Does My Polynomial Integral Equation Hold for All Polynomials?
The discussion confirms that the integral of a sum of polynomial functions can be expressed as the sum of their individual integrals. Specifically, the equation \int_{0}^{t} (ax^n + bx^{n-1} + cx^{n-2} + \cdots + ex) dx = \frac{at^{n+1}}{n+1} + \frac{bt^n}{n} + \frac{ct^{n-1}}{n-1} + \cdots + et holds true for all polynomials in standard form. This principle is established through the property that integration distributes over addition, allowing for the separation of terms in the integral.
  • Understanding of polynomial functions and their standard form
  • Knowledge of definite integrals and their properties
  • Familiarity with basic calculus concepts, particularly integration
  • Experience with mathematical induction as a proof technique
  • Study the properties of definite integrals in calculus
  • Learn about mathematical induction and its applications in proofs
  • Explore the concept of linearity in integration
  • Investigate advanced integration techniques for polynomial functions
Students and educators in mathematics, particularly those focusing on calculus, as well as anyone interested in the properties of polynomial integrals and their applications in mathematical proofs.
yyttr2
I have recently been playing with integrals and I still do not fully understand them.
Usually the best way for me to learn is to play with values and figure it out on my own, so I would like you (physics forum) to check my work so far.
After a bit of time I got this:
[tex]\int_{0}^{t}ax^ndx=\frac{at^{n+1}}{n+1}, n\neq-1[/tex]and after figuring out:
[tex]\int_{0}^{t}ax+bxdx=\int_{0}^{t}axdx+\int_{0}^{t}bxdx[/tex]
I got this equation.
[tex]\int_{0}^{t}ax^n+bx^{n-1}+cx^{n-2} \cdots +ex dx=\int_{0}^{t}ax^ndx+\int_{0}^{t}bx^{n-1}dx+\int_{0}^{t}cx^{n-2}dx \cdots +\int_{0}^{t}(ex)dx=\frac{at^{n+1}}{n+1}+\frac{bt^n}{n}+\frac{ct^n-1} {n-1} \cdots +et[/tex]
Is this true for all polynomials (in standard form)? or does it even work at all?
Hi yyttr2! :wink:
Yes, that's correct.
The integral of the sum is the sum of the integrals …
you can always split a sum (any sum, not just polynomials) into its separate parts, and integrate them separately. :smile:
(unless, of course, that requires you to add an ∞ and a minus ∞)
You can prove, in general, that
[tex]\int (f_1(x)+ f_2(x)+ \cdot\cdot\cdot+ f_n(x))dx= \int f_1(x)dx+ \int f_2(x)dx+ \cdot\cdot\cdot+ \int f_n(x) dx[/tex]
by induction on n.
  • · Replies 16 ·
  • · Replies 18 ·
