What is the tension in string 1 when string 2 breaks?
The problem involves two blocks, m1 and m2, connected by strings, with a focus on determining the tension in string 1 (T1) when string 2 (T2) breaks. The scenario is set on a flat surface, and friction is not considered.
  • Participants discuss the implications of T2's value at the moment before it breaks and question whether T1 remains constant immediately after the break. There is also consideration of the nature of the force acting on the blocks and how it affects T1.
The discussion is active, with participants exploring different interpretations of the problem and clarifying assumptions about the forces involved. Some guidance has been provided regarding the focus on T1 just before the break of string 2.
Participants note the absence of information regarding the nature of the force acting on the blocks, which could influence the calculations for T1 after string 2 breaks.
spursfan2110
Hey, I'm just a tad confused about tension and how it works...
Two blocks m1 (11 kg) and m2 (18 kg) are connected by strings, as shown in the below. String 2 breaks when T2 = 4.9033 N. Find T1 when string 2 breaks.
Answer in units of N. (Blocks are on a flat surface, not hanging)
m1----(T2)-----m2----(T1)---->
F = ma
Not sure if any others are necessary, I don't believe so. Friction not included in this problem.
Before the string snaps, if T2 = 4.9033 N, at that point, the acceleration of m1 = T2/m1 = .44575454545 m/s/s. I assume acceleration across the whole system would be the same, making the T1 = (18 kg + 11 kg)(.445754545 m/s/s), but I am completely stuck on what happens after the string breaks...does the acceleration remain the same and make T1 = .445754545 m/s/s * 18 kg = 8.02358 N?
Also, its my first time here, did I include enough relevant info in my post? Any feedback greatly appreciated, thanks!
I think the question is asking what T1 is the moment before string 2 breaks, not the moment after. I think it's reasonable to assume that T1 stays the same the moment after the other string breaks; after all, whatever is applying the force can't instantly change the force it applies.
Why are you worried about what happens after the string breaks? I think all they want is the value of T1 at the moment that the string breaks (or just before), which you already figured out.
You haven't told us what the nature is of the force that's pulling on both masses. If it's a constant force then your first andwer would be right. If it's a mass hanging off the end
of the table, you would have to know the mass.
Sure enough...that's right. Thank you very much. I think I over-thunk it...
Theoretically, what would you have to do to calculate T1 after it broke?
@willem2, it was a constant horizontal force.
As willem2 notes, it depends on how the force T1 is applied. If you can assume that T1 is fixed, then you're done. Otherwise, you'll have to see what changes.
Thank you all :)
  • · Replies 33 ·
