Pressure & Stress: Definition and Relationship
  • Context: Graduate
  • Thread starter Thread starter Rasalhague
    Pressure Stress
The discussion revolves around the definitions and relationships between pressure and stress in physics, exploring their mathematical formulations and implications. Participants examine the nature of pressure at a point, the role of area in defining pressure and stress, and the conceptual understanding of force as a vector field versus pressure as a scalar quantity.
  • Some participants question why pressure at a point is not generally zero, given the definitions involving limits and areas.
  • There is a discussion about the relationship between force and area, with some arguing that the force should decrease as the area decreases, while others challenge this notion.
  • One participant clarifies that by "p," they meant momentum, leading to confusion regarding the units and definitions used in the discussion.
  • Some participants propose that pressure is a scalar quantity, while others suggest that the concept of pressure may involve vector fields.
  • There is a debate about the implications of the derivative definitions and whether they lead to infinite pressure at a point or zero, depending on how force is treated in relation to area.
  • Participants explore the idea of force as a vector field and how it relates to pressure, with some suggesting that pressure could be viewed as a field that produces force.
  • One participant mentions the concept of momentum flux and questions how it relates to the definitions of pressure and force.
Participants express differing views on the nature of pressure and its relationship to force, with no consensus reached on whether pressure can be defined at a single point or how it should be conceptualized in relation to force. The discussion remains unresolved regarding the implications of the mathematical definitions presented.
Participants note that the definitions of pressure and stress involve limits and derivatives, which may lead to confusion about their behavior as areas approach zero. There are also unresolved questions about the nature of force as a vector field versus pressure as a scalar quantity.
Rasalhague
If pressure at some point on a surface is defined, as here ( http://en.wikipedia.org/wiki/Pressure ), as
[tex]\frac{\mathrm{d}||F_n||}{\mathrm{d}A}[/tex]
(apparently meaning the rate of change wrt area of the magnitude of force normal to the specified surface), why is pressure at a point not, in general, 0? How does the force at a point in space depend on the size of an area, given that no area appears in the definition of force
[tex]\textbf{F} = \frac{\mathrm{d} \textbf{p}}{\mathrm{d} t}.[/tex]
Likewise, a stress vector (traction vector) for a given surface is defined here ( http://en.wikipedia.org/wiki/Stress_(physics) ) as
[tex]\frac{\mathrm{d} \textbf{F}}{\mathrm{d}A},[/tex]
but, given the force acting at a point, how is the force at that point changed at all by changing the value of [itex]A[/itex] in the equation?
Alternatively, if the magnitude of the force perpendicular to the an area is denoted by [itex]\Delta F[/itex] (Fishbane et al.: Physics, 2nd ed., p. 436), and pressure p defined thus:
[tex]p = \lim_{\Delta A \rightarrow 0} \frac{\Delta F}{\Delta A} = \frac{\mathrm{d} F}{\mathrm{d} A},[/tex]
why isn't pressure always infinite at every point, given that for any choice of point, as one choses a smaller area to divide it by, that choice should have no affect on the magnitude of a vector belonging to a force field, nor on its normal component, since what is changing is only the area we're choosing to divide the magnitude of the force by, and not the orientation of the surface.
Where did "F = dp/dt" come from? The units seem all wrong! (Have you defined what the symbols stand for?)
The Units for stress are, as you say, the same as the units of pressure: force/area
As with all differential calculus, dy/dx is the limit of the ratio as dx goes to zero.
So the force per unit area is still finite because that is the limit when an ever decreasing force divided by an ever decreasing area. The force at a point is infinitessimal.
Sorry, I should have defined my symbols. By p, I meant momentum, which unfortunately is traditionally given the same letter as pressure. I'm using bold letters to represent vectors though.
[tex]\textbf{F} = \frac{\mathrm{d} \textbf{p}}{\mathrm{d} t} = \frac{\mathrm{d}}{\mathrm{d} t} \left ( m\textbf{v} \right ) = m \frac{\mathrm{d} \textbf{v}}{\mathrm{d} t} = m\textbf{a}[/tex]
where m is mass, t is time, v velocity, and a acceleration (supposing that mass is constant with time). The units on either side are Newtons = kg m s-2.
sophiecentaur said:
As with all differential calculus, dy/dx is the limit of the ratio as dx goes to zero. So the force per unit area is still finite because that is the limit when an ever decreasing force divided by an ever decreasing area. The force at a point is infinitessimal.
Why does the force decrease as the area does?
In the definition of the derivative dy/dx, if y isn't actually a function of x, it doesn't change as x changes, so
[tex]\lim_{\Delta x \rightarrow 0} \frac{y \left ( x + \Delta x \right )-y\left ( x \right )}{\Delta x} = \lim_{\Delta x \rightarrow 0} \frac{0}{\Delta x} = 0.[/tex]
Rightly or wrongly, I'm thinking of force as a vector field, with a vector defined at each point in space. If we take the magnitude of the component of each of the force vectors which is normal to a specified surface, we get a scalar field.
How then do we get the pressure at one point (if pressure is even defined at a single point)? If we take the value at some point of the scalar field of normal force, as described in the previous paragraph, then divide that by an area, then take the limit as we divide that same unchanging finite number by ever smaller areas, won't the limit be [itex]+\infty[/itex]? Or if we use the definition
and the conventional definition of the derivative, it just seems that the only result can be 0.
"Why does the force decrease as the area does?"
How can it not? If all the individual forces on each small area add up to the whole force.
Why should dF/dA go to zero? By that argument, any derivative would be zero and that is certainly not the case.
The slope of a uniform hill is the same at one point as it is overall - in just the same way.
"Pressure at a single point" will be the same as pressure over a small area around that point and can be the same as the pressure over the whole of the (level) bottom of a swimming pool.
I think that your F = dP/dt is not relevant to this argument even though the definition is correct. What does it do for the force and pressure question?
When you say that you look at Force as a vector field, I think that is where you are going astray. Pressure is the vector field - force is the integral over a surface of that field. That "zero" in your basic definition of the derivative is not correct so what follows isn't right either.
This seems like a different kind of quantity to what I'm used to seeing called force. I'm used to seeing force defined as a vector, namely the time derivative of a momentum vector. Adding forces (to give a net force or total force), in that sense, I think means adding vectors at one point, rather than adding the values of a scalar field at many points. The quantity you call whole force sounds more like a surface integral. Is this the same thing as momentum flux, and would it be written something like this?
[tex]\int_S \textbf{F} \cdot \hat{\textbf{n}} \; \mathrm{d}A.[/tex]
In the standard limit definition,
[tex]\lim_{\Delta x \rightarrow 0} \frac{y \left ( x + \Delta x \right )-y\left ( x \right )}{\Delta x}[/tex]
if y varies as a function of x, then in general [itex]y \left ( x + \Delta x \right ) \neq y\left ( x \right )[/itex], so I don't think what I wrote would imply that any derivative must be zero, only any derivative of a constant function. Apparently the force in the pressure equation isn't constant with respect to area. But I'm curious about how this kind of force is defined?
The derivative of that constant slope is zero. (The derivative of the hill's height as a function of position isn't zero, since the height isn't constant with respect to position.) Would you agree that [tex]\frac{\mathrm{d} F}{\mathrm{d} A} = 0[/tex] unless F varies as a function of A?
sophiecentaur said:
"I think that your F = dP/dt is not relevant to this argument even though the definition is correct. What does it do for the force and pressure question?
Well, that's what I'm wondering ;-)
Obvious I'm getting something wrong... Is this what you mean:
[tex]\int_S \textbf{(pressure)} \cdot \hat{\textbf{n}} \; \mathrm{d}A = (Force)[/tex]
(where bold indicates a vector, italics a scalar).
I must say, all the sources I've looked at seem pretty unanimous that pressure is a scalar quantity...
How about pressure under your foot? It's in one direction.
But I do get your drift. Perhaps I mean that the effect of the pressure is in the direction of the normal n. That must be where my field idea comes in. I don't see that Firce is a field, in any case. An appropriate field can produce a force on a charge / mass / current which is not the same as saying that force is a field. In each of theose cases, the force is proportional to another quantity."The derivative of that constant slope is zero. (The derivative of the hill's height as a function of position isn't zero, since the height isn't constant with respect to position.) Would you agree that LaTeX Code: \\frac{\\mathrm{d} F}{\\mathrm{d} A} = 0 unless F varies as a function of A?"
Of course I couldn't agree with that because the force increases as you increase the area. How else would hydraulic brakes work? In fact, isn't that a clincher argument?
Edit - your maths didn't copy properly but you see what I mean.
Isn't this all to do with the difference between intensive and extensive quantities?
Looking at all this again. Are we both heading in different directions?
Pressure under a solid increases as you decrease the area (force constant).
Hydrostatic force (fluids) decreases as you reduce the area ( pressure constant).
Could that be part of our problem?
You hang an iron cube at the roof through a spring. When the system is stationary, the spring makes a force on the cube, exactly equal to its weight. What is, and which is the value of momentum? If you define force in that way, I see it difficult for a civil engineer to solve static problems to design a building :smile:
Hello sophiecentaur.
Well hi there lightarrow.
Long time no argue!:smile:
I'm not sure I got the relevance of the momentum aspect either.
There are some terminology differences between fields. In solid mechanics, pressure is a scalar and is specifically defined as -1/3 multiplied by the trace of the stress tensor (i.e., [itex]p=-\frac{1}{3}(\sigma_{11}+\sigma_{22}+\sigma_{33})[/itex]). What other people (including Wikipedia) call pressure (and declare to be a tensor), solid mechanics folks would describe as a surface stress: an infinitesimal traction vector acting on a infinitesimal surface area with its own unit normal vector.
In that case, what I need to work out is (1) how many concepts are involved (how many concepts go by the names of pressure, stress and force in physics); (2) what unique and distinct names shall I call them while learning the difference between them (just to keep track of them); (3) what (various) names are each of them called by in the contexts I'm likely to meet them; (4) what do each of the concepts mean.
In the Wikipedia article Stress, at least in this section ( http://en.wikipedia.org/wiki/Stress_(mechanics)#Stress_deviator_tensor ), the trace of the stress tensor divided by three is called "mean stress", and denoted [itex]p[/itex] and [itex]\frac{1}{3}I_1[/itex].
To begin with, I'm particularly interested to understanding the meaning of the kind(s) of "pressure" introduced in elementary physics texts and defined
[tex]\frac{\mathrm{d} F}{\mathrm{d} A} \text{ or } \frac{F}{A},[/tex]
and the kind of pressure which the diagonal entries of the stress tensor are said to represent. I'd assumed that the latter kind of pressure was the same thing as the former kind(s), but now I've no idea!
In elementary physics texts, it's likely that [itex]\bold{F}[/itex] and [itex]\bold{A}[/itex] are collinear, [itex]\bold{F}[/itex] is distributed, and [itex]\bold{A}[/itex] is flat, so the surface stress [itex]\lim_{A\rightarrow 0} (\mathbf{F}/\mathbf{A})=F/A[/itex] and is a scalar that is equivalent to pressure. More generally, [itex]\bold{F}[/itex] and [itex]\bold{A}[/itex] will point in different directions and the surface stress [itex]\bold{\sigma}[/itex] will be a second-rank tensor.
sophiecentaur said:
"Would you agree that [itex]\frac{\mathrm{d} F}{\mathrm{d}A} = 0[/itex] unless F varies as a function of A?"
Your reason for disagreeing seems to be of the form:
(1) P (force is a function of area).
(2) Therefore not: "if not P then Q" (if force isn't a function of area, its derivative wrt area will be 0).
But there's no inconsistency between "if not P then Q" and "P", so I don't think (2) is a valid conclusion. (How's that for pernickity!)
Yeah, obviously I've misunderstood something fundamental. My money's on F, and maybe the nature of force generally.
To get the maths symbols to display, if they're on a separate line, just type "tex" in square brackets [...], then after the code put "/tex" in another pair of square brackets. If the maths is in a paragraph, on the same line as normal text, it works better if you use "itex" and "/itex" instead. In the code itelf, just use a single \ before commands like "frac" (it looks like it inserted double slashes \\ when you tried to copy it).
[tex]\frac{\mathrm{d} F}{\mathrm{d} A}[/tex]
And, if I've got this right, the diagonal elements of a matrix representing that tensor are the components of stress normal to each of the coordinate surfaces, i.e. the pressure (in the elementary physics textbook sense) on each coordinate surface.
I take it [itex]\bold{F}[/itex] is the component of force normal to the surface, and [itex]\bold{A}[/itex] is a vector normal to the surface and proportional to the area. What I don't understand is how, formally, a vector can be "distributed"; does this mean taking a surface integral of a vector field? But how do we do that if force isn't a vector field? Perhaps force isn't a vector in the same sense as acceleration or velocity or electric field strength, given that the velocity of each particle that makes up a car doesn't "distribute" over the car, giving a big car an inherently bigger velocity, whatever that would mean... I guess it's related to the fact that force depends on mass, but that suggests force would get smaller as volume got smaller, rather than area. Anyway, suffice to say, I'm a bit confused...
Yes, I think it must be.
Vector fields have a value at each point in space, and since force is said to be a vector and is often derived from vector fields such as the gravitational field and the electric field, I assumed that force was meant to be a vector field too. What do you make of this?
http://en.wikipedia.org/wiki/Force_field_(physics)
The discussion page suggests that it might not be standard terminology.
That's the second time this week I've seen what looks like a vector in the denominator of a fraction ( https://www.physicsforums.com/showthread.php?t=376048 (#10, #17)). All my books on vectors warned me somewhere in the first few pages: "It is meaningless to divide by a vector!" Is the meaning of this notation analogous to the meaning of diazona's notation, explained in #13 of that thread (where its a scalar field that's being differentiated, rather than a vector)? Could you spell it out for me? E.g.
[tex]\frac{\mathrm{d} \textbf{F}}{\mathrm{d} \textbf{A}} \equiv \lim_{\left \| \textbf{A} \right \|\rightarrow 0} \frac{\textbf{F}}{\left \| \textbf{A} \right \|}\cdot \frac{\textbf{A}}{\left \| \textbf{A} \right \|}?[/tex]
Is this right?
Taking Blandford and Thorne's version of the stress tensor matrix (in Applications of Classical Physics) which is the transpose of the version in Wikipedia's Stress article, if we right-multiply it by a column vector representing a unit vector normal to one of the coordinate surfaces, we get the stress vector (traction vector) embodying the stress on that coordinate surface at that point. And in a Cartesian frame, a unit vector normal to a surface of constant [itex]x^{(k)}[/itex] will be the kth basis vector, so the components of this stress vector will then correspond to the jth column of the stress tensor matrix [itex]S^{ij}[/itex], for example,
[tex]\begin{bmatrix} S^{11} & S^{12} & S^{13} \\ S^{21} & S^{22} & S^{23} \\ <br /> S^{31} & S^{32} & S^{33} \end{bmatrix} \begin{bmatrix}1\\0\\0\end{bmatrix} = \begin{bmatrix}S^{11} \\ S^{21} \\ S^{23} \end{bmatrix}[/tex]
or in slot-naming index notation (abstract index notation), and using the Einstein summation convention (summing over identical indices on different levels),
[tex]S^{ij} \; e_{(k)j} = \frac{\mathrm{d}F^i}{\mathrm{d}A},[/tex]
where an [itex]e_{(k)j}[/itex] is the jth component of the kth basis vector. Or will the matrix calculation be the same in a general frame? I'll have to think about that... And if we take the dot product of this vector with a unit vector normal to the coordinate surface, we get
[tex]e_{(k)i} \; S^{ij} \; e_{(k)j} = e_{(k)i} \; \frac{\mathrm{d}F^i}{\mathrm{d}A} = S^{(ii)} = \frac{\mathrm{d}F}{\mathrm{d}A} = p,[/tex]
the normal stress (that is, pressure) on the specified coordinate surface at that point. The bracketed indexes in [itex]S^{(ii)}[/itex] indicating one particular value, a single number. And for an arbitrary surface with unit normal vector [itex]n^j[/itex], the pressure (normal stress) is
[tex]n_i \; S^{ij} \; n_j = n_i \; \frac{\mathrm{d}F^i}{\mathrm{d}A} = \frac{\mathrm{d}F}{\mathrm{d}A}.[/tex]
PF's own page about pressure has this definition of force:
[tex]\bold{F}\,=\,\int_SP\,\hat{\bold{n}}\,dA\ \ \ \ \ \ (F = PA\ \ \text{for constant pressure on a flat surface}).[/tex]
Which gels with what sophiecentaur's being saying (if I've understood) that force (unlike stress tensors, stress vectors and pressure) isn't a local property, since at a point, there is no area, and so no force.
But is this equation only valid where there's no shear stress? Or, to put it another way, I'm (tentatively) thinking this [itex]\bold{F}[/itex] must be a vector field [itex]\bold{F}\left( P, \hat{\bold{n}},A, x,y,z \right)[/itex] defined over the specified surface, everywhere normal to the surface, and each force vector having the identical magnitude
[tex]AP=\int_SP \, \mathrm{d}A.[/tex]
Perhaps we could write:
[tex]\text{pressure} = \frac{\partial}{\partial A} \left ( \textbf{F}\left ( p, \hat{\textbf{n}},A,x,y,z \right ) \right ).[/tex]
All real forces are distributed; point forces are only an idealization. Does this clarify things?
This seems crazy, or perhaps is a caution found in texts whose scope doesn't include tensors. Vector division happens all the time. We divide [itex]4\bold{i}[/itex] by the unit vector [itex]\bold{\hat{i}}[/itex] to get its magnitude, 4. From the equation [itex]\bold{F}=\bold{\sigma}\bold{A}[/itex], where [itex]\bold{F}[/itex] and [itex]\bold{A}[/itex] are vectors and [itex]\bold{\sigma}[/itex] a second-rank tensor, we have [itex]\bold{F}\bold{A}^{-1}=\bold{F}/\bold{A}=\bold{\sigma}\bold{A}\bold{A}^{-1}=\bold{\sigma}[/itex].
Yeah, thanks. I hope so! Can we say that force is only defined with respect to a specified surface of some orientation and non-zero area, subject to a certain (vectorial) stress; and force is then defined at each point on the specified surface, having a constant magnitude, this being the area times the pressure? Or does this definition only work in the absence of sheer stress? Is that only a particular kind of force: normal force, wrt the surface?
The warning was given in the context of the dot product
[tex]\textbf{a}\cdot\textbf{b} = \left \| \textbf{a} \right \| \, \left \| \textbf{b} \right \| \, \cos{\theta_{\textbf{a},\textbf{b}} } = x[/tex]
where for a given vector [itex]\textbf{a}[/itex], and a given x, there is not generally a unique vector [itex]\textbf{b}[/itex]. Also:
http://mathworld.wolfram.com/VectorDivision.html
Not quite; (1) stress is generally a tensor. (2) You can define a force at a point, but this is going to muddy the relationship with pressure, since all real forces are distributed. (3) There's no problem with incorporating shear stress, which exists if the force and the surface are not perpendicular.
Okay, so how's this? We let the stress tensor, [itex]S^{ij}[/itex], act on the unit vector normal to an arbitrary surface, [itex]n_j[/itex], resulting in a traction vector (also called a stress vector in the Wikipedia article Stress). Again using the Einstein summation convention:
[tex]S^{ij} \, n_j = \frac{\mathrm{d} F^i}{\mathrm{d} A}[/tex]
This vector tells us all about the stress on a surface element at the point where it's defined, including pressure and sheer stress. Compared to the stress tensor, the traction vector has "forgotten" about the stress on all the other surface elements we might consider at that point (except that we can still deduce from it the equal and opposite stress on a surface element with the opposite orientation). The dot product of the traction vector with the unit normal vector gives us the pressure on this surface element:
[tex]n_i \, \frac{\mathrm{d} F^i}{\mathrm{d} A} = p\left ( \hat{\textbf{n}} \right ).[/tex]
All of this can be done for each point where we define our surface.
The normal force is
[tex]\textbf{F}_\perp \left(p,\hat{\textbf{n}},A,x,y,z\right) = \int_S \; n_i \; \frac{\mathrm{d} F^i}{\mathrm{d} A} \; \hat{\textbf{n}} \; \mathrm{d}A = \int_S \; p \; \hat{\textbf{n}} \; \mathrm{d}A = A \; p\left(x,y,z\right) \; \hat{\textbf{n}}[/tex]
[tex]\equiv \left(F_{\perp}\right)^i = \int_S \; n_j \; \frac{\mathrm{d} F^j}{\mathrm{d} A} \; n^i \; \mathrm{d}A = \int_S \; p \; n^i \; \mathrm{d}A = A \; p\left(x,y,z\right) \; n^i,[/tex]
so I guess the whole force must be
[tex]\textbf{F} \left(p,\hat{\textbf{n}},A,x,y,z\right) = F^i = \int_S \; \frac{\mathrm{d} F^i}{\mathrm{d} A} \; \mathrm{d}A = \int_S \; S^{ij} \; n_j \; \mathrm{d}A = A \; S^{ij} \; n_j.[/tex]
And both are vector fields defined on the specified arbitrary surface. Even though they have a value at each point on the surface, both are "distributed" entities in the sense that their magnitude at anyone point depends partly on the area of the whole surface we've chosen, and the value of either vanishes if we reduce the surface area to nothing. At first, I thought the magnitude of the normal force would be constant over the surface, but I was forgetting that the pressure might vary over the surface as a function of position, so I suppose the magnitude of both vector fields (both normal and whole force) can vary over the surface, although they will everywhere by proportional to the unvarying area.
Regarding (1), I guess you mean "a 2nd, rather than a 1st, order tensor" (I'm presuming both the 2nd order stress tensor, as well as what Wikipedia calles the stress vectors or traction vectors, are tensors, the latter being derived from the former by regular tensor algebra; but I'm not absolutely sure if that's a guarrentee of tensorhood--need to read further on that). Regarding (2), unless I got it all right on my next attempt, could you spell out in what sense force is both a vector and not defined locally at a point in space. I think I might have figured (3) out, fingers crossed... You didn't comment on the magnitude issue, but I think I was wrong to say it would be constant. What do you reckon to my solution, is that how force, normal force, pressure, and traction are defined with respect to the stress tensor? Is force a tensor (in the physics sense of being invariant, not coordinate dependent)? I'm guessing maybe yes, since it's defined in terms of other tensors?
The reasoning seems generally OK, but I'm not sure why you're mixing superscript and subscript indices, I'm not familiar with [itex]p(\hat{\bold{n}})[/itex] (the pressure at a point is often written as [itex]p(\bold{r})[/itex], where [itex]\bold{r}[/itex] is referenced to the origin), and your general traction vector is pointing perpendicular to the surface, which isn't very general. So I'm hesitant to "thumbs-up" the math just yet.
EDIT: This is in response to your post #25.
I've been calling second-order tensors tensors, and first-order tensors vectors. This is pretty standard.
It is an idealization to say that force is a vector. A true vector force, if it existed, would produce an infinite amount of stress on any material to which it were applied.
http://en.wikipedia.org/wiki/Einstein_summation_convention
The simple answer is that where the same letter appears once as an upper index and once as lower index, on the same side of an equation, it's summed over.
Mapes said:
I'm not familiar with [itex]p(\hat{\bold{n}})[/itex] (the pressure at a point is often written as [itex]p\left(\bold{r})[/itex], where [itex]\bold{r}\right)[/itex] is referenced to the origin),
By [itex]p\left(\hat{\bold{n}}\right)[/itex] I meant to indicate that the pressure is a function of (among other things) the orientation of the surface. To show that it depends on position too, we could write [itex]p\left(\hat{\bold{n}},\bold{r}\right)[/itex].
Actually it was the general force vector, but good point! I've made the relevant corrections to #25.
Not if defined as in #25, I think. But is this definition consistent with
[tex]\frac{\mathrm{d}\textbf{p}}{\mathrm{d}t}?[/tex]
I'm guessing it would be if both definitions are standard and quantities are called force and used in the same context without comment in elementary physics textbooks, but I can well imagine there might be complications...
  • · Replies 18 ·
  • · Replies 20 ·
