Intensity of laser beam / Inverse square law
The discussion centers around the intensity of a helium neon laser beam and whether this intensity adheres to the inverse square law. Participants explore calculations related to intensity and the nature of laser light propagation, considering both theoretical and practical implications.
  • One participant calculates the intensity of the laser beam as 0.652 W/m² and questions the applicability of the inverse square law, suggesting that the intensity does not obey it.
  • Another participant corrects the initial calculation, asserting that the area should be calculated as π(r)² without the factor of 4, leading to an intensity of 652 W/m².
  • A third participant reiterates the initial question and provides a rationale that the inverse square law applies to light radiated in all directions, while suggesting that a laser beam maintains its area over distance.
  • One participant discusses the internal workings of lasers, mentioning that photons travel multiple circuits within the laser cavity before exiting, which may affect the intensity and divergence of the beam.
  • Another participant states that the inverse square law applies only to isotropic sources, asserting that lasers, being highly directional, do not follow this law.
Participants express differing views on whether the intensity of a laser beam obeys the inverse square law, with some arguing that it does not due to the directional nature of lasers, while others suggest that it may under certain conditions related to beam divergence.
Participants' calculations and assumptions about intensity depend on the definitions of area and the nature of light propagation from lasers. There are unresolved mathematical steps and differing interpretations of the inverse square law's applicability to laser beams.
stimpyzu
Hello everyone!
I'm having a real tough time with this one, maybe I can get a little help.
A small helium neon laser emits red visible light with a power of 3.2 mW in a beam that has a diameter of 2.5mm. What is the intensity of the laser beam? Does this intensity obey the inverse square law?
Now I have for an answer an intensity of 0.652 W/m2 and that it does not obey the inverse square law (although this could be wrong).
For the intensity, I thought:
I = Power / ( 4 pi ( diameter / 2 ) ^ 2 )
but that gives me an intensity of only 0.163. And I thought that all light obeyed the inverse square law. I've done research for this on the net, but I can't find anything. A shove in the right direction would be appreciated.
Thanks!
Science news on Phys.org
You need to lose the 4.
ok, when I did the calculation, I get the right answer, but wrong decimal places. I found the area of the beams cross section. I did this by:
Area = pi(r)^2
= pi(0.00125m)^2
= 4.91exp.-6 (I don't know why you added the 4, the area is only pi(r)^2)
Now I found the powre in watts, 3.2mW = 0.0032W
Now I divided the power by area to get intencity:
I = Power / (pi(r)^2)
= 0.0032W / 4.91exp.-6
I = 652 W/m2
Can someone show me where I went wrong, or is the book wrong. I hope I've been a help.
stimpyzu said:
Hello everyone!
Thanks!
I also got 652 using Nenad's equation.
The inverse square law applies to light radiated in all directions. The reduction in intensity is because the same amount of light is covering an ever expanding area. With a laser, you're sending the light in a straight line (theoretically, at least). The light beam covers the same amount of area 10 miles from its source as it did when it first left the laser.
All the lasers I know about have some sort of laser cavity where the photons make many circuits (n) between reflective ends. The effective geometry has the photons that do not exit out of the sides of the cavity traveling a distance of n times the length of the cavity before exiting the laser and forming the beam.
For a He-Ne laser, the cavity might have a length of 25 cm and a photon might make 5 circuits on average before joining the beam. The distance traveled is then 2.5 m and since the aperature is 2.5 mm, the beam divergence is 1 milliradian.
I say the laser does obey the inverse square law, but you have to consider the distance traveled within the laser. For the above example, the beam width should double and the beam intensity should go to a quarter at a distance of 2.5 meters from the end of the laser ( 5 meters from the "point" of origin of the photons.)
Note that I am probably off by a factor of two since the photons do not originate from a point source but from an extended source with dimensions probably equal to that of the laser aperature (2.5 mm in the example.)
Regards,
Everett
Thanks guys, I really appreciated your input. It helped a lot. What a friendly bunch you guys are in this forum!
Thanks a million!
The inverse square law applies only to isotropic light sources. A laser is highly directional and thus does not obey the inverse square law.
Claude.
  • · Replies 18 ·
  • · Replies 17 ·
