What is meant by momentum is maximised?
  • Thread starter Thread starter maxbye3
    Momentum
The discussion centers on the concept of "maximized momentum" in the context of rocket propulsion. The user is analyzing a rocket's momentum after 250 seconds of engine time, with specific parameters including a fuel rate of 480 kg/s, an initial exhaust speed of 3.27 km/s, and a final velocity of 12.2 km/s. The key takeaway is that "momentum is maximised" refers to the point at which the rate of change of momentum with respect to mass (dp/dm) equals zero, indicating the optimal mass fraction for maximum momentum.
  • Understanding of rocket propulsion principles
  • Familiarity with momentum equations in physics
  • Knowledge of mass flow rates in rocket engines
  • Basic calculus concepts, particularly differentiation
  • Study the principles of rocket propulsion and thrust-to-weight ratio
  • Learn about the Tsiolkovsky rocket equation for velocity calculations
  • Explore the concept of momentum conservation in closed systems
  • Investigate the relationship between fuel consumption rates and rocket performance
Aerospace engineers, physics students, and anyone involved in rocket design or propulsion analysis will benefit from this discussion.
maxbye3
I'm answering some questions to do with rockets and their momentum after 250s of engine time
t=250s
fuel rate of rocket= 480 kg/s
initial exhaust speed= 3.27 km/s
final velocity: 12.2 km/s
m (fuel at t=0) = 1.81*10^5 kg
m(total at t=0) = 2.55*10^5 kg
m (total at t=250s) = 68400 kg
associated questions have been pretty simple so far like:
find the final velocity
find the ration of masses if the final speed was ...
I'm stumped on the meaning of the phase "momentum is maximised"
(not lookign for someone to do my homework)
the phrase I'm stumped on:
A rocket starts moving from rest in deep space. What fraction of its initial mass does the
rocket (i.e. casing plus payload plus remaining fuel) have when its "momentum is maximised"
what is the definition of maximised momentum? The larger the final velocity, the larger the momentum and this all depends on the feul rate from which the rocket uses (the amount of feul 480kg/s)
Anyway if anyone can understand what is meant by "momentum is maximised" that would be great.
http://img14.imageshack.us/img14/2735/momentuum.jpg
Here is a graph of you problem. More exactly the momentuum of your rocket as a function of time. It has a maximum right there.
thanks lok, I wasn't thinking at all.
I took dp/dm=0 to get maximum initial mass?
Thanks!
  • · Replies 42 ·
  • · Replies 22 ·
