Questions about forces Newton's Laws (first law)
The discussion revolves around the implications of Newton's laws, particularly the first law, in the context of very small masses and their potential acceleration. Participants explore the relationship between force, mass, and acceleration, questioning the validity of Newton's laws when mass approaches zero.
  • Some participants suggest that if mass (M) approaches zero, then force (F) could also be zero, yet the object might still experience acceleration, raising questions about the applicability of Newton's laws.
  • Others argue that zero force does not imply zero acceleration, and that zero acceleration implies zero force, but not vice versa.
  • A participant points out that Newton's first law states that an object in motion remains in motion unless acted upon by a force, which seems to contradict the idea of acceleration without force.
  • Some contributions reference the relativistic context, suggesting that the situation becomes more complex when considering massless particles, such as photons, and their behavior under force.
  • There are discussions about whether Newton's laws hold true for massless particles and how they relate to energy and momentum.
  • One participant attempts to derive equations involving force and momentum, indicating the complexity of the relationships involved when mass approaches zero.
Participants express differing views on the implications of having a mass of zero in relation to Newton's laws. There is no consensus on whether Newton's laws are valid in general for massless objects, and the discussion remains unresolved regarding the interpretation of acceleration and force in these scenarios.
Some participants note that the assumptions about mass and force may depend on the context of classical versus relativistic physics, and that the discussion involves unresolved mathematical steps and definitions.
This discussion may be of interest to students and enthusiasts of physics, particularly those exploring the nuances of classical mechanics and relativistic effects on motion and force.
holezch
Hi, it is known that all bodies moving with a velocity will remain moving with a constant velocity unless a force is applied to a body. (according to Newton's laws). But I thought about this:
F = Ma. But if we had a very very very very small object (hypothetically), we could virtually take M = 0 and F = 0, but this small object may still have an acceleration. This is probably okay, since M = 0 can only an approximation - but it does seem like it goes against the law stated above.. (that the acceleration may be somewhat independent of the force) . I just wanted to point this out and I hope someone will set me right. thanks
Science news on Phys.org
holezch said:
F = Ma. But if we had a very very very very small object (hypothetically), we could virtually take M = 0 and F = 0, but this small object may still have an acceleration...
Acceleration due to what?
Why should this object be accelerating?
but if force is equated as F = Ma, zero force doesn't imply zero acceleration , zero acceleration implies zero force, but not the other way around
All you are saying is:
- There is a very very small mass M close to 0.0
- Oh by the way it is accelerating...at a
Therefore if F=Ma, then F is close to 0.0...!
So what about it?? For a very very small mass M, it does not take much force to create an acceleration a :) ...so can't you you can imagine that an F close to 0 can accelerate a M close to 0, at a...?
right, that's true. I was just taken aback because I was looking at a problem solution that assumed that the acceleration was zero, because the force was zero (the object was stated to be really really small in the question) thanks
First of all, you need to realize that Isaac Newton wrote
[tex]F=\frac{d p}{d t}[/tex]
Before Relativity showed that not all time is the same for all observers, you could use
[tex]p = m v[/tex]
to get
[tex]F = \frac{d p}{d t} = \frac{d \left( m v \right)}{d t} = m \frac{d v}{d t} = m a[/tex]
Now, if [tex]m \neq 0[/tex] no matter how small, then for non-relativistic type motions with F=0, then clearly
[tex]F = 0 = m a[/tex]
means that a=0 also (since [tex]m \neq 0[/tex]). Hence, v=constant; and so Newton's first law remains valid.
For m=0 and relativistic motion, the situation becomes more complicated, but I don't think you were asking about that.
73s and clear skies.
If we allow the possibility that m = 0, then, as far as I can see, Holezch is right to say that "if force is equated as F = Ma, zero force doesn't imply zero acceleration, zero acceleration implies zero force, but not the other way around". In that case,
[tex]F = ma \text{ and } F = 0[/tex]
don't, on their own, imply [itex]a = 0[/itex], although Newton's first law does say no acceleration without force in an inertial frame, so maybe that's what the problem solution was relying on. I suppose that implies no acceleration for a massless particle, since no mass implies no force, and no force implies no acceletation.
But are Newton's laws valid in general for m = 0?
Yes, an example is the force-free photon. From Special Relativity we have
[tex]E^2=p^2 c^2 + m^2 c^4[/tex]
and for the photon from experiment
[tex]p=\frac{E}{c}[/tex]
so that [tex]m=0[/tex] for the photon.
Newton's second law is
[tex]F\equiv\frac{d p}{d t}=\frac{1}{c}\cdot\frac{d E}{d t}=\frac{P}{c}[/tex]
where P=power dissipated by the photon.
When no power is dissipated, then
[tex]F\equiv\frac{d p}{d t}=0[/tex]
which means that p is constant. Thus the p-vector never changes and so the photon continues in a straight line with speed c just as Newton's first law says.
Here's my attempt, but I didn't really get anwhere. Let F be 3-force, and p 3-momentum, then
[tex]\textbf{F} = \frac{\mathrm{d} \textbf{p}}{\mathrm{d} t} = m_0 \frac{\mathrm{d} }{\mathrm{d} t}\left ( \gamma \textbf{v} \right ) = m_0 \frac{\mathrm{d} \gamma}{\mathrm{d} t} \textbf{v}\right + m_0 \gamma \frac{\mathrm{d} \textbf{v}}{\mathrm{d} x},[/tex]
which, unless I've made a mistake (quite possible!), gives
[tex]\textbf{F} = m_0 \gamma \left ( \textbf{a} - \frac{\gamma v \textbf{v}}{\sqrt{c^2 - v^2}} \right ).[/tex]
But as [itex]v \rightarrow c, \enspace \gamma \rightarrow \infty[/itex], so we'd have
[tex]\textbf{F} = 0 \infty \left ( \textbf{a} - \frac{\infty v \textbf{v}}{\infty} \right ).[/tex]
Argh... unless there's some meaningful way to find the limit?
[tex]\lim_{m_0 \rightarrow 0, v \rightarrow c} m_0 \gamma \left ( \textbf{a} - \frac{\gamma v \textbf{v}}{\sqrt{c^2 - v^2}} \right ).[/tex]
Can a photon be affected by a force and change in energy, and if so, is the effect of force on a photon only to change its energy, rather than its trajectory?
Either way. Note that if [tex]\stackrel{\rightarrow}{p}[/tex] changes then it can change either in magnitude or direction, or even both.
I tried to reply earlier and evidently the reply got bounced off somewhere. So if there is another answer, I apologize.
Except for a minor typo, it's good.
I got
[tex]\textbf{F} = m_0 {\left ( \gamma \textbf{a} + {\gamma}^3 \textbf{v}\frac{\textbf{v}\cdot\textbf{a}}{c^2} \right )}[/tex]
This can be decomposed into
[tex]\textbf{F} = \textbf{F}_\perp + \textbf{F}_\parallel[/tex]
where [tex]\textbf{F}_\perp}=\gamma m_0 \textbf{a}[/tex] corresponds to [tex]\textbf{v}\cdot\textbf{a}=0[/tex] and [tex]\textbf{F}_\parallel={\gamma}^3 m_0 \textbf{a}[/tex] corresponds to [tex]\textbf{v}\cdot\textbf{a}={v a}[/tex]
In either case, Newton's first law remains valid.
Is that 4-momentum or 3-momentum? The magnitude of a photon's 4-momentum, being its rest mass, is always 0, right? So, I guess you mean 3-momentum here.
Take two:
[tex]\frac{\mathrm{d} \mathbf{p}}{\mathrm{d} t} = m_0 \frac{\mathrm{d} }{\mathrm{d} t}\left ( \gamma \mathbf{v} \right ) = m_0 \left [ \frac{\mathrm{d} \gamma}{\mathrm{d} t} \mathbf{v} + \gamma \frac{\mathrm{d}\mathbf{v}}{\mathrm{d} t} \right ].[/tex]
And
[tex]\frac{\mathrm{d} \gamma}{\mathrm{d} t} = \frac{\mathrm{d}}{\mathrm{d}t}\left ( \frac{1}{\sqrt{1-\left ( \frac{v}{c} \right )^2}} \right ).[/tex]
Let
[tex]z=\frac{v}{c}, \enspace y=1-z^2, \enspace x=y^{-1/2},[/tex]
so that
[tex]\frac{\mathrm{d} \gamma}{\mathrm{d} t}=\frac{\mathrm{d} x}{\mathrm{d} y} \frac{\mathrm{d} y}{\mathrm{d} z} \frac{\mathrm{d} z}{\mathrm{d} v} \frac{\mathrm{d} v}{\mathrm{d} t} = \left ( -y^{-3/2} \right ) \cdot \left ( -2z \right ) \cdot \frac{1}{c} \cdot \frac{\mathrm{d} v}{\mathrm{d} t}[/tex]
[tex]= \frac{2v \gamma^3}{c^2} \frac{\mathrm{d} v}{\mathrm{d} t} = \frac{2av \gamma^3}{c^2}.[/tex]
That gives
[tex]\textbf{F} = \frac{\mathrm{d} \textbf{p}}{\mathrm{d} t}= \gamma m_0 \left [ \frac{2av \gamma^2}{c^2} \textbf{v} + \textbf{a} \right ].[/tex]
And the part of force parallel to acceleration is
[tex]\textbf{F}_\parallel = \gamma m_0 \textbf{a},[/tex]
so the part perpendicular to acceleration must be
[tex]\textbf{F}_\perp = \frac{2avm_0 \gamma^3}{c^2} \textbf{v},[/tex]
which, I think, implies [itex]\textbf{v} \cdot \textbf{a} = 0[/itex] or [itex]m_0 = 0[/itex], in which latter case [tex]\textbf{F} = 0[/itex]. So acceleration is always perpendicular to velocity in an inertial frame? But we know that it's not, so I must have got something wrong.<br /> <br /> I don't understand what happened to the 2 in your version, and I'm not sure how you equate [itex]av[/itex] with [itex]\textbf{a} \cdot \textbf{v}[/itex]. This will be true when velocity and acceleration are parallel, which will be true when both are the zero vector. And velocity and acceleration could be parallel when [itex]\textbf{F} = \textbf{0}[/itex]. But I don't understand how it can be true in general, given that the equation says mutually orthogonal parts of [itex]\textbf{F}[/itex] point in the directions of [itex]\textbf{v}[/itex] and [itex]\textbf{a}[/itex].<br /> <br /> Is this equation for a frame comoving with this body being accelerated? If so, I suppose it can't be applied to body moving at c, and hence not to a massless particle if we start with the assumption that a massless particle must move at c.[/tex]
If it is known that, all bodies moving with a velocity remain moving with a constant velocity unless a force is applied to a body. (According to Newton’s laws). WHAT force {strength} is moving these bodies ? In addition, has this theory ever been done in a real live air tight vacuum, without and gravity effecting it ? I would think not, as it would have to be as big as our World. Thus how do we know it is true, and as I said, after the acceleration, what force is then being applied to keep the body in a constant speed ? As nothing moves without a force.
If the Moon is able to move the tides, why are we weightless and hardily move in the space, I mean the space between us and the Moon ? As if the gravity of the Moon pulls Millions of tons of water, why does it not pull us ?
Wayne
This question makes no sense because it contradicts what you said in your first sentence. Do you see it?
Zz.
Zz.
But I said "if" its known.
Wayne
Wayne
So Newton's laws are still in doubt with no verifiable experimental evidence? Run out of your house immediately!
Zz.
Zero force! It goes against our earthbound intuitions, but it's proved a very useful point of view. You can just as well choose a reference frame (coordinate system) that's moving at the same constant velocity as the object; in other words, a coordinate system in which the object isn't moving, and Newton's laws will work just the same.
Newtonian mechanics is very well tested, as you'll find if you do a bit of reading. It works well within its area of application. According to the definitions it uses, force is not necessary for an object to move, only for the object's velocity to change.
The tides are caused by the difference in the moon's gravitational influence on the far side of the Earth (where it's weaker) and the near side (where it's stronger). The moon's gravity doesn't differ much in strength from one side of a little space capsule to another.
If that pesky moon hasn't already dragged you out of it...
What coordinate system in which the object isn't moving ? As this whole universe is expanding, thus moving. In addition, the Big Bang caused everything to move.
I am saying that in a vacuum, with no air resistance and no gravity, so if it is known that, all bodies moving with a velocity remain moving with a constant velocity unless a force is applied to a body. (According to Newton’s laws). WHAT force {strength} is moving these bodies ? No one stated force {strength} is moving these bodies ? As bofies can not move without a force {strength}
So if an object stood still, but object's velocity to changed, both speed and direction are required to define velocity, so So if an object stood still, but object's velocity to changed it would move ? but what made its velocity change ?
And what if a force accelerated something, what other force would make it carry on moving ? How can a object move without a force {strength} keep it moving ? Are you talking free fall ? But in space there is no free fall, as objects just float, thus if I gave you a shove in space you would move, but like Astrunauts do, but then slow down.
Yes but if I was in the middle, why does not the moon's gravity pull on me ?
Wayne
What physics caused you to day this? This contradicts Newton's first law, and it isn't based on any physics. So what are you basing this on? A body is supposed to move with constant velocity UNLESS a force acts on it.
This is very puzzling because you contradict yourself in the same paragraph. It requires NO FORCE to for an object to continue moving with the same velocity.
Zz.
I am saying that in a vacuum, with no air resistance and no gravity, so if it is known that, all bodies moving with a velocity remain moving with a constant velocity unless a force is applied to a body. (According to Newton’s laws). WHAT force {strength} is moving these bodies ? No one stated force {strength} is moving these bodies ? As bodies can not move without a force.
{strength}
Zz.
Yes but why does it require NO FORCE to for an object to continue moving with the same velocity ? So if no force {strength} is needed to keep it moving, how does it move without a force {strength} Why ? But then again physics seems to say it needs a force {strength} to start it moving.
Wayne
Wayne
To start moving, yes. To continue moving with a constant velocity requires NO FORCE! Newton's First Law!
Maybe you should be the one who answers the question why would it needs a force to stay moving with a constant velocity.
Zz.
Zz.
Ok, so you are saying that no one knows why ? The point I was trying to make and get at, and please sorry if I sounded rude, or got of your or anyone’s nerves, I did not mean to, but as no force {strength} is needed, this seems to be going against all physics laws, as is it being moved by magic ? Well of course, not you will say no.
Ok, this does not happen, if there is air resistance, so for now that is our clue. In addition, has gravity got anything to do with it ? Alternatively, maybe whatever object you push to a certain speed, just follows on the rest of the moving Universe.
Hold on just thought of something, as there is not air in space, so why have they not tried this experiment there ? But look at this videos, Newton's First Law does not seem to be working, as the tool bag drifted off, but then stopped and just stayed there ? And the camera did.
http://www.youtube.com/watch?v=fTBFlSwtBKc&feature=related
Or maybe it is one of those things like how/why did our little Universe start out with so nearly the critical rate of expansion. And even now Billions of years after what we call the Big Bang it’s still expanding at nearly the critical rate ?
Wayne
Wayne
It is sad that you are using youtube videos as valid experiments. Would you like to see 'evidence' that cell phone signals can make popcorn pop? Do you not care about the validity of your sources?
You need to look up symmetry principles, especially something on translational symmetry principle of our universe. And note also that Newtonian laws are invariant when you transform from one inertial frames to another. This means that if you don't see a force in the rest frame where an object is stationary, transforming it to another inertial reference frame where that object is in motion should NOT result in the presence of a force. Having otherwise will not make any physical sense. That is why I said that it is YOU who has the explaining to do, not me.
You should NOT confuse yourself with the spacetime expansion that is connected to the Big Bang. That has nothing to do with motion within spacetime itself, which is what this is all about. This is more elementary.
Zz.
Zz.
Hi and thx, it a bit late here for a full repply, and will double read what you wrote again, however, that was a real spacewalk by NASA.
Wayne
Wayne
My reply has nothing to do with the video. My reply was on the NATURE of the source.
Besides, how such a video can somehow be used to argue for what you're saying is rather puzzling. I don't quite know why it would even be relevant here.
Zz.
Zz.
Hi ZapperZ,
Well the video was in a real life situation, deep in the middle of space with no air. And this is where Newton’s Law should have worked. But it did not, or am I missing something ? As the 2 object went off, but did not keep going on at the same speed, they slowly stoped. Showing that all bodies moving with a velocity do not remain moving with a constant velocity unless a force is applied to a body. (According to Newton’s laws).
Wayne
waynexk8 said:
Hi ZapperZ,
Wayne
Then I suggest you write to NASA, and tell them that one of their videos have violated Newton's laws, and ask for an explanation. Tell them too that they should use this new discovery to maneuver the space shuttle, rather than use those darn pesky thrusters that obviously make use of the outdated Newton's laws.
Zz.
  • · Replies 16 ·
  • · Replies 17 ·
  • · Replies 62 ·
  • · Replies 26 ·
