their calculations, indicating a need for further clarification on the application of the divergence theorem in this context.
jameson2
Use the divergence theorem to find the outward flux of a vector field [tex] F=\sqrt{x^2+y^2+z^2}(x\hat{i}+y\hat{j}+z\hat{k})[/tex] across the boundary of the region [tex]1\leq x^2+y^2+z^2 \leq4[/tex]
The Gauss Divergence Theorem states [tex]\int_D dV \nabla \bullet F=\int_S F\bullet dA[/tex] where D is a 3d region and S is it's boundary.
First, I sketched out the boundary, which I think is a sphere of radius 2 with a cavity f radius 1 at the centre. The formula requires that S is oriented outwards.
I basically need to know if the way to do this is first to treat it first as a sphere of radius 2 without a cavity, and work out the outward flux through this. Then treat the cavity as a sphere of radius 1 and work out the flux going into this, and add the two.
If this is the right approach, I'm not sure how to treat an inward pointing area element. The formula seems to heavily stress that the outward normal is taken, and I don't know if taking an inward normal is allowed.
Alternatively, I think I might be able to take the region as a whole straightaway, and then when integrating over the volume just take the limits of the radius as 2 and 1.
This way, which is the only way can actually get an answer at the moment, gives me an answer for the flux as[tex]\int_S F\bullet dA=48\pi[/tex]
Any help would be much appreciated.
"Outward" means "pointing away from the interior of the region". The outward normal on the inner (radius-1) surface points toward the origin, not away from it.
Incidentally, dot product is \cdot, not \bullet: [tex]\int_S F \cdot dA[/tex]
Ok, does that mean the way I got my answer isn't valid? Since by doing the whole thing in one go I only treated the normal pointing away from the outer surface and not the interior normal pointing towrads the origin?
No; if you computed [tex]\int_D (\nabla\cdot F)\,dV[/tex], then the divergence theorem says that equals the flux with the normal taken in the correct (away from the region) direction.
