| Thread Closed |
which liquid have low specific heat capacity |
Share Thread | Thread Tools |
| Feb9-10, 08:01 AM | #1 |
can you please state some liquid which is a good heat conductor
(which have low specific heat capacity) |
| Feb9-10, 09:51 AM | #2 |
Got to http://www.matweb.com/search/PropertySearch.aspx
On the left tree, click fluid. On the right choose specific heat capacity, and set a number to your preference as max. I have found 22 fluids which are below 0.45 J/gK (which is the specific heat capacity of iron). |
| Feb9-10, 10:21 AM | #3 |
Actually the thermal conduction is usually direct dependent on heat capacity (larger heat capacity=> larger thermal conduction). |
| Feb10-10, 05:13 AM | #4 |
thank you
| Thread Closed |
| Thread Tools | |
Similar Threads for: which liquid have low specific heat capacity
| Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity | Advanced Physics Homework | 4 | ||
| Specific Heat Capacity of solids liquid or Gas, which is largest? | Introductory Physics Homework | 7 | ||
| Convert ml to grams for a Heat Capacity and Specific Heat problem, is that possible? | Biology, Chemistry & Other Homework | 3 | ||
| Specific heat capacity, latent heat => ice water steam mixture | Introductory Physics Homework | 1 | ||
| specific heat capacity and latent heat of fusion | Introductory Physics Homework | 4 | ||
