Integrating Complexity: Solving \int \frac{1}{x^n(1+x^n)^{1/n}} \;\mathrm{d}x}
The discussion revolves around the integral \(\int \frac{1}{x^n(1+x^n)^{1/n}} \;\mathrm{d}x\), which falls under the subject area of calculus, specifically integration techniques. Participants are exploring various approaches to tackle this integral.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster expresses difficulty in starting the problem and seeks guidance on an initial substitution. Some participants suggest manipulating the expression by bringing terms to the numerator and question the implications of changing the sign of the exponent. Others share their attempts at substitutions, such as letting \(x^n = t\), and express confusion about the resulting integrals. There are also suggestions to use integration by parts and trigonometric substitution, with participants questioning the validity of their approaches and results.
The discussion is active, with participants sharing various attempts and questioning the correctness of their methods. Some guidance has been offered regarding potential substitutions and integration techniques, though there is no clear consensus on the best approach or solution at this stage.
Participants are navigating through different substitution methods and expressing uncertainty about the results. There is an indication of imposed homework rules, as some participants suggest using external tools for verification instead of providing direct answers.
Rats_N_Cats
An Integral : [tex] <br /> \int \frac{1}{x^n(1+x^n)^{1/n}} \;\mathrm{d}x}<br /> [/tex]
The Standard integrals.
I'm aware that integrals like this become very easy after a clever substitution...but maybe I'm not that clever :frown: so I can't even start it. If anyone shows me the first step I'll try to take it from there.
Fixed your latex:
[tex] \int \frac{1}{x^n(1+x^n)^{1/n}} \mathrm{d}x[/tex]
ideasrule said:
Fixed your latex:
[tex] \int \frac{1}{x^n(1+x^n)^{1/n} \mathrm{d}x}[/tex]
have you tried bring the (1+x^n)^(1/n) to the top? It would become (1+x^n)^n.
You've left the dx at the bottom :wink:
but how will it become [itex](1+x^n)^{n}[/itex]? Bringing it to the top will change the sign of the exponent, right?
Yes, I got confused. Sorry about that.
I tried letting xn = t, but that ended up with [tex] \frac{1}{n} \int \frac{1}{\sqrt[n]{t^2+t}}\:\mathrm{d}t[/tex], And I don't see how to do it.
Then I tried letting xn+1 = tn, and got something similarly unsolvable. Can anyone tell me what's the right substitution in this case?
Here's something:
[tex]\int x^{-n}(1+x^n)^{-1/n} \mathrm{d}x[/tex]
And integrate by parts from there. Dunno if it works, though. I tried it on W-A and they used a weird substitution within a substitution.
I did that, letting (1+xn)-1/n as first function, and I ended up with :
[tex] \frac{x^{1-n}}{1-n}\,(1+x^n)^{-1/n} + \frac{x}{1-n} + \frac{x^{n+1}}{1-n^2} + C[/tex]
Is that correct?
Maybe. I'm too tired to check now. It looks right.
Will anyone please confirm if my answer is correct or not? This problem's been bugging me for quite some time.
try trigonometric substitution
Hello!
What trig substitution can you make? PM me if the OP wants to work it out themselves.
Thanks!
  • · Replies 54 ·
19K
  • · Replies 22 ·
