Acceleration at the center of circle
The discussion centers on calculating the acceleration at the center and at a point 1 cm from the center of a circle with a radius of 2 cm rotating at 1000 RPM. It is established that the acceleration at the center is zero, as it does not move. For the point 1 cm from the center, the correct formula to use is a = ω²r, where ω is the angular velocity derived from the rotation speed. The participants noted discrepancies in the provided acceleration value of 2 m/s², which is inconsistent with theoretical expectations.
  • Understanding of circular motion and angular velocity
  • Familiarity with the formula for centripetal acceleration
  • Basic knowledge of radians and revolutions per minute (RPM)
  • Ability to perform unit conversions (e.g., from RPM to radians per second)
  • Study the derivation of centripetal acceleration formulas
  • Learn how to convert RPM to angular velocity in radians per second
  • Explore the implications of acceleration in circular motion
  • Investigate common mistakes in physics problems involving rotation
Students studying physics, particularly those focusing on mechanics and circular motion, as well as educators looking for examples of common misconceptions in rotational dynamics.
songoku
A circle with radius 2 cm rotates at 1000 rpm and the acceleration at the rim is 2 ms-2.
a. What is the acceleration at the center ?
b. What is the acceleration at 1 cm from the center ?
a. The acceleration will be zero because the center doesn't move?
b. a = ω2r = 2πf*r = 2π * 1000/60 * 2 x 10-2 = 2/3 π ms-2. Is this right?
Thanks
Your answer for a seems to be right. The problem is that the acceleration at the rim of a circle with radius 2 cm that rotates with 1000 rpm is more than 100 times as high as [itex]2 m s^{-2}[/itex]
I don't see why the acceleration is given at all in the problem.
For part b you use [itex]\omega[/itex] instead of [itex]\omega^2[/itex] and a radius of 2 cm instead of 1 cm
Hi willem
Yeah, my mistake...now I know it's not a good idea to post question at 2 AM..
I also agree that the information given doesn't match the theoretical calculation...something wrong with the question...
Thanks a lot !
  • · Replies 25 ·
  • · Replies 35 ·
18K
  • · Replies 42 ·
