 Quote by Lok
On the thick slit, the abnormality might be explained by reflections between the 2 surfaces. That is usually why slits are thin.
The into the laser photos, is there any slit, aperture anything? how about the cameras aperture it has it's own effects.
Btw. One simple and clear way to see double slit patterns is through your eyelashes. while looking to a small source of light ( light bulb at 5m) close your eyes a bit so you see through your eyelashes. The pattern will appear in rainbow colors as the light has most of the visible in it.
thanks for your reply,the banding is no different just more of them,the photos in to the laser was straight in to laser (still had lens in laser) with dig cameras the processer (i think)likes to hex shapes that are round,with the pin hole shot i loaded at end of video it took 8 or 9 times to get the pin hole to look round and not hex,you can see the banding,i had also found out you dont need to shine laser through the slit,shine it on to a wall 5 feet or 10 or 20 and look through the slit at the dot,i also found out if you hold a double slit to your eye and hold up a lens the slit focas the immage,the strange thing is when the lens is removed the experiment dont work,you get banding inside the slit,like you see if you hold the slit to your eyes,
any more comments welcome
