| Thread Closed |
A glance beyond the quantum model |
Share Thread | Thread Tools |
| Feb2-10, 10:35 AM | #1 |
I wanted to follow up on a couple of specific points that were raised in another thread, and felt it would be better to split the discussion off here. The references for the discussion are:
A glance beyond the quantum model, Navascues and Wunderlich (2009) "One of the most important problems in Physics is how to reconcile Quantum Mechanics with General Relativity. Some authors have suggested that this may be realized at the expense of having to drop the quantum formalism in favor of a more general theory. However, as the experiments we can perform nowadays are far away from the range of energies where we may expect to observe non-quantum effects, it is difficult to theorize at this respect. Here we propose a fundamental axiom that we believe any reasonable post-quantum theory should satisfy, namely, that such a theory should recover classical physics in the macroscopic limit. We use this principle, together with the impossibility of instantaneous communication, to characterize the set of correlations that can arise between two distant observers. Although several quantum limits are recovered, our results suggest that quantum mechanics could be falsified by a Bell-type experiment if both observers have a sufficient number of detectors. " ...And a recent comment on the above (by a PF member no less :) Comment on "A glance beyond the quantum model", Peter Morgan (2010) "The aim of "A glance beyond the quantum model" [arXiv:0907.0372] to modernize the Correspondence Principle is compromised by an assumption that a classical model must start with the idea of particles, whereas in empirical terms particles are secondary to events. The discussion also proposes, contradictorily, that observers who wish to model the macroscopic world classically should do so in terms of classical fields, whereas, if we are to use fields, it would more appropriate to adopt the mathematics of random fields. Finally, the formalism used for discussion of Bell inequalities introduces two assumptions that are not necessary for a random field model, locality of initial conditions and non-contextuality, even though these assumptions are, in contrast, very natural for a classical particle model. Whether we discuss physics in terms of particles or in terms of events and (random) fields leads to differences that a glance would be well to notice. " ---------- Of interest - and there has been recent discussion about several of these points - are the following: a) Can you speak of particles without discussing the associated fields? b) Are the fields themselves discrete or continuous? c) It the correspondence between the macroscopic world and the microscopic world fundamental? Can we recover certain classical concepts - such as "no-signaling principle" or the introduced idea of "macroscopic locality" when a large number of particles are involved and our measurement devices fail to resolve discrete particles? d) Are their low-energy Bell-type experiments that can set limits on the unification of quantum theory and gravity? e) Anything else you might think of from the above...
| Feb2-10, 12:27 PM | #2 |
b) One can work with either discrete or continuous mathematics. QFT on a lattice has certainly taught us stuff. Universality makes it difficult to make a categorical statement here, because discrete structure at the Planck scale would presumably be washed out at the scales at which we have any present hope of making measurements. c) I think I take the Correspondence Principle to be a methodological requirement that comes from social issues in science. If one wants a new theory to get a running start, it helps to be able to point out how it is the same as and how it is different from the theories we currently take to be empirically effective. If one can show that the new theory can legitimately adopt a lot of the empirical effectiveness of an existing theory, it leaves less to do to establish how the new theory is better. The Correspondence Principle was used with stunning effectiveness by the founders of the new quantum theory in the late 20s to constrain quantum theory, so it seems worthwhile to attempt the same sort of approach now. From a Correspondence Principle point of view, given that our current best theories are QFT and GR, it makes sense to stick with a field approach of some sort in attempts to construct new theories. The choice of an effective mathematical structure is important. Part of my enthusiasm for random fields is that they are a powerful generalization of classical differentiable fields that introduces the concept of probability in a mathematically correct way (whereas differentiable fields don't sit well with the measure theory), and which can be presented in a way that is very closely parallel to quantum fields. Retrospectively, a random field formalism might make a Correspondence Principle approach more possible. However, this does not, to my more-or-less empiricist approach, entail that the world is continuous, only that it can be useful to use continuum mathematics, always supposing that we can get finite answers out, somehow. d) Dunno. When I critiqued Navascués' and Wunderlich's assumptions I was careful not to get into the actual purpose of their paper because I know not much about QG. ![]() e) Even less to say. Except that I believe the published version of the Navascués and Wunderlich paper is free to access on Proc. Roy. Soc. A, at http://rspa.royalsocietypublishing.o...t/466/2115/881, and is preferable, from the point of view of my Comment, because they introduced classical fields into their paper only after the current arXiv version. |
| Feb2-10, 06:15 PM | #3 |
Recognitions:
namely the problem of IR divergences in QED, and correct identification of the asymptotic dynamics, and hence also the asymptotic fields. (I'm not sure whether what follows is tangential to your focus in this thread, but I guess you'll tell me if so. :-) In brief, I find it interesting that considering charged particles together with their Coulomb fields seems to solve the IR problem in QED in a much more physically satisfactory way than the typical textbook treatments. This (imho) lends credence to the proposition that it's better to treat particles together with their entourage of associated fields, although such composite dressed entities are of course nonlocal. For those who want more detail, here's an extract from a summary I've been writing up for myself about it... ----------------------------- Textbook treatments of the infrared (IR) divergences in quantum electrodynamics (QED) typically introduce a small fictitious photon mass to regularize the integrals. Allowing this mass to approach zero, it becomes necessary to sum physically measurable quantities, such as the cross sections for electron scattering, over all possible asymptotic states involving an infinite number of soft photons, yielding the so-called "inclusive" cross section. The IR divergences are thus dealt with by restricting attention only to these "IR-safe" quantities such as the inclusive cross section. However, various authors have expressed dissatisfaction with this state of affairs in which the cross sections become the objects of primary interest rather than the S-matrix. The seminal paper of Chung (Chu) showed how one may dress the asymptotic electron states with an operator familiar from the Glauber theory of photon coherent states, thereby eliminating IR divergences in the S-matrix to all orders for the cases he considered. In a series of papers, Kibble (Kib1,Kib2,Kib3,Kib4) provided a much more extensive (and more rigorous) development of Chung's idea, solving the dynamical problem to show that IR divergences are eliminated by dressing the asymptotic electron states by coherent states of soft photons. Kibble constructed a very large nonseparable state space, within which various separable subspaces are mapped into each other by the S-matrix, but there is no stable separable subspace that is mapped into itself. Later, Kulish & Faddeev (KulFad) ("KF'" hereafter) gave a less cumbersome treatment involving modification of the asymptotic condition and a new space of asymptotic states which is not only separable, but also relativistically and gauge invariant. They were able to derive Chung's formulas without the laborious calculations of Kibble, yet also obtained a more satisfactory generalization to the case of arbitrary numbers of charged particles and photons in the initial and final states. KF emphasized the role of the nonvanishing interaction of QED at asymptotic times as the source of the problems. This inconvenient fact means that QED's asymptotic dynamics is not governed by the usual free Hamiltonian [tex]H_0[/tex], so perturbative approaches starting from such free states are singular (a so-called "discontinuous" perturbation). Standard treatments rely on the unphysical fiction of adiabatically switching off the interaction, but KF wished to find a more physically satisfactory operator governing the asymptotic dynamics. Much earlier, Dirac (Dir55) took some initial steps in constructing a manifestly gauge-invariant electrodynamics. The dressing operator he obtained is a simplified version of those mentioned above involving soft-photon coherent states, but he did not address the IR divergences in this paper. Neither Chung, Kibble, nor Kulish and Faddeev cite Dirac's paper, and the connection between explicit gauge invariance and resolution of the IR problem did not emerge until later. (Who was the first to note this??) In 1965 Dirac noted (Dir65, Dir66) that problems in QED arise because the full gauge-invariant Hamiltonian is typically split into a "free" part [tex]H_0[/tex] and an "interaction" part [tex]H_I[/tex] which are not separately gauge-invariant. Indeed, Dirac's original 1955 construction had resulted in an electron together with its Coulomb field, which is clearly a more physically correct representation of electrons at asymptotic times: a physical electron is always accompanied by its Coulomb field. More recently, Bagan, Lavelle and McMullan (BagLavMcMul-1, BagLavMcMul-2) ("BLM" hereafter) and other collaborators have developed these ideas further, applying them to IR divergences in QED, and also QCD in which a different class of so-called "collinear" IR divergence occurs. (See also the references therein.) These authors generalized Dirac's construction to the case of moving charged particles. Their dressed asymptotic fields include the asymptotic interaction, and they show that the on-shell Green's functions and S-matrix elements for these charged fields have (to all orders) the pole structure associated with particle propagation and scattering. -------------------------------------------- Bibliography for the above: \bibitem{BagLavMcMul-1} E. Bagan, M. Lavelle, D. McMullan, "Charges from Dressed Matter: Construction", (Available as hep-ph/9909257.) \bibitem{BagLavMcMul-2} E. Bagan, M. Lavelle, D. McMullan, "Charges from Dressed Matter: Physics \& Renormalisation", (Available as hep-ph/9909262.) \bibitem{Bal} L. Ballentine, "Quantum Mechanics -- A Modern Development", World Scientific, 2008, ISBN 978-981-02-4105-6 \bibitem{Chu} V. Chung, "Infrared Divergences in Quantum Electrodynamics", Phys. Rev., vol 140, (1965), B1110. Also reprinted in (KlaSkag). \bibitem{Dir55} P.A.M. Dirac, "Gauge-Invariant Formulation of Quantum Electrodynamics", Can. J. Phys., vol 33, (1955), p. 650. \bibitem{Dir65} P.A.M. Dirac, "Quantum Electrodynamics without Dead Wood", Phys. Rev., vol 139, (1965), B684-690. \bibitem{Dir66} P.A.M. Dirac, "Lectures on Quantum Field Theory", Belfer Graduate School of Science, Yeshiva Univ., NY, 1966 \bibitem{Dol} J. D. Dollard, "Asymptotic Convergence and the Coulomb Interaction", J. Math. Phys., vol, 5, no. 6, (1964), 729-738. \bibitem{Kib1} T.W.B. Kibble, "Coherent Soft-Photon States \& Infrared Divergences. I. Classical Currents", J. Math. Phys., vol 9, no. 2, (1968), p. 315. \bibitem{Kib2} T.W.B. Kibble, "Coherent Soft-Photon States \& Infrared Divergences. II. Mass-Shell Singularities of Green's Functions", Phys. Rev., vol 173, no. 5, (1968), p. 1527. \bibitem{Kib3} T.W.B. Kibble, "Coherent Soft-Photon States \& Infrared Divergences. III. Asymptotic States and Reduction Formulas.", Phys. Rev., vol 174, no. 5, (1968), p. 1882. \bibitem{Kib4} T.W.B. Kibble, "Coherent Soft-Photon States \& Infrared Divergences. IV. The Scattering Operator.", Phys. Rev., vol 175, no. 5, (1968), p. 1624. \bibitem{KlaSkag} J. R. Klauder \& B. Skagerstam, "Coherent States -- Applications in Physics \& Mathematical Physics", World Scientific, 1985, ISBN 9971-966-52-2 \bibitem{KulFad} P.P. Kulish \& L.D. Faddeev, "Asymptotic Conditions and Infrared Divergences in Quantum Electrodynamics", Theor. Math. Phys., vol 4, (1970), p. 745 ----------------------------- |
| Feb2-10, 06:28 PM | #4 |
Recognitions:
A glance beyond the quantum model"random fields ... introducing the concept of probability in a mathematically correct way". Could you elaborate on the details of this point, and/or give specific places in your earlier papers where you discuss this, please? |
| Feb2-10, 08:15 PM | #5 |
I found your discussion of IR divergences interesting, and I've bookmarked it both for the discussion and for the references, but I regret that I can't speak to it at this point, except to say that I've never seen anything that makes dressed particles look conceptually simple enough (or, more specifically, algebraically simple enough -- though that's not a conceptual direction one necessarily has to take).
For a quantum field, some mathematical control (but not enough) is achieved by defining the quantum field to be an operator-valued distribution, not an operator-valued field, so that to construct an operator one has to "average" the quantum field over a finite region. As we consider smaller regions, the variance of such operators diverges, so if we try to talk about the quantum field at a point we find that, more-or-less, we would always observe either +infinity or -infinity, which isn't a good start for constructing a differentiable function. For the vacuum state of a free quantum field, the two point correlation function [tex]\left\langle 0\right|\widehat{\phi}(x)\widehat{\phi}(y)\left|0\right\rangle[/tex] is finite for [tex]x-y[/tex] non-zero, but diverges as [tex]x\rightarrow y[/tex], which is to say that the variance [tex]\left\langle 0\right|\widehat{\phi}(x)^2\left|0\right\rangle[/tex] is infinite. It's also to say that the correlation coefficient between the observed values at x and y is finite/infinity=zero, if we relinquish decent control of what limits we're taking. For interacting fields this only gets much worse, of course. For classical fields, when we introduce the classical probability density [tex]{\normalfont exp}(-\beta H(\phi))[/tex] of a thermal state we also find ourselves working with classical fields that are nowhere differentiable. I shouldn't say that there's no other way to deal with the situation, it can be managed, but random fields do deal with it pretty well, without introducing anything relatively exotic such as nonstandard analysis, for example. I've taken it to be useful to consider random fields because they can be presented as random-variable-valued distributions, or even as mutually commutative operator-valued distributions, which are close enough to quantum fields to make comparison of random fields and quantum fields very interesting. In comparison of classical differentiable fields with quantum fields it's hard to know how to start. Part of why this is good to do is that it does give a new way to think about quantum fields, even if the more ambitious hopes I have for my program don't work out. |
| Feb2-10, 09:30 PM | #6 |
Recognitions:
them to a state vector is technically illegal. They must be smeared with test functions to give bonafide operators. OK. introduce the concept of probability in a "mathematically correct way". My perception of your random fields (or should we say "Lie fields"?) is as an inf-dim Lie algebra parameterized by spacetime points, as we discussed a while back. But obviously I'm missing some crucial connection between this and probability. I need you to be more explicit/expansive on this point if I'm to understand... |
| Feb2-10, 10:25 PM | #7 |
All that is standard QM, albeit not in elementary terms. When we introduce joint observables [tex]\widehat{A}[/tex] and [tex]\widehat{B}[/tex], the difference between QM and random fields is only whether they always commute, which they do not for QM, but they do for a random field. In the random field case, the function [tex]\widetilde{P}(\lambda,\mu)=\omega(exp(i\lambda\widehat{A}+i\mu\widehat{ B}))[/tex] is a joint characteristic function, whereas it is not (in general) the Fourier transform of a positive function in the QM case (unless [tex][\widehat{A},\widehat{B}]=0[/tex], which will be the case if the two operators are constructed using only quantum field operators associated with mutually space-like regions). I hope this is at an appropriate level and helpful? I'm not sure it's an answer even if the level is OK, in which case sorry. I realize now that I should also note that IMO a random field and a quantum field are better considered as indexed by smooth functions on space-time, not indexed by space-time points. I find it helpful to think of the index functions as "window functions", which is the name this concept is given in signal processing. Learning to work intuitively with the concept of operator-valued distributions took me several years, but it seems obvious enough by now that I have trouble explaining. Sorry. |
| Feb2-10, 11:00 PM | #8 |
Recognitions:
but what is your [itex]\delta[/itex] in the above expression? |
| Feb2-10, 11:54 PM | #9 |
Hi strangerep,
Thank you very much for the interesting review of IR divergences and references. I am very interested in combining these ideas with the dressed particles approach of Greenberg and Schweber. Do you have any suggestions? Eugene. |
| Feb3-10, 02:00 AM | #10 |
Recognitions:
(And it would probably be too speculative for Physics Forums anyway. :-) Perhaps after you've had a look through the referenced papers we could discuss further in a separate thread, or privately. |
| Feb3-10, 06:44 AM | #11 |
[tex]\omega(exp(i\lambda\widehat{\phi}_f))= \omega(\sum_{k=0}^{\infty}\left[\frac{(i\lambda\widehat{\phi}_f)^k}{k!}\right])[/tex]. Except, urp, that there should be a factor of [itex]2\pi[/itex]. That seems a better way to introduce it. The expected values of [itex]\widehat{\phi}_f^k[/itex] are the moments of the vacuum state's probability density over [itex]\widehat{\phi}_f[/itex], giving us the characteristic function, which we can formally inverse Fourier transform to obtain the probability density. In practice, one constructs the characteristic function as a scalar function of [itex]\lambda[/itex], which for the free field vacuum would be a Gaussian, which inverse Fourier transforms into a Gaussian probability density. It does seem that what you have to say about IR divergences and dressed particles is pretty vague at the moment. A "discuss these papers" thread would seem reasonable to me, however, and it's generally a helpful discipline to pay attention to how speculative what we're doing is and to look for ways to rein it in. Indeed, I think that the path to my getting papers into journals is very much about that process, partly because anything that looks speculative is often picked on by referees as a reason to reject a paper that they only have general misgivings about. If you make no speculations, the referee's rejection letter is generally much more helpful, because they have to engage more with the paper to give a clear reason to reject it. At a grosser level, which I have often visited, editors can spot speculative from about a light-year away, so one then doesn't get as far as relatively more detailed feedback from a referee. Getting papers published is just making the speculation look well reasoned --- not getting rid of it, which IMO often makes for a boring paper. |
| Feb3-10, 07:35 AM | #12 |
| Feb3-10, 09:02 PM | #13 |
Recognitions:
Your random fields (and their noncommutative quantum generalization) are basically a generalization of certain concepts in classical statistical mechanics. Actually, let me quote some stuff from the draft book of Neumaier & Westra, arXiv:0810.1019v1, that (I think) relates to this way of looking at things... (This is from their sect 1.2...) quantities f are normally interpreted as functions over phase space (hence the Liouville measure above), your random fields are just over 4D spacetime (or rather over a space of test functions over 4D spacetime). (?) So I'm now trying to follow your criticism of Navascues and Wunderlich more carefully... But... in the online version (arXiv:0907.0372), which is all I have access to right now, I can't relate your quotes to their section numbering. I also can't find the mention of "continuous fields"? Is the Proc Roy Soc version different from the online version, and you were commenting on the former? |
| Feb3-10, 09:45 PM | #14 |
| Feb3-10, 10:59 PM | #15 |
Recognitions:
At the end of your comment paper, you say: "this comment does not touch Navascués’ and Wunderlich’s argument". So... you're not actually arguing against the essential results of NW's paper? But only the "little" flaw of using the phrase "continuous fields" rather than "random fields" ? |
| Feb4-10, 08:21 AM | #16 |
Getting the politeness right in a critical comment apparently evaded me, but I do think these are serious Physicists, running with a respectable idea, that we might look at what the Correspondence Principle might tell us about the Planck scale and beyond. I think it's a good idea to do that in principle, but I'm telling them that "Oh, I wouldn't start from there". That could be boring. What saves their paper, I think, and what made it possible for me to make my comment constructive, I hope, is that they introduce classical continuous fields. They do it half-heartedly, and they might even have been made to introduce fields because the referee said, "well, but what about fields?", but they do it. This is a potentially significant development, because the ways in which classical fields might be used to model Physics is underdeveloped. Good math approaches to QFT take it almost for granted that QFT is about fields, not about particles, particularly because of the Unruh effect, since about 20 years ago, say. Very few Physicists, however, take the obvious next step, which is that in that case we'd better find ways to talk about fields instead of about particles. A notable exception is Art Hobson, whose web-site has available a copy of the paper of his that I cite. He's concerned with how to teach QFT, and proposes to do it by emphasizing a field perspective. Andrei Khrennikov, who is a Mathematical Physicist who turned seriously to foundations of Physics about ten years ago, takes a similar line, but his mathematical methods and mine are very different. 't Hooft's approach is also similar but different, as also for Wolfram. Elze and Wetterich are two other hard Mathematical Physicists who are developing entirely different formalisms. Khrennikov, Elze, and Wetterich are developing fairly traditional stochastic differential equation methods, 't Hooft and Wolfram are developing finite automata models, in which the statistics are generated by simulation; I'm the only one, to my knowledge, who is seriously developing an algebraic presentation of random fields. A friend, Ken Wharton, is developing a view based on classical fields, with me trying to persuade him that he has to introduce probability in a mathematically decent way, and him dragging his heels, perfectly reasonably, because he doesn't like a metaphysics that includes probability. If I have a metaphysics, it is a metaphysics of statistics and ensembles rather than of probability, with my being content with a relatively loose, somewhat post-positivist relationship between observed statistics and the mathematics of probability, but we've been negotiating this fine point for a while. All this move to fields, and lattices, has more-or-less started to happen in the last ten years (although there's also Stochastic Electrodynamics, dating from the 60s, and Nelson's approach, too, from the 70s, but these are arguably problematic because they are preoccupied with fermions being particles, bosons being fields, and these programs, although I believe always continuing, have had significant hiatuses). As far as all these different approaches are concerned, I consider that mine has the most to gain from comparison with QFT, in a Correspondence Principle sort of way, because I can even show that a free complex quantum field is empirically equivalent to a free random field, so I'm especially happy to see NW talking about CP. Nonetheless, I would only claim that my approach gives a useful counterpoint to stochastic or lattice methods, not that my approach is correct. I wish not to claim that the world is continuous rather than discrete, for example. A random field, properly speaking, is only an indexed set of random variables, it is only associated with a continuous space-time if we specifically take the index set to be the Schwarz space of functions on space-time (or some other well enough controlled function space on space-time). So why should NW be pulled up for this rather than someone else, given that almost no-one pays any attention to how their use of particle-talk conditions their thinking? Their fault, I suppose, is that they mention fields so glibly, without thinking about how rich the seam is, and proceed with a discussion that would make almost no sense if they tried to accommodate both particle and field ways of thinking. At the very least, their conclusions would have to be hedged with a statement such as "if we think only in terms of particles, ...". NW's discussion of Bell inequalities is similarly conventional. If they did the job properly, they would know that the flow of ideas surrounding Bell inequalities has been shifting dramatically over the last 10 years, with roots that go back to about 1980. The relative significances of contextuality and of locality are gradually being teased out more and more clearly. Anybody trying to talk about Bell inequalities should at least acknowledge those currents, and again they should either accommodate the various possibilities or explicitly hedge their conclusions. As the last sentence of the abstract says, "Whether we discuss physics in terms of particles or in terms of events and (random) fields leads to differences that a glance would be well to notice." Perhaps I might add, even more facetiously, "or at least what is not noticed ought to be mentioned", but that would go far enough that I imagine the editors would have sent it back to me unrefereed. As it is, my comment is with referees; I hope they see that my criticism is constructive. |
| Feb4-10, 06:53 PM | #17 |
Recognitions:
my first thought was "what _precisely_ do they mean by that phrase"? (Such pedantic detail becomes important in discussions about "introducing probability in a mathematically correct way"...) So let me ask you the question... You've explained in earlier posts what you mean by a random field (i.e., an inf-dim commutative *-algebra, with basis elements indexed from a space of well-behaved functions over spacetime, such that state functionals over this algebra make sense). What then are your definitions of the phrases "classical field" and "continuous field" ? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: A glance beyond the quantum model
| quantum model of the atom | Quantum Physics | 5 | ||
| LA - Trace - Is this an elegant solution or an incorrect one? (Breif glance needed) | Calculus & Beyond Homework | 2 | ||
| simple average speed (quick glance should do the trick) | Introductory Physics Homework | 2 | ||
| RC Circuit (Quick Glance please, mostly theoretical) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| What is the quantum model? | Quantum Physics | 1 | ||
