Can the floor function be used in integration from 0 to 2?
The discussion revolves around the integration of a function involving the floor function, specifically the expression ∫([x] - 2[x/2]) dx from 0 to 2. Participants are exploring the implications of using a floor function in integration and questioning the continuity and behavior of such functions.
  • Participants discuss the nature of the floor function and its discontinuities, questioning whether it can be treated like continuous functions in integration. Some suggest graphing the functions to understand their behavior better, while others propose converting the integral into a summation.
The conversation is active, with participants sharing insights about the area under step functions and the challenges of integrating non-continuous functions. There is recognition of the need for special considerations when dealing with step functions, though no consensus has been reached on a definitive method.
Participants note that conventional integration methods yield results that may not apply to functions with discontinuities, highlighting the need to break integrals at points of discontinuity for accurate evaluation.
Integral8850
Integral [x] - 2[x/2] dx limits are 0 to 2
I am using [] to represent the floor function.
Of course normal integration gives
x^2/2 - x^2/2 which gives 0 for all cases, So is it right to assume a floor function (not continuous) is always 0?
Thanks!
You don't 'assume' something is equal to zero. You 'show' something is equal to zero. Draw a graph of [x]+2*[x/2] between 0 and 2. It's just a step function.
Thanks!
I don't think it's a good idea to use the answer for the continuous functions as a basis for the answer for the floor function. There are too many pitfalls with doing this.
In this case, the answer is clearly not zero. You can quickly graph out the functions and see the answer by inspection.
In more difficult cases, there are probably good methods to use. I've never had to do this before, but it seems to me you can probably convert some integrals (such as your case) to summation expressions.
Thanks, I did construct the graph. I guess I should have worded the question better. Can a step function have area?
Why not? The area under a step function is just the sum of the signed areas of some rectangles, isn't it?
I can clearly see that the graphs area is 1, however integrating [x]-2[x/2] conventionally will always give 0. I guess I should ask is there a special integration for a step function? Thanks
Personally, I would attempt to convert the problem to a summation (when possible), rather than an integral. There are techniques and tables for evaluation of summations, just as there are for integrals.
If you can see that the graphs area is 1, then I think you've solved the problem. You can certainly write down special rules for integrating step functions. But they are going to look complicated, and on a simple problem like this, it's really not worth it.
Thanks for your help!
in general if you want to integrate the floor function from say 0 to x where n<x<n+1, then what you need to do is break your integral at each point of discontinuity and use it as your integration limit, this way you will get a sum of integrals, and the last integral will be from n to x.
  • · Replies 105 ·
13K
