Linear Algebra - Change of basis question
The discussion focuses on finding the transformation matrix T_{B'A'} that represents a linear transformation from basis A to basis B, using the given matrices for the standard basis E4 in R4 and the polynomial basis B in P2 over R. The transformation matrix is derived using the identity matrices I_{AA'} and I_{B'B}, which are calculated based on the new bases A' and B'. The final result of the transformation is a matrix with many zeros, indicating specific properties of the transformation.
  • Understanding of linear transformations and their representation as matrices.
  • Familiarity with basis change in vector spaces.
  • Knowledge of polynomial spaces, specifically P2 over R.
  • Ability to perform matrix multiplication and manipulation.
  • Study the concept of change of basis in linear algebra.
  • Learn about the properties of linear transformations and their matrix representations.
  • Explore the implications of zero entries in transformation matrices.
  • Investigate the relationship between different polynomial bases and their transformations.
Students of linear algebra, mathematicians working with transformations, and educators teaching concepts of basis change and linear mappings.
zeion
Let A = E4 in R4 (standard basis) and B = {x^2, x, 1} in P2 over R. If T is the linear transformation that is represented by
[tex] <br /> \begin{bmatrix}1 & 1 & 0 & 1\\0 & 0 & 1 & -1\\1 & 1 & 0 & 1 \end{bmatrix}<br /> [/tex]
relative to A and B, find the matrix that represents T with respect to A' and B' where
A' = {(1,0,0,0), (0,0,1,0), (1,-1,0,0), (0,-1,1,1)}
B' = {x^2 + 1, x, 1}
So by looking at this matrix T, it's clear that its a transformation from A to B, so we want the transformation matrix [tex]T_{B'A'}[/tex],
which is: [tex]T_{B'A'} = I_{B'B}T_{BA}I_{AA'}[/tex]
So I need to find [tex]I_{AA'}[/tex] and [tex]I_{B'B}[/tex].
For [tex]I_{AA'}[/tex], I write A' wrt A(which is standard basis of R4):
I get : [tex]I_{AA'} = \begin{bmatrix}1 & 0 & 1 & 0 \\0 & 0 & -1 &-1\\0 & 1 & 0 &1\\ 0&0&0&1 \end{bmatrix}[/tex]
Then for [tex]I_{B'B}[/tex], I write B wrt B', and get
[tex]I_{B'B} = \begin{bmatrix}1 & 0 & 0 \\0 & 1 & 0\\-1 & 0 & 1 \end{bmatrix}[/tex]
Now I put them together to get something with lots of zeros.. which doesn't seem right?
Your answer is correct. (At least it sounds correct.) You have the representations of the A' basis in the natural basis, so try applying them to the given T and see what you get. Then look at how those results would be represented in the B' basis. You'll see why the transformed T has so many zeros.
When I put them all together I get:
[tex] \begin{bmatrix}1 & 0 & 0 \\0 & 1 & 0\\-1 & 0 & 1 \end{bmatrix} \begin{bmatrix}1 & 1 & 0 & 1\\0 & 0 & 1 & -1\\1 & 1 & 0 & 1 \end{bmatrix} \begin{bmatrix}1 & 0 & 1 & 0 \\0 & 0 & -1 &-1\\0 & 1 & 0 &1\\ 0&0&0&1 \end{bmatrix} = \begin{bmatrix}1 & 0 & 0 & 0\\0 & 1 & 0 & 0\\0 & 0 & 0 & 0 \end{bmatrix}[/tex] ??
  • · Replies 32 ·
